Gaitors for front suspenders - opinions?
White Dog_imp Offline
Threads: 59
RE: Gaitors for front suspenders - opinions?
#41
The Ferret has the best looking gaiters of any I've seen. I seem to recall him saying they were a Triumph part. Expensive, but a man of his means ...
11-23-2016, 02:09 PM
Retsel_imp Offline
Threads: 24
#42
They are kawasaki. Go here for part number and instructions.
http://cb1100forum.com/forum/showthread.php?tid=3289
Sent from my XT1096 using Tapatalk
11-23-2016, 02:30 PM
Olyrider Offline
PNW
Threads: 23
#43
I don't know if Ferret's gaiters are actually made by Kawasaki or not.
The gaiters on my CB1100 are made by Triumph, and are quite nice. Very well-made in fact.
And I believe they were quite a bit less expensive than the Kawi gaiters. I'm sure that the part #s and info were gleaned from this forum somewhere.
11-23-2016, 02:47 PM
Retsel_imp Offline
Threads: 24
#44
Yes, the part numbers are from a post by Ferret. With instructions on installing them. I just did it myself. Bought them from Dime City Cycle. They are high quality.
11-23-2016, 03:12 PM
Threads: 59
#45
The gaiters I bought last year from Revzilla are 41mm dia but the outside diameter of the bellows is 3 1/4" dia. and length is 7 1/4" relaxed. I'll be selling these once I get my new ones installed.
Ferret what does your CB1100 Kawa gaiters measure?
11-26-2016, 01:48 AM
Threads: 698
Likes Received: 623 in 279 posts
Likes Given: 789
#46
White Dog I can't measure free length because they are on the bike, so somewhat compressed by weight of bike, but they measure 5 3/4" on the bike top to bottom and a pleat in the middle measures 2.60" or just over 2 1/2" in diameter (not circumference)
11-26-2016, 02:40 AM
Threads: 59
#47
(11-26-2016, 02:40 AM)The ferret_imp Wrote: White Dog I can't measure free length because they are on the bike, so somewhat compressed by weight of bike, but they measure 5 3/4" on the bike top to bottom and a pleat in the middle measures 2.60" or just over 2 1/2" in diameter (not circumference)
Definitely smaller (and better looking on the bike). My length measurement was also on the bike. Revzilla says they will stretch to 10".
11-26-2016, 02:48 AM
Blockhead_imp Offline
Threads: 7
#48
(11-23-2016, 02:47 PM)Olyrider_imp Wrote: I don't know if Ferret's gaiters are actually made by Kawasaki or not.
These are the same ones the Ferret has and yes they are Kawasaki, cost around $100. His tutorial on installing was excellent.
[Image: 8a393bc0f58375bb6399a1014fc7ab85.jpeg][/URL]
11-26-2016, 10:33 AM
Lord Popgun Offline
El Supremo RLET Force
Virginia
Likes Given: 142
#49
Here is a thread with the Triumph numbers: http://cb1100forum.com/forum/showthread....ph+gaiters
11-26-2016, 11:13 AM
Honda Lover_imp Offline
Threads: 4
#50
I purchased the Kajima Gators 2 years ago. A few thoughts:
1. While certainly easy to install and took very little time, I did find in addition having to use additional zip ties then what was included with the gators to keep the lock seams together, I used cement glue on the actual lock seams....otherwise over time they would begin to separate in the rear along the seams.
2. I will say so far the Kajima's do hold up well. They are constructed of thick rubber and do not feel flimsy in the slightest. No signs of visual wear. I've been riding with them for 7k miles so far. Also, there is no corrosion on the forks underneath. I do make it a habit of checking underneath during the winter months and use chrome polish to protect against any potential moisture build up that could damage the forks...
3. The bottom of the boots are about 1/4 inch longer compared to a traditional gator install. If I was to install again, I might re-consider trimming along the bottoms a bit. I initially elected not to as I was concerned they would appear cut and not look as close to an OEM install as possible.
4. When all is said and done, while I'm ok with the Kajima's, I plan at some point to install a set of the Kawi gators. [Image: be99681cff20f443a2c7edb698599dc8.jpg]
11-27-2016, 12:16 AM
  Fork gaitors on E bay. hondadownunder_imp 15 1,145 06-29-2022, 03:27 AM
Last Post: 2017EX_imp
  Fork Protectors, an alternative to Gaitors? Tev62 22 1,645 05-12-2021, 03:16 AM
  honest opinions: lowering a CB1100 misterprofessionality 76 4,717 07-27-2019, 12:06 PM
Last Post: Nightengale_imp
  Accessory mod opinions please dsinned_imp 14 1,008 11-26-2016, 01:59 AM
Last Post: White Dog_imp
  Opinions please on Delkevic 8" CF slip on exh dsinned_imp 12 882 07-03-2016, 01:51 AM
Last Post: Motogeezer1949_imp
  Gaitors Baaybeeey !!! lash_imp 10 754 06-04-2016, 03:48 PM
Last Post: TINK_imp
  Need tire setup OPINIONS - a few different options Ferrealls_imp 7 618 06-25-2015, 10:02 AM
Last Post: Ferrealls_imp
   Honest Opinions Please StreetFighter_imp 19 1,409 06-20-2015, 06:53 AM
Last Post: Seabee_imp
  Decal opinions wanted... Rebel73_imp 22 1,760 04-15-2015, 07:26 AM
Last Post: Papa Weeley_imp
  Worn gaitors! mjvielle_imp 7 565 08-21-2014, 05:16 AM
Last Post: mjvielle_imp
