Another High Idle Problem
#41
Nice work MTC, like yourself i am glad this went without too much hassle, service seems prompt and accurate.
Hope you still have the old unit, you just never know and you did pay for it, remember?......
cuss. Forgot to take it. I’ll see if they still have it. Totally forgot.
(12-04-2020, 01:20 PM)GoldOxide_imp Wrote: Any machine behaviours that are improved or old ones missing since the ECU transplant?
Seemed normal for the 12 miles I rode. Big improvement over when the idle was high, though. Hope to ride a bit tomorrow and a bit more on Sunday. I don’t anticipate much change from what I’m used to, but there might be a little change as it learns my Yosh exhaust. We’ll see
(12-04-2020, 02:27 PM)EmptySea_imp Wrote: cuss. Forgot to take it. I’ll see if they still have it. Totally forgot.
Sounds like good news.
RE old ECU: A quick phone call to the shop should help quickly sort that out.
I'm pleased to hear you're reunited with your steed, MTC. Enjoy it.
@MTC really happy for you !!
Did you learn anything in the process about whether ECU's are model specific or all the same ?
(12-01-2020, 05:16 AM)Houtman_imp Wrote: I am very happy that your problem does not cost you a fortune , pleasures in life cost money.
I would call it "the pleasure in life which we have adopted in our culture cost money". Why ? Because anything you create yourself, you design, you build, you test and use, can do much better. But we have deliberately installed bumpers along that way. Angel
(12-04-2020, 01:24 AM)Houtman_imp Wrote: And you do not want to be the richest man in the cemetery.
I'd like to be at around minus a million and a half that day, but this can't be done without life insurance Big Grin
If however I could ask everybody in the country for a small donation, with a small percentage going to my lawyers, an most of it for my own projects, such as ECU's and more, ... what a field day !
Matt, I'd like to know if you still have your old ECM ?
(11-30-2020, 08:19 AM)peterbaron_imp Wrote:
(11-29-2020, 10:21 PM)EmptySea_imp Wrote: My bike is already taken to someone — it’s in the shop now, presumably with the old ECU removed. Also, I don’t know how to perform the reset that you describe. I have no doubt that it’s within my abilities, but my comment about asking the tech to do this was because I have neither the instructions nor the bike in my possession at this time.
You can do it, it's DIY without any special tool:
* If possible warm up the bike to get normal operating temp and idling (not necessary)
* Ignition OFF/key out from the ignition switch
* Disconnect both battery cables from the battery terminals, the negative cable first.
* Cover both battery terminals with a plastic bag/rag to prevent accidental cable to terminal reattachment.
* Join both cables (- &+) together for about 10 minutes. If the battery cables are too short, jumper wire can be used.
* Reconnect both cables back to the battery terminals, the positive cable first, then the negative.
* Ignition ON, wait until meters sweeping is completed 2-3 sec, start your bike and observe idling......
* Ignition ON, wait until meters sweeping is completed 2-3 sec, start your bike and observe idling...... Peter, I can't say for certain that you solved my high-idle problem, but it looks good at this point.
I had exactly the same problem on my '13 that MTC describes. Started a few months ago before it got hot here. So today I ran your ECU reset as described above and went for a ride. Bike ran as it is supposed to. Ambient air temp at around 96F and it was a relatively short ride, but enough stop and go to learn that the idle stayed at around 1200 to 1400 and never went up to 2000. This is very different from a few weeks ago when it would go to 2K when I stopped at the first stop sign a half mile from my house and repeat for the entire ride.
How could it be that simple? I hope it is. Also highly recommend this approach for any who have the high-idle problem.
PowerDubs, you were right, but this looks a little less expensive than replacing the ECU. Of course, if I were running a shop, I'd recommend that my mechanics replace the ECU just for liability protection.
Thanks again, Peter.
Frank, any MPI component is replaced or disconnected, battery replaced or disconnected, ATM or engine replacement should have reseting residual values performed.
Some vehicles are more or less sensitive, some are not at all.
Would like to hear your feedback after riding or driving for at least few drive cycles and several ignition cycles if permanently cured.
This is not a repair, but a simple reset without any special tool that anyone can do at home at no cost.
If a MPI component is defective and needs replacement this procedure is not a substitute but should be performed after.
At work, I use a special tool that can do this procedure within 10 - 30 seconds., for an engine or/and transmission.
Beer
Peter, thank you for the follow-up. I will post as I go along about how it is going. Don't expect too much until after September, as it is too hot to ride much right now, at least for me. When I get up about 0430, it is usually about 80-85F, but by the time I go for a five mile walk and have breakfast, it is 92-95 and I don't enjoy riding much at those temperatures. Then it warms up. Also, I am not sure what effect the high temperatures have on the idle. This procedure is good to know when disconnecting the battery or installing accessories. Thanks.
Re-setting the ECU is the solution to the high idle problem. I followed Peter Baron's procedure day-before-yesterday and rode the bike every day since. This morning's ride was the absolute best, mostly because there was no traffic and I could pay close attention to the instruments and the way the bike functioned. Basically, it idled at 1100 after it warmed up and the needle never moved from there every time I stopped. The bike ran flawlessly and like a new bike. I am so happy to have my bike back and I will tell everyone to re-set their ECU any time they have an idle problem. It may not be the answer to their problem, but it is so easy and quick that it should be the first thing on the trouble-shooting list when you have a problem.
And all this time I thought an ECU was an exotic bird in Australia.
I haven't been so happy since I found out I could wear shoes riding a naked bike.
(07-01-2022, 10:43 AM)peterbaron_imp Wrote: Frank, any MPI component is replaced or disconnected, battery replaced or disconnected, ATM or engine replacement should have reseting residual values performed.
Beer
Peter, I can't thank you enough. What is MPI and ATM? Sorry, but I am not familiar with these terms. I did enough research to learn that an ECU is not an exotic bird found in Australia, but can't figure these out.
My bike is running like a new bike. This morning's ride was perfect. 1100 RPM every time I rolled to a stop. Formerly, it would go right to 2,000.
As I said earlier, this procedure should be the first step anytime something weird starts happening on the CB1100. I cannot believe the Honda technicians don't try it first with all the people who have had this problem. It just seems like it should be first thing on their trouble-shooting list.
Sure is a lot cheaper than installing a new IACV and/or ECU.
  CB1100 Idle speed instability problem ericlo69_imp 1,434 121,115 07-26-2026, 01:51 AM
  idle problem update 1973cb750 37 2,150 05-12-2026, 08:38 PM
Last Post: rdprdp01
  'Factory' high performance spark plugs PowerDubs_imp 17 1,510 10-23-2024, 02:50 PM
Last Post: rtmoto1
  Idle a little rough and miss fire when revved johnnyH_imp 3 435 09-15-2024, 12:16 AM
  Chain or sprocket problem ? The Gecko_imp 14 1,316 07-30-2024, 10:05 AM
  High engine revs on start up CBX1000_imp 21 1,872 06-06-2024, 02:40 AM
  another idle thread Tom_imp 11 1,047 11-20-2023, 01:30 PM
  O ring chain problem Mixagon_imp 7 681 10-17-2023, 07:28 AM
  TPS Sourcing because of High Idle Obi-wan Kenobi_imp 38 2,829 09-14-2023, 10:08 PM
  Honda CB1100 Rough Idle Solution dickie1951_imp 56 4,478 09-06-2023, 01:36 AM
