Exhaust mods?
mgoodie_imp Offline
Threads: 6
Exhaust mods?
Has anyone done/heard of modding stock exhaust on these to make it louder or deeper? Just wondering if baffles can be removed or holes drilled in them. Ive modded other exhaust systems in a similar fashion and had good luck with sound and performance.
09-17-2014, 07:13 AM
Pterodactyl_imp Offline
Threads: 75
RE: Exhaust mods?
It has been the subject of a post(s) on the forum I'm sure. I think most go with slip-ons.
09-17-2014, 09:22 AM
mgoodie_imp Offline
Threads: 6
RE: Exhaust mods?
Thats what I figured
Thanks!
09-18-2014, 12:18 AM
grover_imp Offline
Threads: 6
Exhaust mods?
There's a gent, kdiqq, that has removed the catalytic converter from his stock exhaust and welded it back up quite cleanly. It should make the exhaust sound a bit deeper and free up some additional power.
I think he's gauging interest from forum members on this mod in the classifieds section.
09-18-2014, 12:32 AM
mininsx_imp Offline
Threads: 11
RE: Exhaust mods?
If you take a flashlight and look inside the muffler outlet you'll see a baffle way down in there. I drilled some holes in mine to see if it made a difference and guess what? It didn't. Undecided
09-18-2014, 12:47 AM
mgoodie_imp Offline
Threads: 6
RE: Exhaust mods?
I had a Harley as my last bike and I cut the whole baffle out and made a big difference as you would expect. I was more just wondering if I could do the same on the cb. But if I did I imagine i would need to make changes to the computer to adjust the amount of fuel/air etc...
09-18-2014, 01:11 AM
kDiqq_imp Offline
Threads: 11
Re: RE: Exhaust mods?
(09-18-2014, 01:11 AM)mgoodie_imp Wrote: I had a Harley as my last bike and I cut the whole baffle out and made a big difference as you would expect. I was more just wondering if I could do the same on the cb. But if I did I imagine i would need to make changes to the computer to adjust the amount of fuel/air etc...
The computer compensates a surprising amount on this bike! That being said, a totally stock bike can benefit from a tune... If you were going to modify the stock muffler, I wouldn't say it's a bad idea to remove the cap, cut end off, remove guts, bland place cap back on. It'd look mostly stock. Worth a shot if you're consider a slip on anyways. Just a lot of cutting to do..
09-18-2014, 01:17 AM
Stealth128_imp Offline
Threads: 19
RE: Exhaust mods?
Confused
(09-17-2014, 07:13 AM)mgoodie_imp Wrote: Has anyone done/heard of modding stock exhaust on these to make it louder or deeper? Just wondering if baffles can be removed or holes drilled in them. Ive modded other exhaust systems in a similar fashion and had good luck with sound and performance.
It sounds awful kinda like a tin can. If your in that direction pull your can have a muffler shop add a flared extension pipe. That souds better then hacking you can.
09-18-2014, 12:50 PM
Threads: 19
RE: Exhaust mods?
Confused
Confused
(09-18-2014, 12:50 PM)Stealth128_imp Wrote: Confused
It sounds awful kinda like a tin can. If your in that direction pull your can have a muffler shop add a flared extension pipe. That sounds better then hacking you your can and you can reverse it.
mgoodie_imp Offline
Threads: 6
RE: Exhaust mods?
I wondered about that. Thanks for all the input I think I just save my pennies and get a slip on sometime.
09-19-2014, 12:26 AM
  Gauge Mods Seancampbell777_imp 11 1,012 10-16-2024, 04:14 AM
  Short mods list and experience with each for those considering. Motomike7_imp 6 565 04-07-2023, 11:34 PM
Last Post: 1973cb750
  2 small mods until the weather changes inditx_imp 10 920 01-02-2023, 10:31 AM
Last Post: inditx_imp
  Mods to OEM seats? 2014ltdltz 7 682 07-05-2022, 05:56 AM
  Best suspension mods? gretle_2.0 6 542 05-10-2022, 06:25 AM
  Winter Mods finished, time to ride! Phadreus_imp 3 471 05-02-2022, 10:08 PM
Last Post: Phadreus_imp
  Whitehouse K17 mods... Bazbro_imp 390 22,238 04-30-2022, 12:50 PM
Last Post: Bazbro_imp
  Mods Mods Mods Latinrudeboi13_imp 12 953 08-23-2021, 01:11 PM
Last Post: Rox_imp
  Mr.P's CB mods, mark II misterprofessionality 18 1,320 05-21-2020, 06:45 PM
  New Mods 89gaz89_imp 1 288 05-15-2020, 08:08 AM
