The Finished Chip Beck Spec CB1100-PHOTOS
Ron in MO_imp Offline
Threads: 14
#51
I am a new forum member and soon (this Thursday) to be owner of a 2013 CB1100. Your bike is an inspiration to me on the personalization changes I have planed fort mine. It's forum members like you who help us all learn from your experiences that make owning one more fun. You have beautiful CB1100 and I hope mine turns out as good as yours!
12-06-2015, 01:24 PM
dirt road_imp Offline
Threads: 2
RE: The Finished Chip Beck Spec CB1100-PHOTOS
#52
(12-06-2015, 01:24 PM)Ron in MO_imp Wrote: I am a new forum member and soon (this Thursday) to be owner of a 2013 CB1100. Your bike is an inspiration to me on the personalization changes I have planed fort mine. It's forum members like you who help us all learn from your experiences that make owning one more fun. You have beautiful CB1100 and I hope mine turns out as good as yours!
Yep...my wallet is gonna be "Chip Beck Spec'd" before I'm done.
12-22-2015, 03:19 AM
ChipBeck_imp Offline
Threads: 29
#53
Dirt,
You made me laugh out loud this morning bro. Merry Christmas!
Chip
12-22-2015, 05:03 AM
EGAlvarez_imp Offline
Threads: 34
#54
(11-24-2015, 07:07 AM)EGAlvarez_imp Wrote: Could we get some more intel regarding the rear tail light? Vendor? Cost?
Chip,
Thanks,
Eddy
I think this may be it...
http://www.dimecitycycles.com/vintage-ca...-1081.html
12-22-2015, 05:27 AM
Threads: 2
#55
I just HAD to nab your turn signals and tail light mods. I already ordered the signals from Lockhart Phillips. They were VERY helpful. I asked about running lights/turnsignals for the front and got a FAST reply from David.
The old style Lucas tail light....I remember using those in the 60's. Had to go for that too. Other stuff is and will be different on mine. I'm still HOPING for a reply from 7th Gear Designs .
Yours is the best build I've seen so far. Subtle and slick. The '13 RULES !
12-22-2015, 08:54 AM
Steverino_imp Offline
Threads: 5
#56
Did you have any problem removing the stickers? Did you use any special remover , was there a residue?
Thx Steve
[quote='ChipBeck' pid='112599' dateline='1448249040']
Gentlemen,
It has now been over two and half years since I acquired my 2013 CB1100. The day I purchased it I had a vision in my mind of what I wanted it to look like when I was finished. I didn’t think it would take this long but some of the mods were more difficult than I anticipated and my work schedule limited the amount of time I was able to work on it. It would have taken twice as long and not turned out as well without the collective knowledge garnered from this forum. I had multiple goals that occasionally conflicted with one another. Visual aesthetics, function, and rider comfort all needed to be combined in a package that did not change the basic early 1970’s character of the bike. The finished product needed to look as stock as possible after eliminating some elements that I found visually or functionally objectionable. I considered starting over with a '14 six speed bike but many of the visual details I find most appealing on the CB11 disappear on the blacked out 2014 standard and I don’t like the shape of the gas tank or the single tone engine and wheels on the 2014 deluxe. I don’t object to the five-speed transmission per se but I think top gear is way too low on the 2013 bikes. After changing the gearing I am much happier with the ‘13 CB11. Many of my mods are detailed in the “how to” section of this forum if any member wishes to duplicate some of them. Some of my mods are simple, quick, and easy and some of them required a considerable amount of work.
I am interested in member’s comments, both good and bad, and I’m not thin-skinned so please fire away with what you think. All modifications are the personal preference of the rider and there is certainly no right or wrong. Below are listed the 21 modifications that made the final cut on my CB1100. I made many more but some of them were reversed and others were changed and revised. So here ya go……
1. Removed all stickers from the fuel tank.
2. Removed front fork slider reflectors.
3. Removed stock handlebars and replaced them with genuine Honda CB-500F flat black handlebars that retained the stock bar-end weights and dampening system.
