Seat mod and Cockpit management
cbfan_imp Offline
Threads: 25
Didn't like the forward lean to the stock seat, so pulled the cover back and took carving knife to the foam and lowered it a bit, to go with lowered seat installed lowering blocks on the pegs (from Takashi). To the cockpit installed thermometer, digital voltmeter, TPMS, throttle lock, foam grips, palm rest and risers. I do believe she is ready to go.
11-14-2013, 09:46 AM
dBuster_imp Offline
Threads: 7
RE: Seat mod and Cockpit management
Can we get a closer photo of that cockpit of yours? Wanting to see how you have everything mounted up.
11-14-2013, 09:53 AM
cbfan_imp Offline
Threads: 25
Since I'm using 1.25 back risers there is a step, that is where I mounted thermometer and TPMS (made a bracket mounted with tape) using 3M two face tape. The TPMS cover is alittle cloudy, I screwed up and got wax on the back side of it. Forward of the TPMS is 12v accessory socket.
11-14-2013, 10:34 AM
HikerToo_imp Offline
Threads: 114
I just put my Comet fairing on this evening and really like the clean look compared to NC deflector hardware clogging up my cockpit view...although it does shake just a little in the wind.
11-14-2013, 10:37 AM
cbfan_imp Offline
Threads: 25
My fairing had a "buzz"/vibration at speed. I made a couple rubber spacers and installed between tach/speedo and fairing...............no more movement. They are small 'nough where you can hardly see them.
11-14-2013, 10:47 AM
Ole_imp Offline
Threads: 18
"lowering blocks on the pegs"
Tell us (or show us) more! Thanks
11-14-2013, 11:11 AM
cbfan_imp Offline
Threads: 25
From Samuride/Takashi, good product. You have to do some modifications for them to be in the lowest position.
11-14-2013, 11:27 AM
  improved seat and 3 cm higher SEAT. the best reform Alfgaxatico_imp 1 235 04-25-2021, 04:47 AM
