CHROME REAR CARRIER
holy666diver_imp Offline
Threads: 37
CHROME REAR CARRIER
I just ordered a new CHROME REAR CARRIER off bike bandit for the 2014 CB1100. Any tips on installation? I couldn't find any instructions online.
10-29-2014, 01:55 AM
ClassicVW_imp Offline
Threads: 6
RE: CHROME REAR CARRIER
(10-29-2014, 01:55 AM)holy666diver_imp Wrote: I just ordered a new CHROME REAR CARRIER off bike bandit for the 2014 CB1100. Any tips on installation? I couldn't find any instructions online.
The one I got from Webike came with a couple of spacers and longer bolts, and illustrated instructions with the text in Japanese. If yours comes the same way, or even with no instructions, you should be able to figure what goes where. Just be aware that you will probably need to grow longer fingers and a third hand. You'll see what I mean....Confused
10-29-2014, 03:02 AM
Lord Popgun Offline
El Supremo RLET Force
Virginia
Likes Given: 136
This Honda site has instructions for mounting the Honda rack on a '14.
http://cssportal.css-club.net/honda/MCA/TERMS010.aspx
Note: I didn't read them, I just checked to make sure they are there.
10-29-2014, 03:59 AM
Threads: 37
Do you install one side at a time?
10-29-2014, 05:21 AM
Houtman_imp Offline
Threads: 115
Get the instructions in English as per post from Popgun, that will help a lot. It is not difficult at all once you can read the instructions in ENGLISH !!!
10-29-2014, 06:48 AM
Threads: 6
Tongue
(10-29-2014, 05:21 AM)holy666diver_imp Wrote: Do you install one side at a time?
You remove the side bolts that need to be removed. Then you place the rack where it belongs and just install the two front bolts one side at a time, and then do the two rear. Keep everything loose until all the bolts are in place, then tighten everything.
The hardest part will be to get the bolts to start grabbing the nuts on the inside of the frame. If you have a rubber mat, a piece of carpet, or even cardboard that you can position under the bike, all the better. You WILL drop a nut or two during the install, and it's better that you have a softish floor surface so they don't bounce and roll far away. And don't do the install at dusk or you'll need a flashlight to find the lost nuts. DAMHIK. Confused
Don't sweat it and wait for it to arrive. You'll see what needs to be done.
10-29-2014, 07:20 AM
Pterodactyl_imp Offline
Threads: 75
I put up a post with some pics for installation of a '10/'13 rack. If they are similar then it will help. My first attempt to install took me some time. I now get the rack off, or on, in less than 5 minutes.
10-29-2014, 07:22 AM
cbfan_imp Offline
Threads: 25
I'm thinking about a rear carrier, which is the best bang for the bucks?
10-29-2014, 07:49 AM
Houtman_imp Offline
Threads: 115
Use painters tape to keep your nuts (....) on the wrench and than it is very easy to get bolts started.
10-29-2014, 07:52 AM
Threads: 37
Well I ordered from bikebandit.com for $230! Awesome deal! BUT!! The rear carrier didn't come with INSTRUCTIONS!!!! Well I used Pterodactyl's post he made about installing as reference and it was pretty straight forward. Dang some of the spaces are tight!! But took about 30 mins and I got it all installed Smile Now I can carry my stuff without a darn backpack! Very happy haha
[Image: 5cbf6749d68db585a33f08a4d84d35a6.jpg]
Oh someone who has instructions help me out I torqued the bolts to this:
Front bolts: 30 ft. lbf-ft
Back bolts with nuts: 19 bf-ft
I saw thats what the deluxe instructions said but couldn't find anything for the standard 08L70-MGC-A20
10-29-2014, 11:13 AM
  Anyone recommend s a top case for the 13' OEM rear Carrier? iamlegend21087_imp 14 1,137 06-21-2023, 08:51 PM
Last Post: Tbhart89_imp
  Exhaust coating Jet-Hot Chrome finish Brady Bourgeois_imp 12 995 08-04-2020, 03:42 AM
  HELP! OEM Top Box/ wrong rear Carrier? 13' CB iamlegend21087_imp 4 475 05-12-2020, 09:16 PM
  Honda carrier the lodger_imp 21 1,270 04-27-2019, 05:25 PM
Last Post: DBM_imp
  ‘17 chrome headlight bucket on my ‘14 PowerDubs_imp 18 1,147 08-19-2018, 12:50 AM
  Powder Coating Chrome Fenders riggies_imp 18 1,393 07-13-2018, 02:26 PM
Last Post: riggies_imp
  Chrome/Stainless bar ends Chris Goldson_imp 10 624 11-19-2017, 04:56 AM
Last Post: 2017EX_imp
  Rectangular Chrome Mirrors for CB1100? 17-CB-002 12 916 08-23-2017, 04:31 AM
  2017 Chrome Gauge Covers on a 2014 suhawk305 12 800 08-01-2017, 12:27 PM
Last Post: run-tmc_imp
   Chrome Engine Cases Anyone? aschem_imp 2 368 01-11-2017, 07:34 AM
Last Post: aschem_imp
