Fork Boots aka Gaiters
Likes Given: 753
Finally found some time and managed to put some Kaw W650 gaiters on the front of my CB. Took about an hour as reported.
Before
[url=http://smg.photobucket.com/user/theferret111/media/forkboots001_zps606cf935.jpg.html][Image: c527cd5dc5dc09e859024d73b19c2f68.jpg]
After
[url=http://smg.photobucket.com/user/theferret111/media/forkboots021_zps1f4986b2.jpg.html][Image: a7eedf11fc0dfc7fcaf1129dcb8630fe.jpg]
[url=http://smg.photobucket.com/user/theferret111/media/forkboots038_zps8ed78d32.jpg.html][Image: 7e59a890eb38c5fcab0e65da8627610d.jpg]
06-17-2014, 06:10 AM
B166er_imp Offline
Threads: 15
RE: Fork Boots aka Gaiters
Love.... want...
Sent from my SM-N900P using Tapatalk
06-17-2014, 06:27 AM
Rocky_imp Offline
Threads: 26
WOW, they look great Thumbs Up Thumbs Up
Only an hour to dis-assemble and assemble the front end! That's very good time. I'm impressed!
How did you support the bike with the wheel and fork leg off?
06-17-2014, 06:42 AM
Likes Given: 753
Rocky, bike was on ceneterstand then took off the seat and used tie downs at the rear around under the work bench holding the back end down (and therefore front end up), but it could have been done with a board and jack under the motor.
06-17-2014, 06:44 AM
Elipten_imp Offline
Threads: 13
Did you remove brakes, then wheel, then each fork tube? Or did you remove brakes , and then pull fork tubes with wheel as one assembly?
Any detailed instructions how to?
06-17-2014, 07:40 AM
Likes Given: 753
Elipten I took a few pics along the way and will try and put something together, but yes had to loosen front axle pinch bolts, remove front axle nut, remove front axle, remove front wheel, slide off both brake calipers, remove both hydraulic hose stays, remove abs contact, remove front fender, then remove each fork leg one at a time and install gaiter. Then reinstall 1 fork leg, and then do other fork leg, then reassemble. Wasn't difficult, hardest part was removing and reinstalling the abs sensor since I have never messed with one before, and din't pay enough attention to order of removing the sensor wire. Had to re-remove front wheel during reassembly because sensor wire had to be installed before wheel could be installed and I didn't realize that.
06-17-2014, 07:50 AM
CB4ME_imp Offline
Threads: 183
Very nice. Looking forward to the thread in the "How To" section.
06-17-2014, 08:10 AM
Rocky_imp Offline
Threads: 26
(06-17-2014, 07:50 AM)The ferret_imp Wrote: Elipten I took a few pics along the way and will try and put something together, but yes had to loosen front axle pinch bolts, remove front axle nut, remove front axle, remove front wheel, slide off both brake calipers, remove both hydraulic hose stays, remove abs contact, remove front fender, then remove each fork leg one at a time and install gaiter. Then reinstall 1 fork leg, and then do other fork leg, then reassemble. Wasn't difficult, hardest part was removing and reinstalling the abs sensor since I have never messed with one before, and din't pay enough attention to order of removing the sensor wire. Had to re-remove front wheel during reassembly because sensor wire had to be installed before wheel could be installed and I didn't realize that.
I put gaiters on my Triumph T100 last winter and that's pretty much the routine - except for the ABS.
I really like the look and next winter during our nearly six month winter layup, I may do the CB too.
06-17-2014, 07:37 PM
redbirds_imp Offline
Threads: 186
Looks good Mickey. Better protection for the fork seals also. Gaiters should be standard equipment.
06-17-2014, 09:33 PM
Rick Froscheiser_imp Offline
Threads: 5
Looking good Ferret! Glad you finally slowed down long enough to install the gaiters.
Ride safe my friend
06-17-2014, 09:54 PM
  Fork Gaiters and Heated Grips tdbru 20 2,925 05-02-2025, 11:16 PM
  Fork Gaiters - buyer beware 12cb96vfr_imp 53 3,269 04-13-2025, 05:04 AM
Last Post: balkanhound_imp
  The GOAT of Short Motorcycle Boots: indie Ridge rdprdp01 13 1,305 01-08-2025, 08:36 AM
  Boots, Pants, and Airbag Vest rdprdp01 4 490 11-21-2024, 02:45 PM
Last Post: rdprdp01
  Fork Gaiters Gone in 60 15 1,223 02-13-2021, 05:12 AM
  sniff my boots Chuckk_imp 20 956 04-06-2020, 05:39 AM
Last Post: IndianRider_imp
  OEM Honda Fork Boots 2017EX_imp 28 1,684 08-03-2019, 03:23 AM
Last Post: motoRAT_imp
  Fairing and Fork Boots garysieben_imp 21 1,557 03-24-2019, 12:49 PM
  Alternative Fork boots (not the kawa boots) misterprofessionality 11 1,013 06-01-2018, 05:39 AM
Last Post: Rocky_imp
  New Triumph fork boots Mscb1100_imp 11 798 12-25-2017, 02:21 AM
