Flashed CB1100 Review
Threads: 349
Likes Given: 1,101
RE: Flashed CB1100 Review
#81
(05-13-2014, 10:04 PM)The ferret_imp Wrote: Motorcycles are the perfect medium for individualizing...and I for one encourage that.
I think once the second motorcycle was sold, one of the two guys that bought them wanted to change his to make it more personal than the other guys, and probably make his faster than the other guys too. That is how we as human beings are. We love buying perfectly well engineered products and then modify them to make them a little different than the other guys'. That's cool.
I think it's great that Cip and Ridem are seeing what this bike is capable of. I like what Ack and Silas, and CB4ME have also done. Do I have any intention of ever emulating what they have done? No, I like my bike as it came from the factory, which also means I wouldn't café it, or street fighter it, or turn it in to a full fledged tourer, chopper or bobber. I'm not going to make it faster, or louder or a different color or put on different fenders, or put on a different seat, add luggage racks, or different turn signals, or different handlebars, different exhaust, or remove the reflectors. I'm not going to put rear shocks on it, or fork springs or a fork brace or remove the air snorkel or a myriad of things other owners have done to this bike to make themselves happy. I have made a few minor changes to suit me... new grips, rlets, removed curb feelers, ummmm aluminum valve stem covers, but I have all the original stuff in a box in the garage and could put it back to bone stock in 10 minutes. I might change the left switch out but that would be a safety issue, because for me, right now, the left switch is a danger and could get me killed. I will continue to use genuine Honda oil filters and Honda GN4 10w30 oil and when it comes time I will replace the stock air cleaner and brake pads with oem parts. But that's just how I roll.
Love seeing other guys mods though, so keep changing them and keep posting the pics (or dyno results as the case may be)
+1
(05-14-2014, 12:38 PM)Red Mist_imp Wrote:
(05-14-2014, 11:47 AM)Ridem32_imp Wrote: Amazing the high Tec we have now.
+1
+1
+1
____
+2 =
05-14-2014, 03:10 PM
Ridem32_imp Offline
Threads: 51
#82
+ 2= most everyone will end up with a reflash before the end of the year ! Let that 1972 ford pinto station wagon out run them down hill. Or even worse I beat up yugo ! Lol
05-14-2014, 03:14 PM
Threads: 349
Likes Given: 1,101
#83
(05-14-2014, 03:14 PM)Ridem32_imp Wrote: + 2= most everyone will end up with a reflash before the end of the year ! Let that 1972 ford pinto station wagon out run them down hill. Or even worse I beat up yugo ! Lol
Yeah, but as already noted, you HAD to get yours done to get all the farkles up the hill. Tongue
05-14-2014, 03:18 PM
Ridem32_imp Offline
Threads: 51
#84
Lol cormanus Smile
Ok pitcher this. : your out on a nice ride one day cruising about. 80 mph a ninja 250 comes pass you motor winding out ! Here you are on a brand new. 2014 1100 bike all the sexy gals are watching as you hit 112mph spitting and sputtering the lil 250 ninja pulls away from you !! Pull over on side the road and act like you ran out of gas lol Smile are worse get rear ended by that yugo while your spitting and sputtering at a mere 112 on a massive 1100 new bike! Even the big bulky Harley will come around you ! Again pull over fast and act like your out of gas ! Lol
05-14-2014, 03:21 PM
davidsargee_imp Offline
Threads: 6
#85
(05-14-2014, 03:07 PM)Ridem32_imp Wrote: David I'm like you. I'm leaving my bike stock as far as pipes air filter blinkers seat etc. I worked for Nissan for 20 years and I know the restrictions of a motor. Which is worse to be restricted! I know that a ECM can work in milli seconds! A carb could never be adjusted to throttle position as good as EFI system. It just stands to reason that EFI is so much better in everyway than carb and points etc. But when the EPA says this bike or car has to meet this standard it kills what the motor can do. So all I did was have my ECM flashed to run like the motor should run with out restrictions! Faster better response not a matter of running 140 mph but just the pure reason is to let the bike run as it should! Same as a cell phone they have them so under powered with the antenna that you drop calls. Lots of over seas phones when they make it to the USA they keep full signal due to no fed regulations
Yeah, modern tech is amazing compared to what we did back then. I must admit, the more I think about it, getting "flashed" might be in my future, not for the top end, heck, I've only hit the speed limiter on mine twice. But for the overall better tuning, it's such a simple mod, and I don't anticipate any affect upon the reliability of this motor, it is a very strong, well built, mill. Richer fuel mixtures would probably help it to run a little cooler, wouldn't it? What do you think?
BTW, what part of Mississippi are you from? I'm originally from Central Louisiana, used to get through there pretty regularly.
05-14-2014, 10:38 PM
Ridem32_imp Offline
Threads: 51
#86
I'm in crystal springs. Just outside of Jackson
05-14-2014, 11:22 PM
HikerToo_imp Offline
Threads: 114
#87
(05-13-2014, 11:10 AM)Ridem32_imp Wrote: CIP will be able to tell us lots in a few days when dyno his bike with the flash ECM Don will fine tune it and will know what the motor can really do! It's not honda,s idea to really power back the motor it just has to meet all the government rules and EPA. I think a lot of us will be shocked to see what a cb11 motor can really do. Time will tell Smile
I will be interested in this flash once CIP gets his retuned based on Dyno results. Then I assume Don will be sending out our ECU's with that in mind.
05-15-2014, 12:14 AM
Ridem32_imp Offline
Threads: 51
#88
Yes Don told me if he could get one bike in his shop he could get everything just right in each gear! Then he will have it stored so when someone sends in their ECM he just plugs in his gizmo and BAM it's done. Box it up and overnight it back!! 2 days and your rolling. Smile
05-15-2014, 12:18 AM
Red Mist_imp Offline
Threads: 12
#89
BTW, if Don gets new info and revised the flash, I understand he'll reflash previous units to the update.
05-15-2014, 07:55 AM
Ridem32_imp Offline
Threads: 51
#90
I hope so! If Don gets CIP dialed in on dyno and he blows me away. Don will have to tweak mine to beat CIP Smile lol on the phone Don has been very nice and helpfull that I can say
05-15-2014, 09:19 AM
  Hagon Rear Shock Review dUh! 2 512 09-18-2022, 10:55 PM
Last Post: KiowaEagle_imp
  Samurider Paniers-review + pictures tomas_imp 76 7,832 05-03-2022, 02:35 PM
Last Post: ChiefJP_imp
  Daytona Cozy Seat - A Review motoWest_imp 11 1,174 06-06-2021, 06:09 AM
Last Post: JLEECB
  Dart Marlin Flyscreen - A Quick Review the_undecider_imp 70 7,166 12-10-2019, 02:16 PM
Last Post: jimgl3_imp
  Yoshimura RS3 Exhaust Can install and review Frulk_imp 4 500 11-02-2018, 06:57 AM
  My $8 helmet cam review use2b_imp 9 1,297 05-04-2018, 04:47 AM
Last Post: chync_imp
  Ryujin Exhaust System Review Magnus_imp 9 883 02-10-2016, 01:19 AM
Last Post: NightRider_imp
  Matching helmet/Shoei NeoTec review Papa Weeley_imp 17 1,434 10-20-2015, 09:21 AM
Last Post: Desert viper_imp
  Bridgestone Battlax T30 Review lola_imp 19 1,540 03-26-2015, 05:30 AM
Last Post: lola_imp
  Ryujin Seat Review xpacpal1x_imp 10 884 01-05-2015, 03:48 AM
Last Post: Timpo_imp
