Question Re. Radiator Protectors
MrTim_imp Offline
Threads: 11
So I'm setting my CB up for some long distance riding and feel that a radiator protector may be a worthwhile investment. However I've seen a few people warning that radiator protectors can impede airflow and make the engine run hotter than it should.
Could anyone who's installed one be able to share their experience?
01-16-2014, 04:59 PM
Delphisa Offline
Near by Grenoble, France
Threads: 28
Likes Received: 48 in 7 posts
RE: Question Re. Radiator Protectors
I have not tested it, but I am interested in this item:
[url=http://www.rg-racing.com/browseBike/Honda/CB1100/2013/OCG0018BK.aspx]R&G Oil Cooler Guard for Honda CB1100
I would be very surprised if this could reduce airflow and impede engine heat dissipation. On my previous bike (Suzuki Bandit) there was such a guard from stock and never had problem.
01-17-2014, 05:40 AM
Website Find Reply
CB4ME_imp Offline
Threads: 183
And yet there's been much discussion on their possible adverse effects, although not on a CB1100. It would be interesting if someone had an oil temp guage on their bike and one of these.
01-17-2014, 09:35 AM
lola_imp Offline
Threads: 18
(01-16-2014, 04:59 PM)MrTim_imp Wrote: So I'm setting my CB up for some long distance riding and feel that a radiator protector may be a worthwhile investment. However I've seen a few people warning that radiator protectors can impede airflow and make the engine run hotter than it should.
Just my opinion and experience. I would definitely put one on youre oil cooler and I am pretty sure that you will not see any higher temperatures with the Oil cooler guard on it. I do not have it on my CB1100 yet but If I were to do long distance riding then It would be nice to have some added security from flying rocks.....
I do have a radiator guard on my other bike which is water cooled and I did not see any difference in temperatures when I did a test using a temperature guage. I did a test with and with out the Radiator Guard, Different days,same daily route, same outside temperature and there was no difference.
just my .02 cents
enjoy the tourBiker
01-17-2014, 10:21 AM
enzo_imp Offline
Threads: 10
I have some mozzy gauze on mine no problem
[attachment=944][attachment=943]I have fitted a piece of aluminium mozzy screen and have had no problems. These bikes have a oil temperature warning light. http://cb1100forum.com/forum/showthread.php?tid=1189
01-17-2014, 05:19 PM
The Spaceman_imp Offline
Threads: 42
What type of roads do you plan to ride on?
I ride on pavement only, and have never dinged a radiator or oil cooler in 40 years. But, if were planning a trip to Alaska or riding on lots of dirt or gravel roads, I'd consider a guard.
01-18-2014, 02:30 AM
MrTim_imp Offline
Threads: 11
(01-18-2014, 02:30 AM)The Spaceman_imp Wrote: What type of roads do you plan to ride on?
I'll be riding almost entirely on sealed roads, maybe a couple of sections of gravel but just about the entire thing sealed.
01-18-2014, 04:42 PM
Threads: 42
If you like the looks of the guard, go for it. But unless the roads in Oz are a lot different than here, I'd say the chances of your cooler/radiator getting holed on pavement are very slim.
01-19-2014, 01:32 AM
meowguy_imp Offline
Threads: 26
Quote:I'd say the chances of your cooler/radiator getting holed on pavement are very slim.
And any object that punctures your oil cooler is no doubt going to go right through your legs or blow out a knee. What type of a cover do you have for your legs?
01-19-2014, 09:30 PM
AzBob_imp Offline
Threads: 6
Guards such as these heavily impede airflow. If I recall, drag increases by the square of velocity. So, you're looking at some huge air impedance at 60mph. The oil cooler is up very high and unless you're riding off-road somewhere that your stock tires probably won't take you anyway, you're probably never going to have any kind of problem with rocks.
If you're curious, take the guard and have someone drive you at 60mph in a car, and stick it out the car window. That blast of air you're struggling to hold the thing up against is the force being impeded by the guard.
Bikes with guards from the factory have already had their math done and the radiator is larger than it would otherwise be without the guard.
01-20-2014, 09:28 AM
  Instrument panel protectors? LucienLeFranc 9 578 05-11-2026, 03:17 PM
  SW-MOTECH Crash Bars / Engine Protectors rdprdp01 1 386 04-12-2025, 08:57 AM
Last Post: 17-CB-002
  SW-MOTECH Crash Bars / Engine Protectors rdprdp01 11 1,120 11-03-2024, 05:24 AM
Last Post: WRXer_imp
  Fork Protectors, an alternative to Gaitors? Tev62 22 1,761 05-12-2021, 03:16 AM
  Fork Protectors apex1_imp 10 830 03-24-2021, 06:09 AM
  transparent tank protectors Enzofour_imp 2 439 03-03-2021, 09:35 PM
Last Post: Enzofour_imp
  Radiator Protectors michael1954 3 424 05-31-2020, 02:35 PM
Last Post: zirconxi_imp
  Anyone installed a radiator cover? bioman_imp 35 4,026 05-18-2020, 12:00 PM
Last Post: TXBikerGuy
  R&G Racing Supermoto Exhaust Protectors apex1_imp 3 414 06-25-2018, 01:22 AM
Last Post: aschem_imp
