Threads: 11
(12-17-2014, 07:45 AM)Ack-CB11_imp Wrote: The JASO MA2 oil has less ZDDP in it for catalytic converter safety compared to the MA rated oil.
After trying multiple brands and weights, I ended up with Redline 10w30. It's JASO MA because of the extra high levels of ZDDP. Never got that cold knocking with it either.
Actually, JASO MA, MA2, and MB ratings *mostly* describe clutch performance (has to do with clutch friction ratings) and any JASO rating does not guarantee any content of ZDDP. But! Redline is a PROVEN oil and does very well on UOAs.
(12-17-2014, 08:09 AM)NightRider_imp Wrote: Quote:Since Honda produces the oil in house, ...
I did not know that. I thought maybe they bought it from some oil company and branded it.
So, if they don't just buy it and feel the need to make it then I guess it is special. Like my CB1100. Special oil. Special bike. I like that. I'll keep both.
So, if they don't just buy it and feel the need to make it then I guess it is special. Like my CB1100. Special oil. Special bike. I like that. I'll keep both. (12-17-2014, 09:19 AM)ClassicVW_imp Wrote: If they do make it, then that's the definitive reason to use it.
They can formulate it and tweak it to whatever is best for their engines.
Nothing as far as oil brands go is definitive  the reason Honda decided to produce their own oil in house is unknown. My speculation was listed above. It's *far* more profitable to to make sure every component comes out of Honda than to try and contract it out. That's undisputed. Does Honda go through the effort of tweaking their formulation for their engines? Maybe, I have no idea at all. I'm guessing no. Honda does not use any unique materials or unique tolerances that can be addressed by an oil. A good example is how Honda discussed the materials used in the CB1100 are different than that in any of their other engines due to its unique design.
Again, everyone here obviously cares a lot about their bike and it shows in regular maintenance. Keep it up and, again, everyone is right
Remember how I said I can be wrong?
I did some more research and it looks like, though Honda does not contract another oil manufacturer to sell their oils (like some 'OEM' oils do), they DO just buy their oil from different companies and brand it Honda. In America, it's an Exxon-Mobil blend (which means their synthetics are PROBABLY a class 3 oil, not true synthetic) and in Canada its PetroCanada. I didn't research the other countries  Now, as far as the formulation goes, Honda either contracts a chemist/company, uses in-house employees, bought a formula(s), or has tells the providers to give them a blend with certain compliances. Personally, I will never know this. Hopefully this sheds some light though!
Just an FYI!
Threads: 347
Likes Received: 839 in 462 posts
Likes Given: 973
kDiqq, from someone not terribly excited by oil threads, thanks for this really interesting information. To add a little bit, I'm pretty sure the local Honda dealer in Australia does not use Honda oils. Having bee lectured by a bloke in the service department of another Honda about the evils of mixing different brands of oil,I rang to find out what they'd used and it certainly wasn't Honda oil.
On that question, do you know of any scientific/ engineering reason not to mix brands of oils if, for example you just need a top up?
Threads: 11
Yes!!! If you run, for example, Mobil 1 10w40 synthetic in your bike and you need to top up, your first choice should be the exact same thing. If its not available, get Mobil 1 20w50 synthetic. If you can't find that, get a non-synthetic of the same brand/weight. Once you've exhausted all the oils of the same brand, then go to another brand and change ASAP. Mixing weights isn't a big deal to get you home because they will mix and 'average'.
Mixing brands is bad because different companies use different additives and you can't know how they are going to react. Most of the time, its probably okay. But its not worth risking any negative chemical reaction once all the additives and detergents get warm and begin breaking down as they are designed to do.
This is based off what I found on the bobistheoilguy forum  those folks are crazy knowledgeable.
Threads: 347
Likes Given: 973
Threads: 9
Somebody just mentioned Honda does not make it in-house but...wattaminute. Just a sec. Hold on there. If it is formulated to their specifications by an oil company then they "make it" just as if it were in-house.
There you go.  This was easy and pretty clear cut.  Now, on to something harder? Like, when to use stabilizer in your fuel and what kind is best? Speaking of fuel, ethanol? Does it hurt and since Honda does not make the gas, is it better to use non-ethanol or does ethanol actually help keep things running smoother?
My applogies for spinning this yet another oil thread to other liquids, but sheesh, nine pages about oil? Must be a hobby for some of us!
Threads: 6
I never worried about mixing different brands of oil or different weights as long as the weights were very close. And the two letter service grade was the same or also close. Like in 10W-30 and 10W-40. I generally follow the rule that "Oil is good. No oil is bad." Never had any issue with any vehicle that I owned.
