Not Too Quiet Now
FUZZY_imp Offline
Threads: 18
Not Too Quiet Now
Temporary mod. Actually sounds great & mellows right out @ cruise speeds.
[url=http://www.youtube.com/watch?v=pRhTiGGTgt4&sns=em]http://www.youtube.com/watch?v=pRhTiGGTgt4&sns=em
06-02-2013, 09:53 AM
oldyaler_imp Offline
Threads: 2
RE: Not Too Quiet Now
The link doesn't work for me.
06-02-2013, 10:48 AM
wildezt_imp Offline
Threads: 9
this one below should work oldyaler
thats not too quite at all Fuzzy,rightly said..
but man, that sounds too loud for me... Big Grin definitely would get people and animals out of the way for sure when you open it.....Big Grin
06-02-2013, 12:20 PM
FUZZY_imp Offline
Threads: 18
Thanks I don't know what happened on previous link. I have been on H-D's for a long time with my last '10 Road Glide punched, polished & ported running D&D 2-1. This seems pretty mild based on what I'm accustomed to. Had a '05 ZRX1200 tricked out with a Muzzy Meg. Now that's the sound I'm looking for. Trying to hold out and see if USA company gets us fixed up.
06-02-2013, 12:46 PM
Threads: 2
(06-02-2013, 12:20 PM)wildezt_imp Wrote: this one below should work oldyaler
Thanks. Too loud for me too. Now, if someone could come up with an exhaust system that sounded like this at idle but got quieter with increased throttle I might be interested.
06-03-2013, 01:48 AM
ChipBeck_imp Offline
Threads: 29
I like it. I like your Mustang GT too. The catalytic converter acts as a muffler so it's not nearly as loud as straight open pipes would be. I did the same thing on my 2007 Shelby GT car. Removed the mufflers and kept the cats on. It has a really nice sound. Did you make that cat back pipe or did you have it made?
Chip
06-03-2013, 02:03 AM
Deftquiver_imp Offline
Threads: 4
I love it!!! That could hold me over until the US develops more of an aftermarket. Details please!?!?
Oh and thank for blazing the way.
Deft
06-03-2013, 02:43 AM
FUZZY_imp Offline
Threads: 18
(06-03-2013, 02:03 AM)ChipBeck_imp Wrote: I like it. I like your Mustang GT too. The catalytic converter acts as a muffler so it's not nearly as loud as straight open pipes would be. I did the same thing on my 2007 Shelby GT car. Removed the mufflers and kept the cats on. It has a really nice sound. Did you make that cat back pipe or did you have it made?
Chip
It's a step reducer & turn out. You are correct. Cat takes place of a muffler. It's loud when you want it to be or it will growl when you desire. That's the wife's GT. She has Roush on the 5.0. It really talks. My 69 Camaro has Thorley's & twin FM super 44's. Same with it.
It's not the look @ all I'm going for on the 11. The sound is close & 100 times better than stock.
Whoever made SA comment about sticking to HD's. I've probably modified more types of vehicles in my life than you have seen. I can take criticism all day long. SA attitudes, not.
(06-03-2013, 02:43 AM)Deftquiver_imp Wrote: I love it!!! That could hold me over until the US develops more of an aftermarket. Details please!?!?
Deft
This won't get ya a trophy in a bike show but if ya need sound I think you'll be pleased. I fired it it without the turnout an it was loud but adding the step down & turnout made it a much better tone.
Getcha a 2" turnout exhaust tip, 1 7/8" ID X 1 3/4" OD Exhaust Adapter & a can of VHT Flameproof flat black spray paint.($22.27 @ Autozone) You will have to use hack saw or sawzall to cut small adapter end lenghthwise across opening down to just before transition. Then spread the small end opening until it will slide over stock pipe off collector. I had an extra band clamp to secure this but you can probably use the stock muffler clamp. Then you can position turnout for next step which is to determine where on back of turnout you need to drill for center stand stop bracket. You cam easily make this out of a 1" or 3/4" piece of flat bar. Drill hole in 1 end, come down slightly & put a 90* bend. Hold up to back side of turnout, push down on center stand enough to clear chain + say 1 1/2" & mark turnout to drill. Cut of excess from end of flat bar @ center stand location. You can put or socket head bolt through from inside turnout, through bracket & attach with nyloc nut.
06-03-2013, 03:57 AM
johnnymac_imp Offline
New to the Forum
Threads: 1
What size is the pipe when you take off the muffler? I might get a JC Whitney long megaphone that sits low just to have more room for bags??
Thanks
06-04-2013, 11:04 PM
FUZZY_imp Offline
Threads: 18
(06-04-2013, 11:04 PM)johnnymac_imp Wrote: What size is the pipe when you take off the muffler? I might get a JC Whitney long megaphone that sits low just to have more room for bags??
Thanks
Stock can has 1 5/8" ID inlet. Note it has an upward sweep on header outlet. Let me know what ya find!
06-04-2013, 11:48 PM
  My DLX factory pipes are too dang quiet! Rebel73_imp 29 2,074 08-06-2017, 07:39 AM
Last Post: rustyski_imp
  Quiet as stock 4x4 exhaust Ack-CB11_imp 17 1,295 08-07-2013, 10:25 PM
Last Post: Ack-CB11_imp
