(01-09-2017, 10:49 PM)DaSwami_imp Wrote: (12-19-2016, 05:25 AM)LongRanger_imp Wrote: Not to derail, but I think you could add Moto Guzzi to the bastion of the unloved. Terrific motorcycles, strong racing pedigree (from the 50's), great styling and engineering, but zero marketing support in the US and an even weaker dealer network. Like the CB in certain respects, the brand deserves better.
+1 there, the comments apply to MG the most, the V7 / V7II are fabulous bikes
I own a 2013 Scram and the CB1100....thinking about trading in the Scram for another CB, but it is turning out tougher to do than I thought. The darn Scram is a low tech beast that darn well starts and runs everytime with zero issues. Looks like nothing else on the market. It's not rational, I know. But the Scram is a mule that I would trust to take me anywhere in the world. You look at this idle/stalling issue on the board here with the CB1100 and it gives me pause.
Type issues with moto Guzzi V7 into google like I just did, and you will find plenty of issues. You may trust yours, others are not having as good of luck
typical from wildguzzi
problems with my new 2014 v7 stone
« on: October 10, 2014, 10:25:04 PM »
I took delivery of this bike less than one month ago. The bike is having a serious drivability problem and I am having it towed to the dealer tomorrow. I am summarizing the issues I have noted during the initial 66 break-in miles I have ridden thus far.
1. Difficult starting, since delivery. It often took several attempts to start.
2. Difficulty staying running at idle. Stalls frequently and easily at idle after warming up.
3. Hesitation and surging leading to choppy acceleration up to 4000RPM in any gear.
4. The above problems are significantly worse when the temperature is colder. Today the temperature was about 60-62F and it was unable to idle for more than 30 seconds without stalling. It stalled at nearly every red light at idle. The idle surged from 1100-1500 RPM the entire ride.
From Guzziriders.org
Topic: New bike - same problems :/ (Gearbox & Stalling)
Posted: 01 Oct 2015 at 12:46
Hello all and thanks for reading.
My previous post was regarding my 2013 V7 Stone which was having idling and gearbox problems. Instead of putting the effort to fix it, and since the dealer was willing to take it as part exchange for a very similar price i paid a couple of months earlier, I decided to get the new version of the V7. Initially Issy (as i call my bike) seemed to be the perfect choice as her gearbox felt much smoother and the idling problems were only apparent rarely when her engine was cold. Unfortunately the longer I am riding the more regularly I find the following problems appearing:
a) The engine stalls quite frequently even when it's warm. Especially when engaging the clutch after a short burst of speed in 1st or 2nd gear, but has also happened when trying to downshift from 5th gear to 4th!! Many times it idles just fine when stopped at the traffic lights, only to stall as soon as I engage the clutch, before I even try to put it in gear.
b) The gearbox which initially felt smooth, at least compared to the 5Speed on the previous model, started giving problems as it sometimes refuses to downshift (gear pedal feels stuck).
c) When trying to downshift from 2nd to 1st while stationary, or even engage 1st gear from neutral or 2nd to neutral, the gearbox is completely unresponsive, with the gear pedal moving freely but not much happening besides this. The solution i found is to slowly release the clutch a little until the gear goes 'cluuuunk' and then it becomes responsive again.
d) The clutch cable tension is impossible to set-up. The manufacturer advices 2mm of slack on the clutch lever to avoid clutch slips and excessive clutch ware. Unfortunately the slack varies quite significantly depending of how warm it is, so if you set it up before you get going you will have more than 10mm slack when the clutch has warmed up properly. Get stack in traffic on a hot day and the slack increases further, the gears start to clunk horribly when engaged and the bike moves forward even with the clutch completely pressed.
There were plenty more......
What I am saying is all manufacturers have issues which is why they give you a warranty. Most of the time it's nothing serious. Sometimes it's something mysterious and difficult to diagnose because there are not enough of the issues that it has to go back to manufacturer to figure it out . But in the end what I am saying is, the Honda is a great machine..you have 2200 miles on yours with no probs, Cormanus has 30,000 on his with no probs and Sanoke has 60,000 miles on his with no issues. I wouldn't let it worry me.
