  • 1 Vote(s) - 2 Average
Cold Weather Riding
#61
Good for you!! Thumbs Up
(12-28-2023, 02:17 AM)Charlie Bravo_imp Wrote: Went for the silk under-layer test ride yesterday, and they performed flawlessly! (If this is too much info for you, stop reading right now, or continue at your own risk. Not responsible for any damage to your delicate condition) [Insert laughing emoji here.] With the silk garments, wool socks, jeans, a long-sleeve wool pullover shirt, a Schott Perfecto jacket, gauntlet gloves and a full-face helmet, went on a 45 minute ride in the 51 degree mid-afternoon and was toasty warm the whole time.
My [primal] understanding is silk underwear works best when they are slid off slowly and sensually, especially with the help of another - or several - if you are so lucky. There is no shortage of heat, among a few things.
And then there's that, but this is the wrong forum for that!
(12-27-2023, 02:56 AM)Nachodaddy_imp Wrote:
(12-27-2023, 01:45 AM)Charlie Bravo_imp Wrote: For Christmas my sweetie gave me a set of silk under garments, similar to a long-sleeved T-shirt and sweat pants. Going to be 50 degrees and sunny today, so I'm gonna test 'em out this afternoon.
That sounds great. Might want to wear something over them, though.
I thought something was a little odd!
(12-27-2023, 04:13 AM)pdedse_imp Wrote: Just saw this on another forum.
Heated Motorcycle Grip Cover Pad
I'm going to give these a try.
I ordered the above and they arrived the other day. Some photos:
The heating grips wrap around your mc grips and velco together.
[Image: 808964622224647a9d32299bb8ee352c.jpg]
[Image: 9e1615e11d76f620301391928d2ec7f4.jpg]
The wiring instructions are minimal
[Image: 8fb9d217b932fe9151e292919b8240ec.jpg]
If not legible, says "the red wire is connected to the positive output wire of the electric door look (ACC) and the black wire is connected to any negative electrode on the motorcycle" .... Positive output wire of the electric door lock? What?!
The fuse and wiring ends.
[Image: 5d72655badcfbf6603d539770731a5fc.jpg]
I learned about this product while on a Suzuki DR650 forum, so different bike. I asked there about connections, and if one could wire into a battery tender. Someone suggested solder/heatshrink or positap an [url=https://www.amazon.com/dp/B0BL2TTVNN?linkCode=ogi&th=1&tag=sofferscom1-20]SAE connector like these:
[url=https://www.amazon.com/dp/B0BL2TTVNN?linkCode=ogi&th=1&tag=sofferscom1-20]https://www.amazon.com/dp/B0BL2TTVNN?linkCode=ogi&th=1&tag=sofferscom1-20
And then others expressed concern about amps / watts "discrepancies" between battery tender and heated grips 5amp fuse. Electronics being somewhat of a black hole for me, I figured I'd ask here as well, mainly for the CB1100.
Other info: the heated grips have 3 temp settings, and the power draw is:
Hight Temperature(Switch Red light) 25w
Medium Temperature(Blue Light) 20W
Low Temperature(Green Light)15W
So questions. 1) w/out doing anything to the wiring (using the spade connectors), can I simply connect directly to battery terminals? Will there be a constant draw on the battery if I do? There is an on/off button/switch that's supposed to be fixed on the handlebars for easy temp control access.
2) what I'd rather do is add the SAE connectors to the existing wires of the heating unit. a) that would allow me to use the same grips on different bikes b) by disconnecting at the battery tender, would eliminate any draw on the battery.
Last night I wired them directly to the battery terminals just to test them out, and the mid temp setting was nice and warm in two minutes. Max temp was pretty hot.
I have grip puppies on the CB and my W800. These thicken the grip and the velcro wrap-around heating element for this product isn't quite enough for it to velcro together. But they would have enough reach for stock grips. I'll have to secure them, maybe with rubber bands wrapped around them.
Any feedback appreciated.
[url=http:///gif/cast-away-i-have-made-fire-tKUxyM][Image: 610665025ff6cce38be23092b96963de.gif]
I broke down and recommissioned "The Weber", my inauspicious name for my Givi V40 box. It looks like a mid-sized barbecue on the back of my bike, doesn't it. Not flattering, but what box is. I've been using my E36, a smaller, less obtrusive box for the daily commute, which does not have the capacity for a helmet.
However, for winter early morning and evening commutes and the after-work errands and meetups with Mrs. or friends, leaving a helmet locked to the handlebars means coming back to a cold lid, damp with dew. Plus, I'm carrying an extra pair of thick gloves, neck gaiters and other keep-warm bits. The V40 is the smallest Monokey box that can secure a helmet, and carry the extra stuff. Not pretty, but functional.
