New owner... Vibrations.. And a question
#71
(07-04-2021, 05:32 AM)Ayrshire Dunx_imp Wrote: Well mine vibrates so much the mirrors are a blur when it idles. Still love it tho Heart
Either your mirrors are loose, non-factory, or you have modified the engine / exhaust / tuning in some manner.
Members have written about it and suggested it, but has anyone had the luxury of riding another member's CB1100 that had "extra vibrations"? If so, does anyone remember the root cause?
I would be tempted to find out if the engine mounts had ever been out and refitted with a spacer/washer incorrectly. It can be as simple as a misplaced spacer when someone has fitted engine bars for instance. SW-Motech crash bars were well known for introducing vibrations to the Africa Twin as the fitting instructions were a little vague in places and misplacing spacers was very common. Seemingly well fitted engine bars caused a lot of vibration.
I guess I am spoiled because the EX does not seem to buzz me at all. But I do ride it mostly in 6th on the Hwy and cruise at about 80 mph. I did install heavier bar weights on both of my CB's sometime back just to see if heavier was better low on. Will show pixs soon, got to go to work!
Now THAT is a interesting post. My bike came with small engine guards. I will remove them before my next ride. The heavy bar-ends are great, but I will see if this helps more.
THANKS
(07-25-2021, 10:20 PM)michael1954_imp Wrote: I guess I am spoiled because the EX does not seem to buzz me at all. But I do ride it mostly in 6th on the Hwy and cruise at about 80 mph. I did install heavier bar weights on both of my CB's sometime back just to see if heavier was better low on. Will show pixs soon, got to go to work!
I will try to post pics and a link to my bar-ends also.
Sadly it is none of these things, bought it brand new less than a year ago and it has vibrated like mad from day one. I'm hoping the first proper service next year will reveal one cylinder not firing properly.
If any cylinder is not firing properly, you would definitely have a performance issue and most likely MIL on...
I bring nothing new to this but the OP asked for data points so here is my experience. Please bear with me. I've ridden three different CB1100's (all 2018 RS) with all from zero to 4000 miles, and to me they all vibrated identically and more than I think an inline four with a balance shaft should. These bikes have had two sweeter spots - around 3000 rpm and 6000 rpm - where it's sort of ok, but outside that I get a high frequency buzz, quite painful in the long run. Longer rides, more than a couple of hours, lead to tingling hands. Other bikes I've had (a string of 750-1200 sports twins and triples) have vibrated too, some even more, but never affected my hands as the CB does. This to me is the most negative aspect of the CB. Having said that I'vd yet to try Grip Puppies and heavier bar end weights, but this thread has got me thinking I should. In particular I'm curious if it would pay off to try "tune" the weight of the bar ends by playing around with rim balance weights. Anyone tried that and found an optimal weight?
OP has not been back in a month. I would assume his CB his no longer his CB, and that he is happily cruising around at 80-90 mph on something else. Don't blame him if it wasn't enjoyable or getting the job done for him. Life's too short.
THANKS
I removed my crash bars and now less vibrations in fuel tank area.
In a very old post, someone mentioned torquing the riser nuts to 20lbs.Thanks I tried this and it reduced the buzz at the handlebars, even more. The riser cushions are flexible now and not mashed. The nuts were torqued by someone who installed the aftermarket bars, probably. Service manual does not specify torque.
I am using the lower gears with more revs now, my kinda riding ......Thumbs Up
  CB1100 Questions from a potential new owner E11even_Hunnit 88 6,930 02-12-2026, 06:02 PM
Last Post: E11even_Hunnit
  New owner looking for front turn light, signals and exhaust recommend lfminto_imp 8 657 06-11-2024, 08:19 AM
Last Post: devildogdoc_imp
  Owner's Manual Bighonda14_imp 35 2,550 04-04-2024, 02:29 PM
  New Owner of a 2017 CB1100 EX Kalamari_imp 22 3,143 11-18-2021, 03:03 AM
Last Post: Whoops
  The CB owner willsmith_imp 15 1,259 10-31-2021, 08:58 PM
  Met a new CB owner misterprofessionality 26 1,928 10-10-2018, 03:05 PM
  New Owner Report grandpagl_imp 3 359 09-04-2018, 03:39 PM
Last Post: DBM_imp
  New owner with a lot of questions.... jdinaz_imp 7 620 10-25-2017, 02:15 PM
Last Post: jdinaz_imp
  Prospective owner JonC1985_imp 15 996 10-23-2017, 07:42 PM
Last Post: alprider
   Gotta love owner forums Mikestib1_imp 13 827 01-09-2017, 10:46 AM
Last Post: nhawk7504_imp
