Threads: 30
I took my NTM Suzi V-Strom out to my BIL to change the oil. I usually use a BIG pair of Chanel-Locks on the filter, but he had a filter wrench I'd never seen before. It was a heavy strap attached to a 6"x 3/4" square bar. Wrapped that strap around the filter, a big crescent on the bar, off it came.
Threads: 8
Threads: 27
that's what I have. only bad thing is it will scratch the #$%@!^% out of everything around it.
Threads: 3
(03-11-2021, 02:42 AM)GoldOxide_imp Wrote: (03-11-2021, 12:42 AM)The ferret_imp Wrote: good deal. Shouldn't be an issue next time around. Hand tighten only.
I remember reading about the same ordeal back in the early 80's.
An ol' favourite: "Drive a screwdriver into it and twist."
I was contemplating it as a last ditch attempt. Had to do it before.
Threads: 8
(03-11-2021, 09:50 PM)jimgl3_imp Wrote: that's what I have. only bad thing is it will scratch the #$%@!^% out of everything around it.
thats odd never scratched anything on mine
Likes Received: 609 in 274 posts
Likes Given: 785
I have all 3 tools, the factory cup, the 3 prong thingy and the giant pliars thingy. Once you get the initial filter off (the giant pliars thingy worked best for that for me) then all I've ever used is the factory cup.
Likes Received: 875 in 478 posts
Likes Given: 1,006
I use one of these. Works fine.
(we should go around one more time)
(throw in a best oil to use statement as well)
Threads: 8
If you can't loosen your oil filter with your hands then it tightened down too much.
Threads: 14
Likes Received: 14 in 9 posts
Likes Given: 20
I have always just used a set of channel locks pliers to take off oil filters. Never owned a purpose built oil filter wrench. Who cares if you dent it when removing.