The above experience applies in the past to my older cars. Even my present day cars with 130,000 or so on the ODO don't burn any oil. ( My family drives four Toyotas. Three of them have between 120,000 and 135,000 miles on them )
Most of us seem to change our oil in our bikes at between 2K - 4K miles. If you are regularly faced with adding a quart or a half quart of oil to your motorcycle, then I'd say you have a problem somewhere. Unless said motorcycle has very high mileage.
Threads: 11
(12-17-2014, 04:27 PM)NightRider_imp Wrote: (12-17-2014, 09:19 AM)ClassicVW_imp Wrote: If they do make it, then that's the definitive reason to use it.
Well, it may or may NOT be formulated to their specifications.. If could be formulated in house and manufactured my EM, PC, etc. Or they could just receive orders for an API xx oil and buy what they are selling. Honda knows and, I'm certain, plays that strategy close to their chest.
I never researched a bunch on fuel stabilizers. For our boats, we have always used Sta-bil for winter storage and it worked perfectly. I've never put an additive with every fill up. Dyno tests showed they are useless with regular use (especially octane boosters) as far as power goes. But I've had very good luck in using Seafoam every 30k miles in my cars through the intake.
Ethanol in fuel is a big deal though. In my carb bikes and boats, we have seen E15 could RAPID degradation of floats and damage to other small plastic parts. There is a product, that I have never tried, that claims to 'remove' ethanol from fuel just by adding it to your tank. People who have carb'd hot rods have run the stuff with good results, but I've never used it. E10 seems to be a bit nicer than E15 but pure gas is your best bet. Most EFI motors are built to handle the stuff just fine but over the life of a vehicle, I hear ethanol will break down seals somewhat quicker than pure gas. I will never own a vehicle long enough to see that.
If you have the choice though and it's convenient, no reason not to get pure gas. Check if you have a station near you at http://pure-gas.org/
(12-17-2014, 11:32 PM)ClassicVW_imp Wrote: I never worried about mixing different brands of oil or different weights as long as the weights were very close. And the two letter service grade was the same or also close. Like in 10W-30 and 10W-40. I generally follow the rule that "Oil is good. No oil is bad." Never had any issue with any vehicle that I owned.
Agreed, burning oil is always an indicator of a bigger problem... Like owning a non-Japanese bike  I know, I'm too funny.
The API designation does not always guarantee the presence, or lack thereof, of detergents, chemicals, or additives. No real way to find that out actually  That's how companies say their oil is 'better' than another...
Threads: 17
(12-17-2014, 12:45 PM)kDiqq_imp Wrote: Yes!!! If you run, for example, Mobil 1 10w40 synthetic in your bike and you need to top up, your first choice should be the exact same thing. If its not available, get Mobil 1 20w50 synthetic. If you can't find that, get a non-synthetic of the same brand/weight. Once you've exhausted all the oils of the same brand, then go to another brand and change ASAP. Mixing weights isn't a big deal to get you home because they will mix and 'average'.
I understand your arguments, and agree that it would probably be best not to mix brands or types purely on the basis of chemical compatibility.
However, has anyone ever seen a single piece of documentation that shows any adverse affects from mixing brands or mixing synthetic with dino oil?
As long as you change your oil and filter regularly and stay within the engine manufacturer's specified rating and viscosity, I think that the worst thing anyone has to worry about is winding up with a strange shade of oil, like when you mix Royal Purple with Golden Spectro
Threads: 66
Threads: 17
(12-18-2014, 05:33 AM)Motogeezer1949_imp Wrote: Have fun: http://www.amsoil.com/frequent.aspx
Re the above link...
Of course I would expect to see the following on the AMSOIL Site:
Question: Can AMSOIL motor oils be mixed with other brands?
Answer: Yes. AMSOIL synthetic motor oils are compatible with other conventional and synthetic motor oils. Mixing AMSOIL motor oils with other oils, however, will shorten the oil’s life expectancy and reduce the performance benefits. AMSOIL does not support extended drain intervals where oils have been mixed. Mixing other oils with AMSOIL motor oils may also void the AMSOIL limited warranty.
The preceding quote is also biased and self-serving and does not constitute as impartial documentation concerning any adverse affects of mixing brands...I'm still waiting for that. Besides, I doubt that any CB owner on this forum leaves the oil in his bike for any extended period of time....surely not long enough for any "mixed-oil" issues (if there are any) to ever arise. For the brief time that the oil is in our bikes, you could probably even get away with using (dare I say it?) Quaker State (if they made an approved, wet-clutch, motorcycle oil)
