Whitehouse K17 mods...
RE: Whitehouse K17 mods...
#51
Great Bazbro. Luck comes in many forms. Congrats!
06-06-2019, 02:07 AM
max Offline
Threads: 39
Likes Received: 15 in 8 posts
#52
Nice project bazbro, parts arriving and gathering around the new bike must feel like christmas.
Good idea with the support of the handlebar from the roof, i do a similar thing, my garage is under the house and i have a good selection of herringbone dwangs between the floorjoists to support the bike from, i use a 2.5 Ton ratchet tydown strap and it lifts the frontend of the bike securely off the ground and supplement that with another tydown on the back of the bike for stability, i cannot deal with the momentum of a falling 250 kg bike especially if i am underneath it and by myself let alone on a bike-stand, if you can feel it begin to move over it's already too late.
Sharing your sentiment about the handle bars, i have been looking for a set for my hornet 900, it had a set of wider alloy bars on it and i just did not get on with those, so after 3 years someone offered a set of cb1300 handle bars on a local auction site and i put those on, makes such a difference and i am very happy with the result.
Thanks for keeping the group abreast of your enviable project.
06-06-2019, 03:46 AM
Gone in 60 Offline
Blood Biker of the Apocalypse
Orange County, CA
Threads: 245
Likes Given: 1,002
#53
Regarding JB Weld, very strong. I reattached a broken piece of a transmission case on a Chevy truck with it, and it held till I sold the truck without leaking a drop of fluid. On my Bonneville, I hit a coyote in the country side a few years ago (he lived, and I didn't go down). It tore off my front fender, and in the process broke off the mounting boss for one of the fender stays from the fork tube. I fashioned a new mounting boss from JB Weld and a threaded nut. Sanded it and painted it to match the boss on the other fork tube, and it's held for years.
06-06-2019, 04:09 AM
Bazbro_imp Offline
Threads: 16
#54
Thanks guys. Wink
And thanks, Gone in 60 - that's just the endorsement I'm looking for. Thumbs Up. Wink
06-06-2019, 06:05 AM
Gone in 60 Offline
Orange County, CA
Threads: 245
Likes Given: 1,002
#55
Just make sure the two mating parts are really clean and oil-free. I've found that the slow curing stuff holds better than the 5-minute variety.
[/quote]
06-06-2019, 06:49 AM
Bazbro_imp Offline
Threads: 16
#56
An enquiry to JB Weld elicited the same advice as yours, Gone... Thumbs Up
Their original formulation, product code 8265S, is their strongest, and clamping the item(s) for at least 24 hours produces the best repair. Wink
Yes, Max - it's just like Christmas whenever the postman calls!! Nice to have all the parts ready to go before I start. Smile
06-06-2019, 10:56 PM
Houtman_imp Offline
Threads: 115
#57
I like your hoist set up !
06-07-2019, 12:20 AM
Bazbro_imp Offline
Threads: 16
#58
(06-07-2019, 12:20 AM)Houtman_imp Wrote: I like your hoist set up !
It's been REALLY handy in the past, John.
I used it to lift and steady the BMW on its engine jack when I upgraded the alternator. It's also very handy shifting heavy stuff around, like storage boxes and my Easylifter Hydralift trailer. It's also good to just lift the front or rear of the 'bikes a tad, to spin the wheel for instance. Yes, a very handy bit of kit.
06-07-2019, 01:38 AM
Bazbro_imp Offline
Threads: 16
#59
Replace the damaged rear mudguard (fender). The rear light had already been "removed" in the accident - just the wiring left dangling...
The workshop manual says to first remove the cover for the battery. I took this to mean the tool tray, but I'd removed the side covers anyway. Then "lift off the fuse box" - it took me a while to figure out HOW it was secured - Picture shows the part to press with a thin-bladed screwdriver to allow it to be lifted away from a small bracket.
[Image: c4521e607f8a32d429f291ce0882fe14.jpg]
Pushed to one side, that permits the rear stop/tail light wire to be disconnected. The correct wire needs to be separated from the left and right indicator wires and the seat lock cable.
[Image: 41dad01815ef80dfbbaafee8f8dd5c7e.jpg]
It took me a moment to work out what part of the connector needed to be pushed/pulled to separate them. The handy little screwdriver blade shows where to press.
