Threads: 244
Likes Received: 1,116 in 475 posts
Likes Given: 893
I'm used to helmets with anti-fog coatings on the inside of the visors. But, I just bought two helmets from a european supplier, and neither has this coating. One of them included a Pinlock insert, which I haven't installed yet.
Fogging is a rather minor annoyance here in Southern California, and only this time of year when the weather is chilly, and when I'm stopped or moving very slowly, so I haven't been expedient in putting the insert in my helmet.
I've been reading about Pinlock inserts to get up to speed on them. The advice I've read is that they're for daytime use only. Since half of my riding this time of year is at night coming home, I don't need any problems seeing where I'm going.
For those of you who use them, do you have any trouble at night? And, if they are removed from the shield, do they leave any residue on the shield or damage it in any way, or destroy the Pinlock in the process?
Also, being a very cheap person, I'm seeing universal-fit anti-fog inserts on Amazon with good ratings. For the helmet that didn't include a Pinlock, looking at this as well. Anyone use one from Amazon?
For cool weather night riding (-20C to 9C) resulting in possible visor fog up, I do one or more of the following:
* Crack the visor open a wee bit (this is typical for me),
* For winter riding I use a second barrier shield,
* Pre-heat the helmet before putting head into it (I almost never do this - helmet is stored outside 'cause I am lazy),
* Stop breathing in the helmet.
Threads: 244
Likes Given: 893
*I tried the stop breathing thing, and I got dizzy.
*I always crack the visor open. The only time I forget is when I'm moving slowly on the freeway ramp, and both hands are busy on the brake and the clutch. Comically, that
means the only time fogging is a real issue is when I'm getting on the freeway and need my best visual acuity to cross four lanes of gridlock to get to the car pool lane.
*In the morning, the garage is warmer than the house... I'm assuming because the water heater is in the garage, so the helmet shelf is warmer than it would be in the
house, but my breath is warmer than the garage.
Thinking I might try wearing a neck tube in the morning, and pull it up over my mouth and nose. That would keep my neck warm too. I think I have a drawer full of various tubes and face coverings left over from the recent unpleasantness.
Threads: 92
I've had Pinlock. They work well in cold weather and cool, humid weather. You have to be prepared that they scratch rather easily and need to be replaced from time to time. You're not supposed to wear them at night. I did one time and I did not think it impaired visibility. They aren't great in a dust storm...sand particles will get inside them (happened to me in Death Valley).
Threads: 244
Likes Given: 893
Thanks, Stichill. How long do yours typically last? Good to know about your night riding experience. That's a big concern for me.
Likes Given: 747
(01-17-2024, 04:52 AM)Gone in 60_imp Wrote: *I tried the stop breathing thing, and I got dizzy.
Like GO I crack the shield a tiny bit at the bottom.
Chances are if you wear a neck tube (or balaclava) over your nose it will only make the fogging worse (especially if you use glasses).
I've always thought a tube with mouthpiece like snorkelers wear, that runs out below your helmet would be the cat's meow. Breath into the mouth piece and the air exits below the helmet., nowhere near the inside of the face shield.
Maybe you can 3d print one and attach a piece of 1/2" fuel line. Let me know if my theory is right.
Threads: 244
Likes Given: 893
If I'm going to 3D print a mouthpiece and breath through a fuel hose, I might as well just put the Pinlock on my shield.
(01-17-2024, 08:13 AM)Gone in 60_imp Wrote: If I'm going to 3D print a mouthpiece and breath through a fuel hose, I might as well just put the Pinlock on my shield.
lol - Some riders have done this.
I use the double layer visor during winter riding.
I have pins locks buried in my basement somewhere (don't use 'em).
Threads: 244
Likes Given: 893
(01-17-2024, 08:06 AM)The ferret_imp Wrote: (01-17-2024, 04:52 AM)Gone in 60_imp Wrote: *I tried the stop breathing thing, and I got dizzy.
I grabbed a neck and face tube (out of the box of branded ones we had made during the recent unpleasantness), put it on. I then put on one of my new helmets. First of all, hard not to push down a face tube when you're putting on a helmet.
I then started breathing with the shield down, and yeah, it started fogging a bit. But hey, now I have something to keep my neck warm.
There is truth in all that.
