 Dart Flyscreen Has Arrived!
The Spaceman_imp Offline
Threads: 42
The box from the UK just arrived and everything looks top notch. The plastic is heavy duty and a perfect shade, the hardware is excellent, and the brackets are clearly made just for my bike.
I will install it after dinner and post mote details and photos tomorrow.
10-03-2013, 09:32 AM
Likes Given: 752
RE: Dart Flyscreen Has Arrived!
Saweet!
10-03-2013, 09:39 AM
Utah1_imp Offline
Threads: 2
Okay now the true test, does it keep the love bugs off your teeth at 80mph??
10-03-2013, 10:29 AM
CB4ME_imp Offline
Threads: 183
(10-03-2013, 09:32 AM)The Spaceman_imp Wrote: The box from the UK just arrived and everything looks top notch. The plastic is heavy duty and a perfect shade, the hardware is excellent, and the brackets are clearly made just for my bike.
I'm not surprised in the least. Dart is top notch stuff. Can't wait to see it on your bike!
10-03-2013, 10:52 AM
Threads: 42
Attention Dart Shoppers!
The kit installation was a piece of cake. You only need three hex head tools (T-handle type worked for me) in 4, 5, and 6 MM. Following the simple step by step instructions provided in the kit took under 30 minutes. You connect the new headlight brackets to the screen brackets for each side, remove the bolts holding the headlight, then remove the OEM brackets one at a time and replace with the new. Next install the plastic, then line up the parts and headlight and snug up. This is a precision kit. The fit is amazing; the parts "fell" into place, and once I tightened the hardware, the screen was perfectly aligned. The fit is so precise that with the chrome gauge covers installed, there's just enough space between the top of the brackets and the bottom of the gauges to slide a sheet of paper through!
The performance is even better; it transforms the ride. I took the bike out this morning on the Florida Turnpike for high-speed testing. Luckily at rush hour you can get right up to 100 indicated without drawing attention to yourself. There is no wind pressure on the chest. By holding my hand up and moving it up, I found the airflow started just at the bottom of my helmet. Interestingly, the faster I went, the higher the airflow moved. The bottom line: at 80-90 mph I was in a calm bubble of air with no buffeting and a smooth flow of air around my helmet. I'll be able to easily ride all day with this screen installed.
I took some photos, but honestly the ones on the Dart website are better. Suffice it to say that every part and bit of hardware is excellent, the fit is precision, and the performance is exactly what I was looking for. It took me 3 windscreens, a Madstad bracket, and 2 years of messing around to get to this point with my DL1000.
10-03-2013, 11:26 PM
Firstfour_imp Offline
Threads: 2
Awesome! Thanks for the fine report. Thumbs Up
10-03-2013, 11:31 PM
ron1100_imp Offline
Threads: 2
(10-03-2013, 11:26 PM)The Spaceman_imp Wrote: Attention Dart Shoppers!
Thanks for the review. Is there any limitation with headlight adjustability that this installation may limit?
Also, can I ask how tall you are? Just curious what the effect would be for a taller/shorter person. Yes, I know results will vary due to many variables but just curious.
10-03-2013, 11:36 PM
Likes Given: 752
Spaceman, will you measure how high the top edge of the screen is above the key slot please?
10-03-2013, 11:59 PM
Threads: 42
Ron, there is no adjustability issue at all. The headlight can rotate up or down without any interference from the screen. Right/left rotation is within the headlight shell, so obviously there's no interference there either. I'm either an inch or two inches under 6', depending on the phase of the Moon.
ferret, I held a ruler on the top of the screen parallel to the floor, then put the end of a tape measure on the ignition key slot. It was 8" from the slot to the ruler. Is that the measurement you were looking for?
10-04-2013, 12:12 AM
Likes Given: 752
Yep.. Wow 8" thats not much for doing such a good job. Now I have to go back and see where cip57 cut his down to see how high that was
Ok found it..when he cut his street shield down the first time he was at 12 1/4" above ign, then he cut 2 more inches off proclaiming it good, which would put it at 10 1/4 above the ign.
So it look like 8 to 10" above ign, should get the job done.
10-04-2013, 12:47 AM
  Dart flyscreen and a little Yoshimura stain magic 1985CB450_imp 19 1,709 10-24-2022, 04:12 AM
Last Post: 1985CB450_imp
  Corbin seat arrived and....... Ollie 9 743 07-22-2022, 01:03 AM
Last Post: Ollie
  Parcel arrived today Mixagon_imp 11 1,011 03-07-2021, 10:03 PM
  Dart Marlin Flyscreen - A Quick Review the_undecider_imp 70 5,690 12-10-2019, 02:16 PM
Last Post: jimgl3_imp
  Clip-ons and Flyscreen. kmoney_imp 17 1,195 11-14-2019, 08:14 PM
Last Post: Moe_rider_imp
  Dart flyscreen and MPG rickcb 3 359 06-24-2019, 08:05 PM
Last Post: Rocky_imp
  Dart Marlin Fly screen Ennsync_imp 19 1,256 12-26-2018, 02:51 AM
  Dart Screens For 2017 EX & RS 2017EX_imp 35 2,299 12-11-2018, 01:53 PM
  Dart Fly screen chandler_imp 6 446 11-03-2018, 11:22 AM
  Could someone help me with my Dart flyscreen, please! Olyrider 6 568 09-04-2018, 01:24 PM
Last Post: SportsterDoc
