05-09-2017, 01:55 PM
It's a fairly hefty thing. It says it can deal with 100mm which I take to be 100 mm diameter. It seems pretty effective to me.
The dumbest question I've ever been forced to ask
05-10-2017, 01:20 AM
(05-09-2017, 01:55 PM)Cormanus_imp Wrote: It's a fairly hefty thing. It says it can deal with 100mm which I take to be 100 mm diameter. It seems pretty effective to me. I use the boa in the kitchen when Penny can't get a lid off a jar. Those big vacuum sealed spaghetti sauce jars are the worst. The oil filter on my CB500XA was far worse than those jars. On the CB500 Forums riders complain about the Thais using gorillas or sumo wrestlers to tighten things down. I have never had a motorcycle that was so difficult to remove a simple screw, bolt or oil filter as this one. I had to buy an impact driver to remove the screws from the handlebar weights.
05-10-2017, 07:27 AM
Rather than the boa, try tapping gently around the edge of the lid with the edge of a knife and then turning the lid.
03-10-2021, 05:36 AM
Seems like I’m digging up an ancient topic. My filter is jammed on tight.
Cap type slipped and rounded the filter edges. The rubber strap types will not bite, and the same with the chain types. They both just slip. I’ve ordered the filter wrench and hope this will get this filter off. Judging from this topic seems like they have arm wrestlers fitting the filters. Sent from my iPhone using Tapatalk
03-10-2021, 05:48 AM
The filter wrenches will very easily remove the filter , good ones only $10-$15 .
I heard that the Samurai wrestlers train at the Honda plant putting oil filters on bikes , could be a hoax ?
03-10-2021, 06:53 AM
(03-10-2021, 05:48 AM)Houtman_imp Wrote: The filter wrenches will very easily remove the filter , good ones only $10-$15 . Yeah hopefully will find out tomorrow. Then a bit of oil and hand and a bit tight. Wrestlers, Sound legit. Sent from my iPhone using Tapatalk
03-10-2021, 08:33 AM
NAPA used to sell a strap wrench that would remove any oil filter. It is like a strap wrench but you use it with a half inch ratchet wrench. I once tried to remove the oil filter on a Kawasaki Mule that seemed to be "welded" on. A proper sized filter wrench rounded off the flats on the filter. Filter wrench pliers collapsed the filter without budging it. I called a friend to help and he brought his secret weapon, the NAPA strap wrench and a half inch breaker bar; took it off gripping what was left of the collapsed filter.
03-10-2021, 11:07 PM
Well looks like the filter wrench did the job. That thing was on tighter than it should have ever been.
03-11-2021, 12:42 AM
good deal. Shouldn't be an issue next time around. Hand tighten only.
03-11-2021, 02:42 AM
« Next Oldest | Next Newest »
| Probably the dumbest question ever... | PowerDubs_imp | 10 | 758 |
10-11-2020, 11:50 PM Last Post: Roper_imp |