(01-10-2024, 03:14 AM)Gone in 60_imp Wrote: I broke down and recommissioned "The Weber", my inauspicious name for my Givi V40 box. It looks like a mid-sized barbecue on the back of my bike, doesn't it. Not flattering, but what box is. I've been using my E36, a smaller, less obtrusive box for the daily commute, which does not have the capacity for a helmet.
The "Weber"! Haha...It does have that "pizza-delivery / pool-cleaner-guy" look that I see frequently in other countries. : ) But it's highly functional, can be locked, and keeps your helmet dry. Sometimes function must win out over form. An alternative would be a soft tail bag mounted to the seat, as opposed to the rear rack--they look low profile, but these are generally not lockable. I use my soft tail bag on the CB's seat, but I mainly use it to pick up groceries on the way home from work so I don't leave things of value inside the bag while it's parked for long.
EDIT...wait...what DO you use for BBQ?
Yeah, not gonna leave a helmet or anything else in an unlocked bag where I ride, and since all of my bikes have Givi mount plates, it's just too handy not to use a big black brick. Sort of ironic, as a motorcycle soft luggage company is next door to my office.
And, my altar to meat cookery is a Weber Genesis. Anything less... might as well put your meat in a microwave. Word.
Pdedse, on cold mornings and nights, I've toyed with getting grip warmers like you just installed, I do miss them from my last BMW. Maybe someday, but for now, thick gloves do ok... they do have the flaw of making me hit the horn when I cancel my turn signals. Did it just this morning, and got a wave from someone on the sidewalk who must have thought I was saying "Hi, good morning!"
[Image: 634a9ce7dfd9ec5515b30f6d914a1c13.jpg]...
Sometimes I forget my brother is a long-time mechanic for autos and trains and has done his fair share of electrical work, so I gave him a call, sent him photos of what I wanted to connect, and he seemed to think the following would be fine:
Battery tender pigtail (3amp fuse) -- to SAE connecter with 14 gauge wire -- to heated grips wiring (thinner, 16 gauge wire?) with 5amp fuse would work ok. He cautioned to simply try it out, let it run for 5 mintures and check for wires / connectors for heat.
Connected SAE connector to heated grips wires
[Image: 0c3ef3ff3e0d75984a765a6f906b6d19.jpg]
Did a loose-fit on the CB1100, started, cycled through the temp controls of low, medium and high. All worked, could feel the grip heat begin to build after a few seconds, maybe a minute, minute plus 30 to get to full temp. Blue (medium) seemed like it would be good, red (high) got pretty hot. Off button did what off buttons do.
[Image: dd112fb69c3dc4436c677d98b73773e9.jpg]
Checked all along the wiring, fuses, connectors, and couldn't detect any heat at all. The velcro doesn't quite reach around as I have extra girth with the Grip Puppies, but I can secure with thin zip ties.
[Image: 0415b80228a328d3c164fa36eef40d43.jpg]
Now I'll figure out the routing and where to attach the on/off/temp control switch. I went this route adding the SAE connector so I could plug into the pigtail instead of at battery for two reasons 1) so i could transfer from bike to bike 2) to eliminate any possible draw on the battery by disconnecting from the battery tender pigtail. But the units only cost $26 so--if this works ok--I'm thinking of buying a couple more for the W800 and DR650. Looking forward to some dry days, but forecast is for snow and ice and mid 20s for highs the next few days. I can wait till high 30s/low 40s return.
NO winter riding this year, snow almost every day and daily temp around -10*C/14F.
Today at night -24*C/-12F....brrrrrr
I know, our Ferret is a winter champion! Cool
           "Drop a gear and disappear"®
'24 Kawi Z650RS - Hooligan®
            *Grand Chancellor*
  Best Weather App for riding? ymtnpoah11_imp 22 1,549 02-04-2023, 03:32 AM
  Massive weather front lashes eastern Australia Rocky_imp 15 1,225 03-23-2021, 06:49 AM
  Unusual day weather wise here in NE Ohio ohiorider_imp 4 526 12-02-2018, 11:41 PM
  Everything is running well - then the weather turns bad ohiorider_imp 11 1,125 11-02-2018, 12:02 PM
Last Post: ohiorider_imp
  Come on weather ... cooperate! ohiorider_imp 8 634 03-06-2017, 11:29 AM
  Bad weather = no seat time. SCCBrider_imp 12 982 04-14-2016, 05:41 PM
  CB Cold Weather Start-Up Haystack_imp 18 1,188 01-24-2016, 03:17 AM
Last Post: Rocky_imp
  All-weather riders: protecting your bike? alphonsus_imp 12 811 10-20-2015, 03:23 AM
Last Post: aschem_imp
  Rally Weather Powerdogg55 18 1,113 05-26-2015, 10:05 AM
  Running cold Obliviontoad 31 2,172 11-19-2013, 09:59 AM
Last Post: flynrider
