The best laid schemes … gang aft agley
Threads: 349
Likes Given: 1,034
Part 1—In which Cormanus remounts the bike
The original map is [url=https://drive.google.com/open?id=1Umn4GOjrV3CPTKp6rfpjgz9-mXI&usp=sharing]here
There has been, as they say in the outback, a bit of a dry spell for Cormanus and his CB1100. There are good reasons for it—including a month or so away—but it had left me with a strong feeling that something important was missing from life.
It was with some enthusiasm, then, that I greeted Thursday 1 September when, weather permitting, I could get on the bike for a full day’s ride.
The day dawned glorious, albeit a bit chilly; but that was nothing a considered layering wouldn’t deal with. So I saw my wife off to work, put on the gear, programmed the GPS, climbed on to the CB and headed out the gate.
It was quickly to become clear that the riding gods were not just watching but doing so with a certain sardonic malevolence.
Warning number one was when the Bluetooth dongle that connects my telephone (GPS) and my earphones didn’t quite work. I stopped and fixed it.
Warning number 2 was when I realised I’d neglected to put the AirHawk cushion on the seat—I knew my butt’d be sore if I made it through the day I was planning; but by then I was heading away from home and nothing, but nothing, was going to send me back there.
Warning number 3 came after 35 kms or so down the freeway when I’d turned off to head for the hills. Of course, I was starting to feel much, much better about life. Simple things are good.
I stopped for fuel, paid the bill, walked outside, got on the bike, pressed the starter … whirr, whirr, click. Pressed it again … click.
A bit of history. The bike is a 2011 model. I bought it second hand in September 2013 with 2079 kms on the clock. I’ve had for nearly three years and ridden more than 45,000 kms on it. My recollection is that, in spite of being a 2011 model, it wasn’t purchased new until May 2013. So it was nearly two years old when ostensibly new and is now nearly 5 years old. I’ve not replaced the battery. And I suspect the one making odd noises was original.
A five-year old battery owes me nothing.
While it has been a little temperamental since I got home at the end of July, it had started fine that morning. It had just been run for 30 or so minutes, so it should have been charged. The ‘whirr, whirr, click’ suggested it wasn’t.
So I swore. Got off the bike. Swore. Pushed it up the slight incline, parked it and consulted Google for the nearest Honda dealer. Practised swearing again. Thirteen kms back up the motorway.
Got the gear back on, rolled down the slight hill and jump started the bike. Rode the 13 kms, parked the bike, turned it off, turned it on, pressed the starter … ‘Whirr, whirr, v‑r‑r‑r‑rooooooom!’
Repeat. Same result.
What to do? I’m basically cheap. Why buy a new battery if I don’t really need one? Reflect, Cormanus, reflect … It’s clearly becoming temperamental and I ride a lot on my own; I’d have no hope of pushing it and jumping on to start it on my own on the flat and I can’t always be guaranteed a hill.
I went inside and bought a new battery. The nice young lady came outside and checked to make sure it would fit. It did and I said I’d put in myself. I hadn’t paid, so I offered my keys as surety and said I’d put it in then come and pay. I was offended when she took them without question. Do I look that shifty?
Positive terminal: no problems, although even the tiny extra thickness of the terminal for the battery tender made it a bit of a stretch to get the bolt to bite on the nut. A finger on the nut to lift it a micron or two did the trick.
Negative terminal: ‘clunk!’ The bolt slipped out and into the battery tray.
Disconnect the positive terminal. Remove the battery. Find the bolt.
Repeat.
Drag the bike backwards up a slight incline to a flat bit. Put it on the centre stand.
Try as I might, I could not get the negative terminal connected if I included the terminal for the battery charger. The design of the OEM leads is such that the left hand side of the wee opening that holds the nut is covered by part of the terminal and the finger trick was not possible. I couldn’t find anything slim enough to wedge it. So, when it eventually dawned on me that with a new battery I’d probably manage the day without the charger, I stashed the terminal carefully and connected the battery without it.
