12-06-2013, 10:23 AM
Fill the tank to the point described in the owners manual then siphon the tank and see what that measures. Next person to take their tank off could do this. Shouldn't take no more than an hour.
What does each bar on the fuel gauge represent? Miles or fractions of gas?
12-06-2013, 11:03 AM
(12-06-2013, 05:42 AM)The ferret_imp Wrote:(12-06-2013, 05:33 AM)Deanohh_imp Wrote: It wouldn't do much good for the gage to tell you when you were really totally empty. By then you would have run out of gas. That may have been me. I've put in 3.6 gallons on two occasions. Both times there was still a bit of fuel sloshing around in the bottom of the tank, but not much.
12-06-2013, 11:23 AM
(12-06-2013, 10:23 AM)kenfyoozed_imp Wrote: Fill the tank to the point described in the owners manual then siphon the tank and see what that measures. Next person to take their tank off could do this. Shouldn't take no more than an hour. but will the fuel pump pump it all out? Should start it up and run it til engine dies. Any gas left in after that doesn't count.Then precisely measure what goes back in until filled to bottom of filler neck.
12-06-2013, 11:26 AM
We need a volunteer...anybody?
12-06-2013, 11:29 AM
I still say someone with that fancy case on their bike fill up full, ride until you run out of fuel then take a one gallon can out of that case and get yourself to the next gas station. Then report back here your mileage and how much gas you put in.
Do if before you start you know you have a full tank how far can you go? How far can you go on the flashing fill me up indicator before running out of gas? Sent from my Nexus 7 using Tapatalk
12-06-2013, 11:49 AM
Will it creat issues if you run the tank dry? Or to the point where it can't pump any more fuel?
Sent from my iPhone using [url=http://tapatalk.com/m?id=1]Tapatalk
12-06-2013, 12:36 PM
The EFI system has to be pressurized with fuel. After it's run dry and refilled, you should turn the key on and let the pump repressurize the system before trying to start it. It'll probably take a little longer than normal to purge the air from the system.
12-06-2013, 01:18 PM
Got snow at my house, April of 1996. That would be northern Phoenix. Getting down to freezing the last few nights; locals are whining up a storm! On topic, I fear I'll find out by accident.
12-08-2013, 09:32 AM
(12-06-2013, 05:42 AM)The ferret_imp Wrote:(12-06-2013, 05:33 AM)Deanohh_imp Wrote: It wouldn't do much good for the gage to tell you when you were really totally empty. By then you would have run out of gas. I put in 3.954 gallons, but that was done by topping it off and letting it settle down a few times. Here's the old thread. http://cb1100forum.com/forum/showthread.php?tid=1176 Note that the silly filly game is not without risk to the emissions system and is not recommended. Since then, I've run it dry, that is, the engine died while idling at a light on level ground, with a gas station in sight, about two blocks away. I rocked the bike and was able to restart and sputter to the station for a fill. From memory, it took about 3.6 gallons, but I didn't play the silly filly game, either. I don't know what anyone could or should conclude from that, but that's what happened and I thought I'd share it.
12-08-2013, 10:48 AM
Oh yea Rolls, I remember that thread. Any long term issues with over filling your bike? Do you still do it?
I didn't remember popgun filling a dry tank and it tanking 3.5 or 3.6 gallons. |
« Next Oldest | Next Newest »
| 20K miles: how this chain looks like? | valkyrie_rider_imp | 12 | 983 |
02-09-2024, 03:06 PM Last Post: valkyrie_rider_imp |
| What Gauge Wire? | HondaFan_imp | 5 | 511 |
11-30-2022, 10:43 AM Last Post: GoldOxide_imp |
| Pirelli Angel GTs at 5,000 miles | the Ferret | 66 | 6,014 |
11-02-2021, 12:16 PM Last Post: NovaCB1100_imp |
| 2.8 miles | the Ferret | 8 | 630 |
08-23-2021, 12:05 PM Last Post: rboe |
| Anybody looking for a 2013,230 miles? | FLYTYM_imp | 3 | 352 |
05-28-2021, 04:40 AM Last Post: boynton6spd_imp |
| Gas Gauge Accuracy? | Yata-Garasu_imp | 10 | 789 |
04-26-2021, 03:13 AM Last Post: GoldOxide_imp |
| 100 miles in..1st impression | Scoot_imp | 20 | 1,705 |
04-08-2021, 05:19 PM Last Post: Tev62 |
| 100,000 miles on a CB? | AlexCB_imp | 21 | 1,712 |
03-22-2021, 04:57 AM Last Post: Charlie Bravo_imp |
| How many miles.... | Randy B | 53 | 3,448 |
02-10-2019, 11:48 AM Last Post: GoldOxide_imp |
| 100.000 miles on a CB 1100 | itsme67_imp | 31 | 2,273 |
06-05-2018, 08:27 AM Last Post: peterbaron |
