dead battery
#61
(10-16-2022, 03:28 AM)pdedse_imp Wrote:
(10-16-2022, 01:31 AM)GoldOxide_imp Wrote:
(10-16-2022, 12:09 AM)pdedse_imp Wrote:
(10-15-2022, 09:49 AM)peterbaron_imp Wrote:
(10-12-2022, 01:48 AM)pdedse_imp Wrote:
(10-12-2022, 01:00 AM)Charlie Bravo_imp Wrote: 40 bucks?!?! I paid slightly north of 150, because I wanted it RIGHT NOW.
Sometimes you need it right now. My original battery gave me a few heads up with less than normal starts, engine light came on. too. I parked it and ordered the cheapo battery just to try one out and rode the other bike while it arrived. If it lasts less than a year, I wasted a fist full of dollars, but only ones and fives. I have yet to buy a battery that lasted less than 4-5 years in Oregon, so I'll see how this one does.
Pdedse, before visiting the Maritime provinces next year, make sure you have the new battery installed prior your departure...cos due to RIGHT NOW demand, we will charge 'merican travellers more than domestic habitants ... Tongue
But this is when I call you, me stranded near Napadogan having pushed the $40 battery to its outer limits, and you drop everything only to find out that the local battery shacks are out of compatible CB batteries, and so what do you do?...do you leave me stranded by the roadside?...No, that's not happening...you step out into the garage and remove the battery from your CB, and you're out on the road lickety-split...and I am eternally grateful...we take a few pictures, I buy you dinner at the Village Pour House Wenday 1st Stop...and you, PB, you become a CB1100 Forum Hero!!!
Oh, and I promise, the check for that battery IS-IN-THE-MAIL...must be the service between USA-Canada.
(10-15-2022, 09:51 AM)GoldOxide_imp Wrote: pdedse: Also consider a USB socket with voltmeter too. Very low price insurance, plus a USB charging outlet for your dash trash.
I carry a battery charger with jumper cables, built-in flashlight and has USB ports. I'm afraid I only have bugs on the bars, no electrics. The charger keeps the phone juiced when camping, and I've actually used it to jump a car battery...it worked.
That is handy pdedse.
Keep in mind that if your motorcycle battery has at least one dead cell (happens often on end-of-life batteries), then the juiced charger won't help you.
Nevertheless, you can likely still fall back on bump-start; just keep the RPMs elevated to offset the weak battery load on the charging system.
Yep, understood. That's why PB is my roadside backup.
I'm gonna go out on a limb and state unequivocally that this el cheapo battery (it was actually $37.99) is lasting me 4 years minimum.
Angel
Very true. [url=http://cb1100forum.com/forum/member.php?action=profile&uid=3454]PB does keep a pair of CB1100s around.
Yeah, and the main reason is to have an immediate access to the second battery when needed RIGHT NOW Smile
P. S. A special kit for member Pdedse is being prepared….pic coming soon
(10-16-2022, 03:45 AM)peterbaron_imp Wrote: Yeah, and the main reason is to have an immediate access to the second battery when needed RIGHT NOW Smile
Isn't this forum amazing? ...knew I could count on you.
  ABS , speedometer and battery Walter 10 744 05-02-2026, 01:29 AM
Last Post: Walter
  Yuasa Battery Life dave 28 2,437 04-01-2026, 04:44 AM
  Rattle on right side exhaust / battery CB1100i_imp 4 652 04-18-2025, 02:48 AM
Last Post: CB1100i_imp
  Battery jumper the Ferret 14 1,024 10-28-2024, 10:58 PM
  CB1100 SA-E 2017 Battery Davidjill_imp 1 269 08-01-2024, 02:33 AM
  wonder battery The Gecko_imp 58 4,330 02-19-2024, 11:20 PM
  Could old/low battery trigger misfire and engine light? Motorsport3_imp 13 1,197 12-17-2023, 08:41 AM
Last Post: Jgarciajr40_imp
  Replacement Battery dave 54 3,709 02-04-2023, 12:41 PM
  Winter Battery Maintenance Wagonpeddler_imp 27 2,123 10-18-2022, 01:55 AM
  Battery Question KiowaEagle_imp 49 3,579 01-31-2022, 04:09 AM
