03-31-2017, 11:19 AM
Thanks kvdv. That is indeed very good news - and just what I suspected.
8000 miles, did your valves REALLY need adjusting?
03-31-2017, 06:35 PM
I had my 2013 valves checked at 8k miles by my dealer last fall...same results as most on here...all within spec. The service manager also mentioned he has yet to encounter a CB1100 up to 24k miles that actually required a valve adjustment. This is a testament to build quality around our in line 4. After discussing valve adjustments in general, the service manager did mention he experienced a few of Yamaha's line of FZ/FJ bikes that required adjustments after 8k-10k miles...naturally totally different animal (triples/parallel twins) and most likely different type of riding style may be contributing factors...
04-01-2017, 05:00 PM
I'm rolling up on 40,000 miles and plan to check mine for the first time at the next oil change. Not because I expect to need adjustment, but because my valve covers are starting to weep oil and need replacing. I might as well check on them while I'm already in there.
04-01-2017, 09:22 PM
+1 a wise man. haha I do hope you mean replacing the gasket though not that $500 cover!
04-01-2017, 10:14 PM
Keeny my valve cover gaskets are weeping a bit too. Not leaking but you see oily residue on the front corner of the top fin. I just wipe it off for now but someday it will probably need addressing.
04-02-2017, 02:56 AM
(04-01-2017, 10:14 PM)The ferret_imp Wrote: Keeny my valve cover gaskets are weeping a bit too. Not leaking but you see oily residue on the front corner of the top fin. I just wipe it off for now but someday it will probably need addressing. Hi Ferret, Out of curiosity, do you recall an estimate of your odometer when you first observed the slight weeping? Or, how may miles do you have now? Friend of mine had around 35k on a '78 CB750 and started observing similar weeping.... Sent from my iPhone using Tapatalk
04-02-2017, 04:18 AM
I'm at just over 28,000 miles and it just started happening.
04-02-2017, 11:14 AM
04-02-2017, 12:36 PM
I had mine checked at 8000. The observed values are documented in that thread. No adjustment was needed.
04-02-2017, 12:41 PM
« Next Oldest | Next Newest »
| 20K miles: how this chain looks like? | valkyrie_rider_imp | 12 | 886 |
02-09-2024, 03:06 PM Last Post: valkyrie_rider_imp |
| Pirelli Angel GTs at 5,000 miles | the Ferret | 66 | 5,613 |
11-02-2021, 12:16 PM Last Post: NovaCB1100_imp |
| 2.8 miles | the Ferret | 8 | 591 |
08-23-2021, 12:05 PM Last Post: rboe |
| Anybody looking for a 2013,230 miles? | FLYTYM_imp | 3 | 344 |
05-28-2021, 04:40 AM Last Post: boynton6spd_imp |
| 100 miles in..1st impression | Scoot_imp | 20 | 1,626 |
04-08-2021, 05:19 PM Last Post: Tev62 |
| 100,000 miles on a CB? | AlexCB_imp | 21 | 1,677 |
03-22-2021, 04:57 AM Last Post: Charlie Bravo_imp |
| How many miles.... | Randy B | 53 | 3,233 |
02-10-2019, 11:48 AM Last Post: GoldOxide_imp |
| 100.000 miles on a CB 1100 | itsme67_imp | 31 | 2,037 |
06-05-2018, 08:27 AM Last Post: peterbaron |
| speedo miles and km for usa models...by law? | pdedse | 58 | 3,443 |
02-12-2018, 03:24 PM Last Post: Ulvetanna_imp |
| Eleven Whole Miles! | cookiemech | 33 | 2,296 |
01-31-2018, 08:29 AM Last Post: VLJ_imp |
