Really high idle
#41
Dave commented:
"This problem would come and go completely unpredictably - it did NOT appear every time the bike was ridden."
Hmmm.... Is this problematic to Max's theory about heat affecting the magnets?
I still think it may be some kind of binding problem. Maybe only showing when tightened down. IDK.
Yes, you thought about that early on and we did kick it around.
http://cb1100forum.com/forum/showthread....#pid264896
But Dave's post 1242 did not seem to support that theory... not that I have a better one.
http://cb1100forum.com/forum/showthread....#pid290491
Here are links to the posts (846, 833, 775) referenced in the top link above:
http://cb1100forum.com/forum/showthread....ht=Binding
Gordo, Here's the link to Dave's post number 911 with his disassembly photos:
(10-05-2021, 06:55 AM)Lord Popgun_imp Wrote: I don’t think there is a manual on-line, but maybe there is and someone will post up.
Basically the manual has you disassemble the rear end of the bike, moving forward until you can get to the airbox.
But there is another way. Check out this post with pics: http://cb1100forum.com/forum/showthread....#pid291066
Good luck with it if you have no manual. You need one.
Grrrrreat! Thx I appreciate the link as well. When Enzo did his, it looks as though he did not have to remove the rear wheel. I'll try that way first
Replying before clicking the link! UNBELIEVABLE![Image: f646e57cafcac7bb8db9055635c98547.png]
Titus 2:13
2013 HONDA CB1100
So....I dont have the manual to do this repair so I'm flying blind here. I've got this far, but I'm having trouble removing the air filter box. The box before it I believe has more than 5 screws it and I cant access it with this box in the way. It appears there is some sort of strap, but cant find any way to loosen it. Any help would be great
Thank you
Titus 2:13
2013 HONDA CB1100
(10-10-2021, 04:29 AM)Gordo_imp Wrote: So....I dont have the manual to do this repair so I'm flying blind here. I've got this far, but I'm having trouble removing the air filter box. The box before it I believe has more than 5 screws it and I cant access it with this box in the way. It appears there is some sort of strap, but cant find any way to loosen it. Any help would be great
Thank you
Titus 2:13
2013 HONDA CB1100
I strongly advise you to get a shop manual , so useful when you do your own repairs etc.
Yup.......
Titus 2:13
2013 HONDA CB1100
Gordo maybe you can Personal Message enzofour , he is in Italy i believe.
To do this goto popgun's link and click on "enzofour" in the red text above his avatar.
To my knowledge he has not revealed the secret sauce to remove the airbox but you may have more success.
I'll give that a try. I've been at this since 1pm and cant figure this out.
Titus 2:13
2013 HONDA CB1100
Hi,
I am from Singapore and my 2014 CB1100 EX used to have low idling problem. I have replaced the IACV using 16430-MFJ-D01 but my low idling problem came back a few weeks later. I replaced my IACV again, this time using 2017 part number 16431-MGZ-D01 and I have not encountered any low idling problem for more than a year now. Anyone know why Honda changed IACV part number from 2017 onwards when the throttle body part number remained the same for all CB1100 models?
  CB1100 Idle speed instability problem ericlo69_imp 1,434 114,148 07-26-2026, 01:51 AM
  idle problem update 1973cb750 37 1,891 05-12-2026, 08:38 PM
Last Post: rdprdp01
  'Factory' high performance spark plugs PowerDubs_imp 17 1,448 10-23-2024, 02:50 PM
Last Post: rtmoto1
  Idle a little rough and miss fire when revved johnnyH_imp 3 395 09-15-2024, 12:16 AM
  High engine revs on start up CBX1000_imp 21 1,716 06-06-2024, 02:40 AM
  another idle thread Tom_imp 11 907 11-20-2023, 01:30 PM
  TPS Sourcing because of High Idle Obi-wan Kenobi_imp 38 2,473 09-14-2023, 10:08 PM
  Honda CB1100 Rough Idle Solution dickie1951_imp 56 3,930 09-06-2023, 01:36 AM
  About the problem of high idling. (2014 cb1100ex) DDUMZI_imp 62 4,387 08-02-2023, 05:38 PM
Last Post: DDUMZI_imp
  High mileage and oil consumption Jurlie_imp 24 2,021 04-07-2023, 06:05 AM