4. Removed stock chrome rear view mirrors and replaced them with genuine Honda CB-500F flat black rear view mirrors that are lower and slightly wider.
5. Removed the huge stock plastic taillight and the stock license plate bracket with all of its reflectors that obscured most of the chrome rear fender and replaced them with a Lucas type hooded chrome metal taillight with an integral license plate bracket that is smaller and lies flush with the rear fender.
6. Removed all 4 of the jumbo plastic turn signals and replaced them with Lockhart Phillips polished aluminum turn signals that have a similar shape but are much smaller. These signals use the same bulb as the stock turn signals and are just as bright.
7. Removed the stock seat that I thought was visually perfect but functionally unacceptable as it had me constantly sliding forward into the gas tank and uncomfortable for multi-hour rides. Had a Corbin seat made to my personal specifications (Chip Beck Spec) that looked as stock as possible and is comfortable all day. I also purchased a K&H seat but much preferred the Corbin.
8. Attached battery tender cables to the stock battery to facilitate battery tender use without removing the seat.
9. Installed a flat black license plate frame with stainless steel hardware to match other flat black elements on the bike such as my mirrors, handlebars, fuel injector covers, and engine.
10. Installed a 7th Gear Design 19 tooth steel front sprocket which raised final gearing 5%.
11. Installed a 7th Gear design 37 tooth steel rear sprocket which raised final gearing an additional 5.5%. The combination of those two sprockets raised my final gearing 10.5% and lowered RPM at 70 mph from 4000 to 3600 RPM.
12. Removed the charcoal colored, plastic left hand rear engine side case and replaced it with the polished aluminum
12-24-2015, 12:13 PM
Lord Popgun Offline
El Supremo RLET Force
Virginia
Likes Given: 136
#57
Steve, most of us have removed the stickers. For some they come right off. Some use a hair dryer to heat them up some. I used the sun. Using your thumbnail or another finger, you can get the edge to lift up and slowly peal them off.
Any residue can easily be cleaned off with WD-40, or I think some used goo b gone or whatever it is called. I used WD. Then, some of your favorite wax or polish, and you are done. Smile
12-24-2015, 12:35 PM
huxley2_imp Offline
Threads: 1
#58
Great thread, just thought I'd bump it up.
02-23-2016, 01:35 PM
Threads: 29
#59
Gentlemen,
I love my '13 CB1100. Every time I get off my new Sportster 48 and get on the CB1100 it's a revelation all over again.
Chip
02-26-2016, 07:45 AM
pdedse Offline
Threads: 119
Likes Received: 790 in 332 posts
Likes Given: 786
#60
Since you mentioned it, what do think of your Sportster 48, particularly in light of the CB?
02-27-2016, 02:55 AM
  finished "forward controls" today Griz53_imp 12 908 10-02-2022, 10:44 PM
  Winter Mods finished, time to ride! Phadreus_imp 3 472 05-02-2022, 10:08 PM
Last Post: Phadreus_imp
  Tech Spec Tank Pads 2017EX_imp 3 367 08-06-2020, 06:10 AM
  Chip Beck Spec Low Handlebar/Mirrors Mod. ChipBeck_imp 112 8,016 09-18-2019, 12:00 PM
  Chip Beck Corbin Seat owners iamlegend21087_imp 6 514 08-29-2018, 07:12 AM
Last Post: bflint
  Pair valve delete...i need photos -_- JohnHighlander_imp 2 282 05-30-2018, 05:21 AM
Last Post: Ferrealls_imp
  It's Finished! (mostly) Banned_imp 7 646 05-25-2018, 10:44 PM
  Top triple clamp torque spec run-tmc_imp 5 465 06-01-2017, 09:15 PM
  Ryujin Fender Eliminator kit Video & Photos lola_imp 27 1,653 02-05-2016, 05:56 AM
  ASWR Spec Chic Design Sport Trunk Seat Chapomis_imp 22 1,512 12-16-2015, 10:14 AM
Last Post: Riko_imp
