Pyramid fenda extenda now available here in the states
petec_imp Offline
Threads: 9
They haven't hit Twisted Throttle yet but I ordered one from Streetfighters today.
http://shop.fendaextenda.com/category.sc?categoryId=2
I usually end up with one on all my bikes, keeps a lot of crud off the motor, pipes, etc... Nice add-on for not much money and shipping was only 9 bucks.
Pete C
07-27-2013, 10:01 AM
wildezt_imp Offline
Threads: 9
RE: Pyramid fenda extenda now available here in the states
Thanks Pete, I was looking for something like this...handy piece it is for sure..
07-27-2013, 10:32 AM
Lord Popgun Offline
El Supremo RLET Force
Virginia
Likes Given: 142
Yeah, I posted about this a short while back. I have mine installed right now!! Smile
07-29-2013, 12:23 AM
CB4ME_imp Offline
Threads: 183
Popgun,
What did you sure to install yours? Mine is supposed to come in today. I have some "super" epoxy I was going to try. Looked at 3M 5200 marine adhesive, but the box didn't list metal or plastic as a suitable surface.
07-29-2013, 01:14 AM
Lord Popgun Offline
Virginia
Likes Given: 142
On one of the sites, Pyramid in the UK, or the fenda extenda site here, it says this is a adhesive attached part due to the design of the fender.
However, it comes with 4 push type plasitc pop rivits. I did not use those.
The Extenda also has double stick foam tape to hold it in place while drilling holes or glueing.
I would strongly suggest that you remove the fender. It is easy. 2 screws and the brake lines are off, then 4 screws and the fender comes right off.
Then fit the part a number of times until you like the way it fits and looks. Do not peel the tape off yet.
Clean the fender mating surface. I cleaned the plastic with MEK, which is too strong(will melt the plastic), but took the shiny off and mold release, etc. Yeah I was anal. I then took a sharp nail and scratched up the mating surface pretty good to give a better bite for the adhesive.
I used 3M 5200 fast cure. 3m's site says to test on plastics first for suitability, but remember, boats are made of plastic. Fiberglass is known as FRP-Fiberglass re-inforced plastic, or GRP, Glass re-inforced plastic. I know there are different kinds of plastic...
Anyway, after fitting it the way I liked, I peeled off the tape and put a lot of 5200 on the mating surfaces and put it in place. I did use some small clamps to hold it, but the tape did all the work as it turned out.
Notice that when fitting, the extenda will pivot at the tape. Make sure you have it aligned the way you want so it looks like an extension of the fender, following its curve, and isn't pointing at the tire. That left a gap at the front of the mating surface under the fender (the edge farthest from the bottom edge of the fender). I filled that in with the 5200. I have pictures, but as yet still cannot post them. I will send them to you if you want, PM me an email address.
You might want to remove the sticky tape, but that looked like too much work. Also, at first I tried to install the extenda with the fender on the bike. AND, ended up having to remove it with the extenda glued up...
If you leave the tape on, you must use enough adhesive to be above the tape and, enough to fill in the gap at the top of the mating surface if you have one. Use too much and you may have a mess. I actually managed to use just about the right amount, and only have to "caulk" at the gap and around the edges. I had no mess. For once.
After the adhesive sets, re-install the fender, paying attention to the weird little brake line fittings, and you are done--Almost!! Now, re-polish your fender to get your finger prints off of it!! Smile
Having said all that, it was easy, and it is not coming off.
07-29-2013, 08:20 AM
CB4ME_imp Offline
Threads: 183
Popgun,
Thanks for the detailed instructions. I'm going to try to find 3M 5200 quick cure today. Home Deport had the regular cure and I don't want to wait a week.
Update: picked up the eliminator from the woods at the end of my driveway. UPS considers this my "front door" which is actually 200 yards away. I guess they don't have a code for "good luck finding that little box hidded in the ferns at the end of your driveway".
No rivits and no tape were included, just the plastic extenda. No instuctions were included either, but I have your detailed how-to. Again no problem. This piece of plastic is going to help protect the bike. I do a minium of 2 miles on gravel every time I ride.
07-29-2013, 08:55 PM
Lord Popgun Offline
Virginia
Likes Given: 142
Disclamer: I'm not saying that 5200 is the only adhesive that should be used, just that it works and IS some good stuff easily available for consumer use.
I got my fast cure at Home Depot, was around $8. A store like West Marine will charge maybe $12-14.
The quick cure will tack up within the 2 hours or so. After 24 it was most likely good to go. After 36 I'm pretty sure it was mostly done, but I don't have X-Ray vision. Since it rained, I just ended up waiting the 48 hours.
If you have never used this stuff, do not get it on your clothes. It will not come out. I wore vinyl gloves as it is nasty to get off your hands. Think acetone.
After you get the extenda bonded on, avoid touching the 5200 to see if it is curing. It will stick to your finger and pull a string out. You can wet, or lick, your finger and smooth it out around the edges if desired, but I didn't need to. You can put a dollop of it on something and test that. Thin amounts cure faster than thick amounts. And the edges will set up faster than the rest.
I would try to avoid having it ooze out of where the extenda and the fender meet on the outside of the fender. If you use white (I did) it will look bad and be hard to clean off the extenda. Do so before it cures.
I am not an expert on 5200, I just own a boat...and have used a lot of it.
07-29-2013, 11:00 PM
Huladog_imp Offline
Threads: 23
Do you guys think silicone sealant or a construction adhesive like Liquid Nails would do the job?
Both of those things stick to practically anything, remain slightly flexible when cured completely (so it won't crack when dried), thick enough to fill any gaps, etc.? Easier to find in your neighborhood hardware store.
On previous bikes I've used 3M automotive trim adhesive tape to mount my Fenda Extendas but those were plastic fenders.
Aloha,
Huladog
08-01-2013, 06:54 AM
rboe Offline
Phoenix, AZ
Threads: 64
Likes Received: 6 in 2 posts
Likes Given: 7
I have my doubts about liquid nails. I'd rather use the 3M adhesive but silicone caulk may work. I suspect over time it would delaminate.
08-01-2013, 07:39 AM
Lord Popgun Offline
Virginia
Likes Given: 142
I don't know about liquid nails either. As far as silicone, well, my experience with it is around boats. Silicone will not hold a bond on fiberglass, or gel coat, for very long. I didn't trust it to hold a bond on the Extenda or the fender.
I think a polysulfide or polyurathane is better and used 5200 (polyurathane). I wouldn't doubt there are better comercial adhesives, but I don't know what.
What we need is an adhesive expert on the board!
08-01-2013, 10:57 PM
  Installed Fender Extender (Fenda Extenda) venturer434_imp 3 337 03-25-2017, 09:02 PM
  Fenda Extenda ? bflint 6 452 07-14-2016, 04:20 AM
Last Post: bflint
  Fenda Extenda INTP_imp 5 370 03-13-2015, 03:49 AM
Last Post: Rocky_imp
  Fenda Extenda Lord Popgun 14 897 07-17-2013, 09:25 AM