Digression: it took a bit of fiddling in the garage the next day to get the charger reconnected. I had to wedge a small cable tie under the nut enough to lift it so the bolt would bite.
I went inside, paid, retrieved my keys and went outside to get going again. I pressed the starter. ‘Whirr … v‑r‑r‑r‑rooooooom!’
At that point I noticed a couple of very excellent second hand bikes for sale.
You’ll notice there are two bikes of great appeal in this shot: to my eye the CB1300 is not as beautiful as the CB1100, but I still carry a torch for one.
By now a ridiculous amount of riding time had disappeared and the day’s plan would have to be reconsidered. Because I’m more of a [url=http://cb1100forum.com/forum/showthread.php?tid=9086]wanderer than a planner, I thought I might as well ride as do anything else while I figured it, so I turned south.
My destination was O’Reilly’s—a rainforest retreat at the top of a mountain in the Lamington National Park in the border ranges. The attraction was twofold: I’d never been there and the road leading up to it looked promising.
A very short section of the road to O’Reilly’s
It was not long before I’d escaped the worst excesses of the built-up area, and in an hour I was at the bottom of the O’Reilly’s road.
It wasn’t long before I was in the country
Leaving Canungra, the town at the start of the O’Reilly’s Road
The start of the O’Reilly’s road
From Canungra up the hill to the O’Reilly’s Rainforest Retreat is about 35 kms and just under an hour’s ride. It’s a great surface, sometimes lacking a centre line; it twists and turns and was not blessed with much traffic that day. The scenery is terrific, although there’s not always a great deal of time to look at it and concentrating on riding.
What can I say? It was really, really good to be back in the saddle on a country road that wound its way somewhere. The cares of the morning fell away.
Some hazards are better avoided. A sidebar: it was only when writing this post and reviewing the photos that I realised I’d lost a bar weight. Is it too embarrassing to admit that I’d spent another day on the bike after this and still hadn’t noticed?
This sign is a wonderfully common sight on the way up the hill
This was one way!
Arriving at O’Reilly’s, where it was a deal cooler than down in the valley, I decided to reward myself with a coffee and an acceptable toasted sandwich.
09-15-2016, 10:15 AM
postoak_imp Offline
Threads: 50
RE: The best laid schemes … gang aft agley
Thanks, Cormanus, I enjoyed reading all that.
09-15-2016, 10:40 AM
Likes Given: 815
Some days can be trying that's for sure, but a ride usually sorts them for me....and the battery thing just drives you nuts doesn't it? At least with the old acid filled batts you got a little warning they were going down hill. My ST batt was installed Nov 2011. I'm thinking in November just go ahead and buy a new one, even though I am ..um..frugal as well, and hate to replace things if they don't need replacing.
Great pics and narration as always. That Blind Curve Prepare to Stop sign is a new one for me and I sold traffic signs for 25 years.
09-15-2016, 11:32 AM
physics-teacher_imp Offline
Threads: 9
No 'roos in the road?
09-15-2016, 11:46 AM
DAC Offline
Threads: 17
Likes Received: 12 in 6 posts
Likes Given: 12
Great pics and report as always, Cormanus. You're a lucky boy. Nice to have a hill nearby to bump the bike with, lots of modern techno to find the dealership, plus a sandwich at the end!
09-15-2016, 11:50 AM
Threads: 349
Likes Given: 1,034
Part 2—In which Cormanus has a quick look around
Fortunately, the assumption made earlier about the acceptability of the toasted sandwich was correct. It wasn’t stellar; but ‘ acceptable’ is a suitable adjective. As I ate it and drank my coffee I observed people coming and going from the café. Amongst them was a group of tourists, nearly all of whom had the sort of cameras with lenses so big you wonder how they hold them up. They were talking and I heard snatches of conversation which referred to Tasmania, the state where I grew up. I was a bit intrigued, but kept to myself. As I made my way outside to the sitting area which contained any number of signs imploring visitors NOT to feed the birds, there they were flinging seed about with gay abandon, cameras click-clacking at the visiting parrots. To be fair, one of their number soon pointed to the signs and they stopped. I was grateful to them as I got this shot of a crimson rosella. Red birds: they’re everywhere!
