Interesting Discovery
ridesalot_imp Offline
Threads: 1
I have been installing Lockhart-Phillips bullet turn signal lights this week. Knowing that the CB11 has front marker lights combined with the turn signals I ordered the 3 wire version with dual filament bulbs for the front. When I began to disconnect the stock lights I found only two wires. After doing 6 similar installations on other bikes this is the first time I have encountered this system. Apparently, Honda sends a low amperage signal down the turn signal wire full time to serve as marker lights. When the turn signals are operated a higher amp signal is sent down the same wire to produce the flashing. I installed the lights leaving the marker light wires disconnected. Works fine. So... anyone planning this farkle, you will only need the two wire lights.
P.S.
This farkle is a bit more involved on the CB11 than on other bikes I have done. For those who are going to do it, have patience. You will have a few problems to solve.
06-06-2013, 12:51 AM
Threads: 698
Likes Given: 792
RE: Interesting Discovery
What about the emergency flashers?
06-06-2013, 01:38 AM
Deanohh_imp Offline
Threads: 5
I'm too stupid so I'll just leave mine the way they are.
06-06-2013, 02:19 AM
Threads: 1
(06-06-2013, 01:38 AM)The ferret_imp Wrote: What about the emergency flashers?
I never thought of that. I think they will be unaffected by my mod since the the same type turn signal filament is being used in the new bullet lights.
I'll let you know when i get out to the garage.
06-06-2013, 03:08 AM
Threads: 1
Ferret, I checked the emergency flashers. They function normally.
06-06-2013, 07:26 AM
  Interesting Helmet light options satchit 1 343 06-21-2020, 02:59 AM
  interesting chic design fairing ... jedd_imp 12 1,208 01-17-2019, 06:18 AM
  Interesting article on lead-acid vs. lithium batteries Ulvetanna_imp 6 591 11-08-2016, 07:15 AM
  Interesting custom full yosh exhaust on eBay Hondahawkrider_imp 6 558 05-06-2016, 12:08 PM
  Interesting option for front fork cartridge kit. kmoney_imp 5 457 12-04-2015, 01:48 PM
Last Post: spacetiger_imp
