Thinking of a new gadget...
Csory_imp Offline
Threads: 2
RE: Thinking of a new gadget...
#51
Here are two images showing different surface preps: leftmost is printed "as is", middle one sanded, rightmost epoxy-coated. Second image: same cases but painted in matte black. Second image rightmost one (epoxyed and painted) looks best to me. Will go with that.
12-10-2018, 09:38 PM
Threads: 347
Likes Received: 844 in 464 posts
Likes Given: 977
#52
Good choice.
12-10-2018, 10:29 PM
#53
Agreed, second image last sample looks really good. You are moving well.
12-10-2018, 11:09 PM
jtopiso_imp Offline
Threads: 13
#54
(12-10-2018, 05:36 PM)Csory_imp Wrote: Rboe: sure, will put’em under the “homemade for sale” (or whatever is appropriate) thread, but if and only I’m 110% happy with the end result. Right now working on the housing - tested a bunch of iterations with surface finish. The winner process is 160-grit sanded, epoxyed, then spray painted with acrylic in matte black. Base material is 3d printed black ABS, 100 micron layer height. Will have to try cutting the front glass with a diamond disc. Obtained a few sheet of laminated antireflex glass (basically cellphone screen protector) but they are quite thin (0.3mm or less than 1/64”). Will post images once managed to cut’em and not break’em Big Grin
Look for "perspex" plastic. It's tough, cheap and supplied cut to size.
12-11-2018, 12:47 AM
Likes Received: 582 in 260 posts
Likes Given: 763
#55
amazing stuff really.
12-11-2018, 02:09 AM
Csory_imp Offline
Threads: 2
#56
Parts arrived - it was time to see if the housing fits! There were a few gotchas (there are always a few gotchas...) Found that epoxy resin can be peeled off with a knife relatively easily - will try sanding, acetone bath and then spray acrylic for the housing. Also, trimpots are too fiddly to calibrate voltage measurement - will go with software calibration instead. This will be burned in once the panel is complete to match the exact characteristics of that given set of parts. Power consumption is between 10 and 30mAmps (depending on screen brightness), not that bad at all. The pictures below show how cramped this thing is. Will have to re-arrange parts to have access to the MCU for post-soldering reprogramming though... Also added a movie, just to show off Big Grin
12-14-2018, 05:55 AM
#57
Really nice prototyping art Csory. Yeah, 10's of milliamps while riding is nothing - certainly a lot less than a signal light bulb. Cooling over long period of time could be an issue, particularly on profuse humid daze.
Are you going to put a red filter over the display digits?
Crisp video.
12-14-2018, 01:29 PM
Csory_imp Offline
Threads: 2
#58
GoldOxide: I reluctantly admit that the antireflex glass front pane (that I was so proud of...) is somewhat an eyesore. It is so transparent that the instrument looks a bit "naked" with it. Will try a few more options: a.) use black faced 7-segment display, b.) add a translucent (frosted) layer between the glass and the LEDs, or c.) use the standard deep red acrylic filter. The red filter idea seemed a bit out-of-style (with the rest of the instrument panel), but will have to reconsider...
12-14-2018, 09:35 PM
#59
If practical, consider amber LEDs and really get night traffic gawking at the flashing InfoDash at red lights.
The back seat cager kids love that stuff as they press their greasy nose against the door window.
12-15-2018, 01:32 AM
peterbaron Offline
Likes Received: 576 in 313 posts
Likes Given: 969
#60
When this exited project will be road ready and with what monitoring options ???
Smile
12-15-2018, 11:21 AM
  The mountable gadget I'd like to see Tom_imp 23 1,539 01-03-2022, 07:26 AM
Last Post: tommymck
  Thinking about belt conversion Ralph_imp 12 1,009 10-19-2015, 08:41 AM
Last Post: Ralph_imp
  Thinking about a wider rear tire silascopathic_imp 97 6,479 04-12-2015, 05:24 PM
Last Post: lemontree_imp
  Thinking about gaiters the Ferret 10 689 08-06-2013, 02:04 PM
Last Post: BuffaloBill_imp