O’Reilly’s is a resort in the middle of a national park. The family has been present there since the early 2oth Century engaged in forestry, tourism and, more recently, but not on this site, wine growing. I recall that, in a former life, I worked briefly with an O’Reilly who rode a Ducatti up and down the hill from here.
Sitting on the site above the café is this replica of a Stinson airliner.
Friday 19 February 1937 was stormy in the afternoon and an identical Stinson crashed in the McPherson Ranges killing four out of seven people aboard. A search failed to find any wreckage.
Seven days later Bernard O’Reilly set out on foot to find the wreckage. He was convinced the plane had gone down in the Lamington National Park. He was right and discovered the wreckage. Amazingly, he discovered two survivors who, not surprisingly, were in serious need of medical attention. Bernard did what he could to make them comfortable and set off for help. He returned the next morning with a doctor and a few of his farmer mates and the survivors were stretchered to safety 11 days after the plane went down.
Of course, this is the stuff of which movies are made and, in 1987 [url=http://www.imdb.com/title/tt0136490/fullcredits?ref_=tt_ov_st_sm]The Riddle of the Stinson was released. To make the movie, a similar Stinson was rescued from the soon-to-be-closed Wangaratta Air Museum and turned into a model of the missing aircraft. The O’Reilly family bought it in 2012 and relocated it to the resort.
The Riddle of the Stinson starred Jack Thompson, an Australian actor who also starred in Clint Eastwood’s Midnight in the Garden of Good and Evil alongside the wonderful Kevin Spacey and John Cusak. Thomson’s co-star was Richard Roxburgh who has featured recently on the small screen in a wonderful comedy called Rake.
All this allows me to segue into a rant. While America is responsible for many an excellent movie and television series, it has saturated the world with millions upon millions of hours of television so crappy it’s hard to understand how anyone could watch it. And yet they appear incapable of watching anything of any quality made by anyone else. My visit to O’Reilly’s lead me to reflect on two recent examples: Rake a brilliant Australian series which the US found necessary to remake starring Greg Kinnear; and Kevin Spacey’s House of Cards, which, while very good, pales in comparison with the English original from which it was copied.
And why, oh why, oh why, did America find it necessary to remake Ricky Gervais’ The Office which for comic genius is comparable only with Cleese’s Fawlty Towers?
Is it because Americans think only they can do anything properly? I have no idea; but I wondered about it as I walked to the car park and the waiting CB, blissfully unaware of what awaited me during the afternoon.
09-15-2016, 04:54 PM
Rocky_imp Offline
Threads: 26
Great narrative. I really enjoyed that Thumbs Up Thumbs Up
09-15-2016, 08:20 PM
postoak_imp Offline
Threads: 50
I agree with you on "House of Cards". I haven't even bothered to watch the U.S. version as I'm sure it would disappoint.
Where are you from in Tasmania? I've been to Launceston, Strahan, Hobart, and Port Arthur.
09-16-2016, 03:07 AM
Haystack_imp Offline
Threads: 8
[q
[/quote]
The worst day of riding is better than time spent in front of a screen watching TV crap.
09-16-2016, 04:37 AM
use2b_imp Offline
Threads: 39
everyone looks shifty to me mate , they might have those cheap $1 chinese keys and take off with a me bloody battery !
so you couldn't attach the charger Neg to the frame anywhere under the seat? and my gosh man your riding on the wrong side of the road ! that is how I got hit by a cab in hong kong in 72 they do the same thing!
BTW one of my favorite bands of all times was " men at work " what ever happened to them ? I would say more but it might be overkill. enjoyed the ride , somehow I think I was there !
https://www.youtube.com/watch?v=RY7S6EgSlCI
https://www.youtube.com/watch?v=XfR9iY5y94s
https://www.youtube.com/watch?v=SECVGN4Bsgg
09-16-2016, 06:40 AM
