LED Headlight Upgrade
Likes Given: 750
RE: LED Headlight Upgrade
#61
(09-24-2023, 03:23 AM)12milesout_imp Wrote: Since someone mentioned the Auxito LED bulb, here's a comparison of what I believe to be an OEM bulb (Philips H4 60/55), a Hella H4 100/80, and the Auxito H4 LED. All photos were taken in a span of about 15 minutes, so ambient light didn't change much.
[url=https://imgur.io/a/OiW0nCy]headlight comparison
I don't ride at night all that much, so I haven't been willing to pull the trigger on the motodemic upgrade. I was surprised by how much brighter the Auxito was, and how the Hella didn't seem like all that much of an improvement.
Quite a dramatic difference.
Plug and play?
09-24-2023, 04:22 AM
12milesout Offline
Threads: 4
#62
Plug and play?
Yes, completely. Just need a Philips (or preferably a JIS) bit for the 2 screws at the 4 & 8 o’clock positions of the bezel.
09-24-2023, 06:18 AM
SportsterDoc Offline
New Mexico
Threads: 33
Likes Given: 6
#63
i plead guilty to mentioning Auxito.
Used Auxito in second Triumph, Yamaha XVS950, second XT250 and in my pickup. No need in the second Moto Guzzi, as it is factory 100% LED.
[url=https://cb1100forum.com/forum/showthread.php?tid=17328&pid=306191&highlight=auxito#pid306191]https://cb1100forum.com/forum/showthread.php?tid=17328&pid=306191&highlight=auxito#pid306191
https://cb1100forum.com/forum/showthread...#pid320096
https://cb1100forum.com/forum/showthread...#pid328960
Just be sure to order the H4 with metal flange, rather than plastic, as the thickness of the plastic may cause installation issues.
https://www.amazon.com/AUXITO-Motorcycle...JNEALw_wcB
09-24-2023, 10:03 AM
mvk24_imp Offline
Threads: 18
Likes Received: 2 in 1 posts
#64
I also used the Auxito, I have posted the exact model that perfectly matches our stock diode placement so that the LED works nearly identical to stock throw and pattern even though its a in a halogen reflector.
Not all LEDs are created equal!
Can't remember where I posted it so here it is again.
It is motorcycle specific as an upgrade so the Diode matches exactly where the halogen bulbs sat in the bucket so the reflector sends a nearly identical pattern to stock. It also isn't over powered with the build in cooling fan in the back so it will fit inside a motorcycle bucket and not expel too much heat in the enclosed space with plastic and wires.
https://www.ebay.com/itm/334283388064?mk...media=COPY[Image: 514ad9f4993e2dabfe7873cba4fcc1cb.jpg]
09-24-2023, 10:22 AM
TooManyBikes_imp Offline
Threads: 2
#65
(09-24-2023, 10:22 AM)mvk24_imp Wrote: I also used the Auxito, I have posted the exact model that perfectly matches our stock diode placement so that the LED works nearly identical to stock throw and pattern even though its a in a halogen reflector.
Thanks for this post. Your link to eBay showed one for $12.99 https://www.ebay.com/itm/334283388064?mk...media=COPY
Also, eBay showed what seemed to be the same bulb at $7.99 https://www.ebay.com/itm/126285955931?_t...101224.m-1
To your experienced eye, are these the same?
02-07-2024, 09:44 AM
mvk24_imp Offline
Threads: 18
#66
To your experienced eye, are these the same? Looks definitely the same however the 7.99 option in your second link is for 10 interior bulbs. They have the motorcycle 9003 bulb for 19.99 in that listing i'm seeing from your second link though.
[Image: d66d725d729cc460466979c7342f1aaa.jpg]
02-07-2024, 09:50 AM
Threads: 2
#67
Thanks mvk24. Your sharp eyes are appreciated.
02-07-2024, 09:55 AM
mvk24_imp Offline
Threads: 18
#68
(02-07-2024, 09:55 AM)TooManyBikes_imp Wrote: Thanks mvk24. Your sharp eyes are appreciated.
No worries, glad to help
02-07-2024, 09:59 AM
  swing arm upgrade rtmoto1 8 439 03-09-2026, 09:31 AM
  Rear Suspension upgrade 17-CB-002 3 307 02-22-2026, 09:41 AM
Last Post: 17-CB-002
  2017 Fork Spring Upgrade deuce17EX 2 466 04-15-2025, 01:37 PM
Last Post: deuce17EX
  Headlight for 2017 deuce17EX 2 522 04-15-2025, 08:54 AM
  Speedometer Upgrade!? DirkDiggler_imp 12 1,182 02-23-2025, 04:57 PM
Last Post: Jurlie_imp
  Worst headlight ever. Whoops 14 1,274 01-15-2024, 07:01 PM
Last Post: jtopiso_imp
  LED Headlight? 2014ltdltz 16 1,495 06-21-2022, 01:36 AM
   BEST Cheap Headlight Upgrade for the CB1100 BE WELL SEEN IN THE DAYLIGHT! Havasu Secret_imp 18 1,470 02-25-2022, 12:16 PM
Last Post: Scoot_imp
   Traxxion AR-25's installed... great upgrade!! Sparky80_imp 2 310 10-18-2021, 12:38 AM
Last Post: Sparky80_imp
  '17 Grabrail Upgrade for '14 HigginsNYC_imp 25 1,577 04-09-2020, 08:03 AM
