wonder battery
#51
(12-03-2023, 08:39 AM)GoldOxide_imp Wrote: When the Nach laughs, for a moment all is good in the world.
Thumbs UpBeer
...and I even felt that little tsunami here in So/Ontario, CAN
Beer
Beer
Beer Cheers, my friend Beer
I also have the factory battery in my 2014, no issues I just leave it in the trickle charger when not in use
(12-07-2023, 01:22 AM)m in sc_imp Wrote: as a follow up, I received the battery tester MAX referenced and played with it a bit last night. It is a very good unit, for sure. would recommend if you wanted to do some testing.
Good to know, thanks for sharing !!
I've always removed my battery for the winter and left it on a Tender inside. This winter, I decided to leave the battery in the bike in the garage on a Tender. We had a warm day recently, so I thought I'd take a ride....not enough from the battery to crank the engine. BTW, the Tender had a green indicator. It's an aftermarket Firepower Battery that was in the bike (2014 Standard) when I got it three winters ago. There is such a wide variety of prices for batteries. I went for a Mighty Max AGM for $45. It arrived DOA....Tender was properly attached, but the light just blinked red. I thought the battery voltage was just too low. Props for Mighty Max....I emailed them and described the problem, and they refunded me and didn't ask for the battery to be returned. So it's back to the drawing board. Thinking Motobatt...bought one for my last CB750. Seemed OK.
Comments?
Two strange observations in a row ? The tender shouldn't have shown a green light with the old battery (when it did - as I understand), AND it shouldn't have shown a red blinking light with a new (always pre-charged) battery. That is one too much, makes me think the tender has a defect.
Put that generous "gift" battery from Mighty's on a volt meter, if need be charge it with a non-intelligent, old-style, non-AI charger for 12 V, with a charging current of max 500mA for 10-15 hours, and check again. Just my 2cts.
Was actually thinking about that...thanks for the suggestion.
(02-18-2024, 09:35 PM)Wagonpeddler_imp Wrote: I've always removed my battery for the winter and left it on a Tender inside. This winter, I decided to leave the battery in the bike in the garage on a Tender. We had a warm day recently, so I thought I'd take a ride....not enough from the battery to crank the engine. BTW, the Tender had a green indicator. It's an aftermarket Firepower Battery that was in the bike (2014 Standard) when I got it three winters ago. There is such a wide variety of prices for batteries. I went for a Mighty Max AGM for $45. It arrived DOA....Tender was properly attached, but the light just blinked red. I thought the battery voltage was just too low. Props for Mighty Max....I emailed them and described the problem, and they refunded me and didn't ask for the battery to be returned. So it's back to the drawing board. Thinking Motobatt...bought one for my last CB750. Seemed OK.
Comments?
I have had the same experience with mighty battery for other motorcycle and quads.
One the battery was dead inside of a year with proper use. The second the positive terminal had a crack running through the epoxy that seals it to the battery.
Unless its a cheap atv or something I try to avoid them now.
  ABS , speedometer and battery Walter 10 790 05-02-2026, 01:29 AM
Last Post: Walter
  Yuasa Battery Life dave 28 2,516 04-01-2026, 04:44 AM
  Rattle on right side exhaust / battery CB1100i_imp 4 677 04-18-2025, 02:48 AM
Last Post: CB1100i_imp
  Battery jumper the Ferret 14 1,083 10-28-2024, 10:58 PM
  CB1100 SA-E 2017 Battery Davidjill_imp 1 276 08-01-2024, 02:33 AM
  Could old/low battery trigger misfire and engine light? Motorsport3_imp 13 1,226 12-17-2023, 08:41 AM
Last Post: Jgarciajr40_imp
  Replacement Battery dave 54 3,964 02-04-2023, 12:41 PM
  Winter Battery Maintenance Wagonpeddler_imp 27 2,161 10-18-2022, 01:55 AM
  dead battery louied_imp 62 4,238 10-16-2022, 03:48 AM
  Battery Question KiowaEagle_imp 49 3,721 01-31-2022, 04:09 AM
