Crash bars make me crash
#41
I used to run SW MOTECH crash bars just like these. I only managed to drag them a few times on tight uphill mountain curves (RIP THE SNAKE)
I wouldn't worry too much about them. I eventually swapped them out for more low profile sliders though. Get your center of gravity off the bike in aggressive corners and you won't scrape.
They DID save my leg when a Prius drove into me head-on though, so props to big crash bars.
(04-13-2020, 07:07 AM)mattvoyle_imp Wrote: I used to run SW MOTECH crash bars just like these. I only managed to drag them a few times on tight uphill mountain curves (RIP THE SNAKE)
The main reason I wanted a set was to mount highway pegs really. I have had a bike before that had them mounted onto the frame that were very handy and not in the way at all.
Just to be clear to everyone, I meant to not use the Kajima ones. The others have had no complaints and as Matt said, saved his leg! I am not against them Smile
Back in the ‘70s I had those crash bars that were kind of one big rectangle that bolted to the frame. At least they looked ok, not like those Japanese Police ones for our bike that looked goofy. Those are not available anymore, IIRC.
I reckon it's sad that the big old-fashioned ones are no longer available. Sad
(06-04-2014, 03:56 AM)cosmos_imp Wrote: Ok, title may be a little dramatic but here's my little story. Ordered some Kijima engine guards from webike, only took 5 days from Japan so I was pretty excited.
http://japan.webike.net/products/9450147.html
Straightforward to put on, even with Japanese instructions, although I did break one of the two supplied bolts which didn't impress me much. Something new on the bike obviously requires a test ride, right? Great day, 70 degrees, partly sunny, nice day for a ride. Headed to some nearby twisties, not to actually test anything but just because it's fun. About halfway through the twisty part came into a yellow signed 35mph hour at about 50-55, fast enough to be fun but not exactly speed demon stuff. Halfway through the turn I started to scrape. First thought was footpeg, wasn't expecting it but there it was, no big deal. But it wasn't just scraping, it felt like it was digging and really unsettling the bike. I came up a bit but that wasn't going to work so went back down. I had probably let off the gas so that was the beginning of the end. I was heading for the gravel on the outside and didn't want to hit that leaned all the way over so plan B. Came back up, maybe I could still stay on the side and slow enough. Nope. Plan C, fairly shallow ditch just try to stay on while slowing. Worked fairly well but went over the handlebars right at the end. Picked up the bike and gave it a once over, no real damage just broke a mirror off. Started it and rode down the ditch a few feet til I could ride out then went down the road a bit to a pull off. Looked over it more carefully and cleaned out some mud but basically nothing had been damaged or even scratched. Rode home a little embarrassed and deflated but no worse for wear. After it was parked I looked at the footpeg and didn't see any scaping, kept looking around an saw this
[Image: ecd2fff0fed71ea7dd6afac0e93f5065.jpg]
[Image: fe4988fa7c9851036191faf53b372f24.jpg]
Ok, they didn't really cause the crash, I could have handled it better, maybe I should have known better, maybe it's common knowledge the things stick way out, I should have thought....blah blah blah.
Anyway, learning experience, they are coming right back off, and for anyone else unaware like me, you've been warned!!!
Hi, I installed some SW-Motech Crash bars on my 2013, and similar ones from China on my 2017, a couple months back. I do not lean it like my Z900RS, but do corners leaning what feels good, and have never touch either bike's bars on the ground. I am leaving them because in the past I had them save the engine on my old Suzuki VS1400 Intruder years ago.
Ive got the OEM Honda bars on my 2014. My place in Ak is on a dirt road up a steep hill. I got them to save the side cases on the engine. That road is a pis*er. The cb is no lite weight and I am pushing 70.
I enjoyed quite a few twisty mountain roads while in Ak last year. No problems with the Honda bars, the Ak State Troopers not so much!
I have engine guards on my bike, and have never scrapped them - I have scrapped the foot peg feelers on both sides - more than once.
(04-18-2020, 04:05 AM)Dave_imp Wrote: I have engine guards on my bike, and have never scrapped them - I have scrapped the foot peg feelers on both sides - more than once.
Hi, I agree. As I posted, both of my CB's have either the Mo-Tech or the Chinese copy. Both work well and should be almost impossible to scrape unless you are leaning like Valentino Rossi on a World Class Super bike. The original post about crashing must have bars that really stick out or are too low. I will not remove mine because I know from past experiences, they save engines. Michael
  Do they still make motorcycle commercials? pdedse 6 579 09-11-2022, 08:53 AM
  Crash Bobbins or bars Maturecheese_imp 14 942 07-04-2022, 02:29 PM
Last Post: run-tmc_imp
  Rust on tank from crash calipo223_imp 6 605 09-17-2020, 05:06 PM
Last Post: jtopiso_imp
  How to make the CB1100rs perform better Saltani_imp 26 2,104 12-15-2019, 04:07 AM
  Just purchased 2013 CB1100. Buzzy Bars ambbmw_imp 14 1,175 02-18-2018, 11:59 PM
Last Post: Marcosss_imp
  Had a small crash jermo47_imp 17 1,112 09-25-2017, 10:37 AM
Last Post: dsan1964_imp
  Crash Bars for an other bike activedirt_imp 0 193 08-18-2017, 02:26 AM
Last Post: activedirt_imp
  Engine Guards / Crash Bars RonLyke_imp 93 6,918 06-02-2017, 09:55 AM
  Any interest in sissy bars? PowerDubs_imp 85 4,670 05-15-2017, 01:11 PM
  How Are New Bikes Handle Bars Positioned Aka Tsubasa_imp 19 1,274 05-14-2017, 10:24 AM
Last Post: BestStandard_imp
