Threads: 28
Likes Received: 6 in 2 posts
Just an update. I'm no longer looking for a Z900. Not because I bought one, but because I just had a surprise airplane engine expense. The cost to get me back in the air just happened to be exactly what my budget allowed for the new bike.
Looks like the old CB750 will just have to soldier on for another year as my second bike. On the bright side, it might be easier to find a good deal on a lightly used Z900 in another 10-12 months.
Likes Received: 576 in 259 posts
Likes Given: 756
Jeez musta been an expensive repair on the plane. Too bad. Unexpected repairs stink.
Threads: 28
Yep. Generally, all plane repairs are expensive, but the engine troubles are the worst. Only to be surpassed by surprise engine troubles.
Likes Received: 575 in 312 posts
Likes Given: 962
Don't know much about planes in general but assuming multi cylinder engines, repair cost is not cheap for sure...not to mention other sections.
Good luck with your repair  Would be curious to hear what was wrong, especially if related to the engine.
Threads: 28
(10-26-2018, 10:46 PM)peterbaron_imp Wrote: Don't know much about planes in general but assuming multi cylinder engines, repair cost is not cheap for sure...not to mention other sections.
Yep. Like the CB1100, my airplane engine is a 4 cyl. air cooled engine.
This is related to an incident I had back in August. The propellor hit a raised sprinkler head at a grass airstrip. Regulations require that the engine is torn down inspected for internal damage. After disassembly, it was deemed prudent to go ahead and do a full engine overhaul instead of just reassembling with worn parts.
Insurance covered about half of the cost, but I was on the hook for about $10.5K, which happens to be exactly the amount I'd set aside for the Z900.
Likes Given: 756
Cool.... Looks like a super BMW flat twin
Threads: 25
Goodness....that's scary...you could have had problems "in the air".....!
Threads: 28
(10-27-2018, 12:21 PM)The ferret_imp Wrote: Cool.... Looks like a super BMW flat twin
I always think of 'em as looking like an oversized air cooled VW. That one is a 360 cubic inch (4260 cc) and makes about 180 hp.
Quote:Goodness....that's scary...you could have had problems "in the air"
I wasn't too worried about it. The small sprinkler head has very little mass and the engine was idling, so I didn't expect them to find any actual engine damage from the prop strike (which they didn't). Since the sprinkler put a couple of dings in the prop, tear down inspection was mandatory.
Likes Given: 962
(10-27-2018, 11:14 AM)Flynrider_imp Wrote: (10-26-2018, 10:46 PM)peterbaron_imp Wrote: Don't know much about planes in general but assuming multi cylinder engines, repair cost is not cheap for sure...not to mention other sections.
![[Image: ff272f6b4a44b29cc51154547e631ae6.jpg]](https://cb1100forum.net/forum/uploads/imp/201810/ff272f6b4a44b29cc51154547e631ae6.jpg)
Insurance covered about half of the cost, but I was on the hook for about $10.5K, which happens to be exactly the amount I'd set aside for the Z900. Yep. Like the CB1100, my airplane engine is a 4 cyl. air cooled engine.
Thanks, looks very simple 4 cyl boxer with pushrods. Does it have 1 or 2 plugs per cylinder, with multiple ground electrodes ?? When I was a kid my father used to bring me such long plugs with screw on ignition cables.....a few of them I had in my 50cc...
I know from many articles that small plane regulations are very strict..small cuss = big back$.
Good luck with your repair, always have safe flights & rides
Threads: 28
(10-28-2018, 03:53 AM)peterbaron_imp Wrote: (10-27-2018, 11:14 AM)Flynrider_imp Wrote: (10-26-2018, 10:46 PM)peterbaron_imp Wrote: Don't know much about planes in general but assuming multi cylinder engines, repair cost is not cheap for sure...not to mention other sections.
There are 2 plugs per cylinder and each plug is powered by a separate magneto (for redundancy). The plugs have dual electrodes and the cables are screwed on an secured with a nut.
