VIBRATION - deciding too much; and living with it.
#61
(04-24-2015, 02:25 PM)Rboe_imp Wrote: There is an 2013 at GoAZ, less that 500 miles on her. Traded in on a BMW. WTH?!
I don't understand it either, but some folks have money to drain away I guess. I'll be in Lewiston Idaho mid June. Bring it over and I'll test ride it to see if it's like mine. Big Grin
I'd like to try that. Be real difficult to schedule - since I work on-call...but I'd like to try.
The ride through Lolo National Forest is a great one on two wheels; and at the end of it, is Lewiston.
Details to follow then. Big Grin
I know that ride! U.S. 12 over Lolo Pass and across Idaho, right? One of my favorite rides. I haven't done it on the CB11 yet, but have done it at least a dozen times since the mid 80s.
Note : This sign just west of Lolo Pass now reads "99 miles".
[Image: de809b4128e7c061f7109f3e75e536d1.jpg]
Is there anything more beautiful to a motorcyclist than a sign saying "99 miles of winding road"?
(04-25-2015, 08:51 PM)Cormanus_imp Wrote: Is there anything more beautiful to a motorcyclist than a sign saying "99 miles of winding road"?
I was thinking the exact same thing Big Grin Thumbs Up Thumbs Up
Only if the gas tank is up to it.
[Image: 0e0586e65295ad05781b6b31280a26ce.jpg]
Yup.
Made it once, last summer. On my departed BMW.
Time allowing, I'll make it again when weather warms up. It's about twenty degrees colder towards the peak, than it is down in the valley of the Clark Fork River.
I got a pic as my wife and I blew past the sign in 2013 on the ST when we toured Montana, Idaho, Washington, Oregon and Wyoming
[url=http://smg.photobucket.com/user/theferret111/media/DSCN0510_zps7rcvom7v.jpg.html][Image: 930af9540cfbfbec5b92f5d99b67410d.jpg]
Perversely, perhaps, I'm a bit partial to these signs too given they usually indicate a twisty or two.
(04-20-2015, 12:57 AM)nhawk7504_imp Wrote: "Sekiya:
On the hardware side, phased valve timing gives the engine its characteristic feel around the 3,000 rpm range. How did you create the engine's personality?
Minami:
Basically, straight-four engines run smooth as long as all four pistons move the same way. My initial thoughts were, to give the engine a deep rumble, we'd have to change the movement a bit.
We ended up shifting the valve timing of cylinders 1 and 2, compared to cylinders 3 and 4, and by continuing to change the gap, found the right combustion out-of-sync feel."
"Korogi:
At around 3,000 rpm, the four-cylinder engine vibrates strongly like a two-cylinder engine, and has a solid rev feel through the chain to the rear tire, giving a strong sense of traction, and finally a purposeful sound.
'Deep rumble' expresses the feel, through the five senses, of an air-cooled four-cylinder engine."
"Sugiura:
Of all the ideas we had for the engine's 'character,' we went ahead with phased valve timing. The engine is based on the CB1300 Super Four, and in the initial prototyping stages, we took its engine and simply modified it to be air-cooled. We had the prototype tested by a number of people, and the majority told us that it didn't feel like an air-cooled engine, that it felt the same as the 1300SF."
"Fukanaga:
I think the bike is as good as it is, because we had people in the factory see, ride, and understand the level of the engine's potential and 'feel' that we wanted.
Once the factory understood us, they started giving us ideas on how to improve the quality of the mass-produced model. This was what happened for the 2014 model."
Good Answer...!
  2014 CB1100 - rotational vibration/wobble - flat spots in tires? rozbabbo1100_imp 7 646 08-04-2022, 10:10 AM
Last Post: 1973cb750
  Vibration billyfinchapel_imp 5 553 05-10-2021, 02:07 PM
Last Post: billyfinchapel_imp
   Vibration Brad14_imp 16 1,178 08-08-2020, 05:10 AM
Last Post: Brad14_imp
  What's living in your fuel tank? max 4 380 11-05-2019, 08:42 AM
  Deciding 37 vs 35 tooth rear sprocket on 2013, 19 on Front is correct rbike_imp 41 2,968 09-01-2018, 03:19 AM
Last Post: IndianRider_imp
  2017 EX Front End Vibration 2017EX_imp 27 2,080 12-20-2017, 05:55 PM
Last Post: jtopiso_imp
  Clutch Point of Engagement & Front End Vibration 2017EX_imp 14 903 08-07-2017, 05:25 AM
  Inline 4cyl vibration thessler3_imp 22 1,430 03-30-2014, 04:26 PM
Last Post: rjk555_imp
