Aluminum Swingarm
xpacpal1x_imp Offline
Threads: 4
Aluminum Swingarm
Honda website says the 2014 CB1100 is equipped with an aluminum swingarm.
Questions:
1) Can anyone confirm that 2013 models have aluminum swingarms?
2) Samurider carries aluminum swingarms mfg. by OVER Racing...it advertises a 50% weight savings from stock. How can this be if both are aluminum? Is the Over Racing hollow and the stock a solid block of aluminum?
3) How many pounds of weight savings is 50% of the stock arm and how significant is that weight, given that its "sprung" weight (is that the correct term).
I am new to motorcycling...simply interested in the variables surrounding this component and not likely to swap into this aftermarket item. Any educated commentary greatly appreciated.
05-05-2014, 10:26 PM
Likes Received: 618 in 276 posts
Likes Given: 789
RE: Aluminum Swingarm
Hmm thought I had seen your name registered before?
Anyhow, a magnet sticks to my 14 dlx swingarm, so it is steel
05-05-2014, 10:46 PM
Ack-CB11_imp Offline
Threads: 46
OE's are heavy heavy steel. The Over arm are very light and improved my ride and handling a great deal. 10.6lbs vs 23.8lbs Over's are hollow.
Thread: http://cb1100forum.com/forum/showthread.php?tid=1267
I've knocked over 50lbs from my bike. It's a real improvement
05-05-2014, 11:21 PM
Threads: 4
(05-05-2014, 10:46 PM)The ferret_imp Wrote: Hmm thought I had seen your name registered before?
Copy paste from Honda website: "Aluminum Swingarm - Combined with the CB1100’s steel-tube full-cradle twin-loop frame, the stout aluminum swingarm is part of the CB1100’s excellent handling package."
Have I misapplied the term "swingarm"...is Honda referring to the passenger footpeg mount, or the frame that holds the rear axle?
05-05-2014, 11:44 PM
Lord Popgun Offline
El Supremo RLET Force
Virginia
Likes Given: 142
It is interesting that on the Honda powersports site it does say that the '14 has an aluminum swingarm. If you switch to the '13 is says steel swingarm.
So, do you 2014 guys have an aluminum swingarm?
05-06-2014, 12:49 AM
Likes Given: 789
(05-06-2014, 12:49 AM)Lord Popgun_imp Wrote: It is interesting that on the Honda powersports site it does say that the '14 has an aluminum swingarm. If you switch to the '13 is says steel swingarm.
see post 2
05-06-2014, 12:51 AM
Lord Popgun Offline
Virginia
Likes Given: 142
Sorry Mickey,
For some reason I though Acq wrote that.
Xpac--That was a good question, but keep in mind that marketing people run those sites and they don't always get things right for a number of reasons. Thats what I like about forums like this. Hive knowledge and all right here!
05-06-2014, 12:56 AM
Likes Given: 789
Hive knowledge .. I like that term
05-06-2014, 01:01 AM
  MOTHERS/MAG AND ALUMINUM POLISH. wildezt_imp 35 2,011 05-26-2019, 11:27 PM
Last Post: CB1100-King_imp
  Need help sourcing racks for Aluminum Panniers Frulk_imp 15 1,018 03-06-2019, 08:22 AM
  Single Sided Swingarm Cafe Project_imp 46 2,626 01-04-2019, 09:54 AM
  Aluminum Top Box for camping off bike Frulk_imp 11 853 08-29-2018, 07:26 AM
Last Post: DBM_imp
  Aluminum Top Box by Happy Trails Frulk_imp 8 623 08-25-2018, 12:36 PM
  CB1300 Aluminum three-point type of security rod, fitted 2014CB1100 Good protection jp4141432_imp 2 469 09-26-2016, 08:56 PM
Last Post: jp4141432_imp
  Aluminum Bikini Cowl and Seat Trunk bix_imp 48 2,612 06-11-2015, 12:13 PM
Last Post: Motogeezer1949_imp
  Aluminum sprocket cover ('13) fit? (Samurider) Papa Weeley_imp 16 1,123 04-13-2015, 08:56 AM
Last Post: Papa Weeley_imp
  WM Aluminum Cowl CB4ME_imp 36 2,127 03-25-2015, 07:43 AM
  OVER swingarm HaGut_imp 11 878 02-18-2015, 10:57 AM
Last Post: Elipten_imp