[Image: 78b1744b127ba69cd84fc7788532b3f1.jpg]
The grabrail needed to be removed (it's damaged but it makes wiring access easier if removed). Secured by simple 12mm bolts EXCEPT the 6mm hex bolt head has the centre filled with a shaped piece of rubbery plastic. It was not easy to dig it out - a screw helped, although it marked the surface. If I did it again, I'd try a piece of stiff wire on the edge to avoid damage.
[Image: e3276d5117d4c38f44a32c7c7fa1bef0.jpg]
Four 10mm nuts and two bolts hold the mudguard to the frame and it lifts off of two small "tongues" inserted in the plastic at the front - don't forget to locate these when replacing the mudguard. Two "collars" are inserted in the lock moulding where the two bolts pass through and they proved problematic on reassembly, so i resorted to holding THEM in situ with gaffer tape until the bolts had located them. I also temporarily secured the two halves if the lock mechanism together with gaffer tape until bolted up - it made the whole job easier. It needs two pairs of hands otherwise (I wonder how they do it in the factory? Smile ).
[Image: 70460b3d7d79ae8676c1fe67a287b82b.jpg]
[Image: 11c3404905919129f93b577d6bc8d959.jpg]
[Image: c1b3e78e92b69c4ff167b39034c495fe.jpg]
I was shocked at the amount of, admittedly low-level, rust evident under the old mudguard on what is a virtually brand new 'bike - just 165 miles on the road. It wasn't stored in damp conditions either.
[Image: 5b05a577d4df36a77a8cb45da2f55531.jpg]
[Image: 5375c1c42a9b4394158fb6720ec03dab.jpg]
So I've run ACF50 underneath the new mudguard, spraying and brushing it, and allowing gravity to get it to run under welded pieces and folds where rust WILL start (in a UK climate!). Before I fitted the still-dripping mudguard, I covered the rear tyre with a cloth and cleaned the odd drips with brake cleaner.
[Image: 7e49ba0a664e2e788c9b017a19d8f9a9.jpg]
[Image: fe498b4a55914b7b7a0e3845c1a41e59.jpg]
Success - the new mudguard in place.
[Image: dc78ebb067eb63ff9bb40090f333d4de.jpg]
Running the rear stop/tail light wire down into the dedicated "tunnel" on the underside of the mudguard was made easier because the connectors on the end had been ripped off in the accident, so just three wire ends needed to be poked through the hole under the lock. I'd already secured the mudguard before I realised this step was needed, so I released one securing bolt and loosened the other to give sufficient "wiggle room" to push the wire through. Three holes need to be drilled to secure Samurider's CB750 replica tail light assembly.
[Image: f88b49056399049e1019413fd9156fc4.jpg]
After drilling the holes, I need to obtain an oval grommet or boot to protect the tail light wire as it comes out of the mudguard. I also need some grommets to lift the rear light and permit the wire to enter. I hope my Honda dealer will help here.
I also need to peel off the underseat stickers on the old mudguard and reattach to the new one. I'll try a hairdryer and see if that works.
06-16-2019, 05:03 PM
Threads: 349
Likes Given: 1,030
#60
Progress. How exciting. Beer Excellent writeup Bazbro.
06-16-2019, 05:30 PM
  Gauge Mods Seancampbell777_imp 11 1,203 10-16-2024, 04:14 AM
  Short mods list and experience with each for those considering. Motomike7_imp 6 637 04-07-2023, 11:34 PM
Last Post: 1973cb750
  2 small mods until the weather changes inditx_imp 10 1,067 01-02-2023, 10:31 AM
Last Post: inditx_imp
  Mods to OEM seats? 2014ltdltz 7 824 07-05-2022, 05:56 AM
  Best suspension mods? gretle_2.0 6 620 05-10-2022, 06:25 AM
  Winter Mods finished, time to ride! Phadreus_imp 3 546 05-02-2022, 10:08 PM
Last Post: Phadreus_imp
  Mods Mods Mods Latinrudeboi13_imp 12 1,057 08-23-2021, 01:11 PM
Last Post: Rox_imp
  Mr.P's CB mods, mark II misterprofessionality 18 1,537 05-21-2020, 06:45 PM
  New Mods 89gaz89_imp 1 334 05-15-2020, 08:08 AM
  Newly Purchased 2013 With some Mods HigginsNYC_imp 26 2,129 03-14-2020, 12:02 AM
Last Post: Cobalt23_imp
