The Finished Chip Beck Spec CB1100-PHOTOS
Jteakus_imp Offline
New to the Forum
Threads: 0
RE: The Finished Chip Beck Spec CB1100-PHOTOS
#81
Nice ride. Curious if you gutted the head pipe before the jet coat or left the catalyst intact?
09-26-2016, 10:33 AM
feralchimp_imp Offline
Threads: 2
#82
Thanks for the reply on the shocks (and previous asker's question on the tail light...looks super clean!)
09-28-2016, 05:45 AM
ChipBeck_imp Offline
Threads: 29
#83
(09-26-2016, 10:33 AM)Jteakus_imp Wrote: Nice ride. Curious if you gutted the head pipe before the jet coat or left the catalyst intact?
Although I have a perfect stock header with the cat removed I chose to coat my original header with the cat. My bike ran really well with the Power Commander 5 and I didn't want to risk screwing it up by lowering the back pressure with no cat. The header had rubber stoppers in all openings when it was coated and polished so the cat was not compromised. The inside of my header is not coated. Cheers bro.
Chip
09-28-2016, 08:35 AM
PowerDubs_imp Offline
Threads: 125
#84
There is no such thing as good back pressure. That is a never dying fallacy. An engine is an air pump. Anything that makes it less efficient is bad.
The important tuning part is exhaust pulses, and there are many variables to that- pipe diameter, length, transitions, bends, collectors, cats, etc.
Once the cat is removed, you may need to tweak the tune a bit, but the end result would be more power and better gas mileage. Along with a little less weight, a little less heat, a little more sound. Possibly not the sound you want. On cars pulling cats can make it 'raspy' if no resonators are in the system.
09-28-2016, 09:37 AM
cooldrum_imp Offline
Threads: 0
#85
Very nice mods and touches to your bike! The CB in stock form is an artful design. You took it to even a higher level! I found my CB in Scottsdale and drove it home to Pdx. I should have stopped by for a visit! Russ
10-01-2016, 01:09 AM
Threads: 29
#86
(09-28-2016, 09:37 AM)PowerDubs_imp Wrote: There is no such thing as good back pressure. That is a never dying fallacy. An engine is an air pump. Anything that makes it less efficient is bad.
Power,
In a 4-stroke engine I agree IF.....as you say, I were to "tweak the tune a bit" to increase fuel to compensate for the increase in air flow to keep the air/fuel ratio near 14.7 to 1. And as I said in my post my bike ran great from idle to red line as it was. Without the cat it would have been a bit lean which would have required a tune adjustment and I don't have the tools or expertise to accomplish that. If I did then my CB11 would have made a bit more power assuming I got it right. Without changing my tune if cat removal improved airflow enough to take my air/fuel ratio from 14.7 to 1 to 16 to 1 then the result would be less power and rougher operation.
So I decided to stay with the cat and my existing tune which my spark plugs indicate is pretty much spot on for my current setup. Cheers.
Chip
10-03-2016, 04:59 AM
  finished "forward controls" today Griz53_imp 12 916 10-02-2022, 10:44 PM
  Winter Mods finished, time to ride! Phadreus_imp 3 474 05-02-2022, 10:08 PM
Last Post: Phadreus_imp
  Tech Spec Tank Pads 2017EX_imp 3 368 08-06-2020, 06:10 AM
  Chip Beck Spec Low Handlebar/Mirrors Mod. ChipBeck_imp 112 8,055 09-18-2019, 12:00 PM
  Chip Beck Corbin Seat owners iamlegend21087_imp 6 514 08-29-2018, 07:12 AM
Last Post: bflint
  Pair valve delete...i need photos -_- JohnHighlander_imp 2 282 05-30-2018, 05:21 AM
Last Post: Ferrealls_imp
  It's Finished! (mostly) Banned_imp 7 652 05-25-2018, 10:44 PM
  Top triple clamp torque spec run-tmc_imp 5 466 06-01-2017, 09:15 PM
  Ryujin Fender Eliminator kit Video & Photos lola_imp 27 1,657 02-05-2016, 05:56 AM
  ASWR Spec Chic Design Sport Trunk Seat Chapomis_imp 22 1,513 12-16-2015, 10:14 AM
Last Post: Riko_imp
