Fork Boots
White Dog_imp Offline
Threads: 59
RE: Fork Boots
#31
The gaiters I purchased from RevZilla (part #150125, which is also HD-03212) fit snug at the top (41mm) and are slightly loose at the bottom. The specs say the bottom diameter is 2 9/16" whereas I measure 2 1/2" diameter of the fork seal cover. So, the gaiter bottoms are a loose fit. I did not use the zip ties to attach the bottom sections--yet. I want to see what they do when I am riding. Even if water from the road were to get into the gaiters by them being loose, that same water will drain out. I might even flush the insides of the gaiters after a wet ride then blow dry them with my air compressor. These gaiters have no drain holes so if I were to shim the bottoms to fit tight, then zip tie them, I'd have to poke drain holes in the gaiters. The bottom part of the gaiters overlap the fork seal by roughly 1 1/2".
01-29-2016, 02:55 AM
Threads: 59
RE: Fork Boots
#32
These are the gaiters from RevZilla. Part HD-03212. Next time I'll try to hold the camera straight.
[url=http://s105.photobucket.com/user/WhiteDog14/media/dd874e8b-f00c-4b30-ba76-f97bf0d73835_zps7qftxjpa.jpg.html][Image: f02ac21b952eec98a4a13c53eaf83640.jpg]
01-30-2016, 12:06 PM
Riko_imp Offline
Threads: 47
RE: Fork Boots
#33
now i'm curious to see your windscreen Smile
about your boots, why aren't you using any zip ties, they seem to hang too low, especially at the top
01-30-2016, 01:44 PM
Threads: 59
RE: Fork Boots
#34
(01-30-2016, 01:44 PM)Riko_imp Wrote: now i'm curious to see your windscreen Smile
The tops of the gaiters are zip tied up and are up against the bracket which is mounted to the frame and hold the turn signals. The bottoms are larger diameter than the fork seal covers by 1/8". If I zip tie them, it would cause a bunched deformity in appearance so I elected to let them just hang loose. The problem could be solved for about $100 if I were to buy Kawasaki gaiters, which fit tightly top and bottom. Mine were less than $34.
My winshield is a PS2 with Memphis Shades lowers. I modified the MS brackets to fit the CB.
01-31-2016, 01:26 AM
  The GOAT of Short Motorcycle Boots: indie Ridge rdprdp01 13 1,501 01-08-2025, 08:36 AM
  Boots, Pants, and Airbag Vest rdprdp01 4 544 11-21-2024, 02:45 PM
Last Post: rdprdp01
  sniff my boots Chuckk_imp 20 1,121 04-06-2020, 05:39 AM
Last Post: IndianRider_imp
  OEM Honda Fork Boots 2017EX_imp 28 1,939 08-03-2019, 03:23 AM
Last Post: motoRAT_imp
  Fairing and Fork Boots garysieben_imp 21 1,847 03-24-2019, 12:49 PM
  Alternative Fork boots (not the kawa boots) misterprofessionality 11 1,155 06-01-2018, 05:39 AM
Last Post: Rocky_imp
  New Triumph fork boots Mscb1100_imp 11 940 12-25-2017, 02:21 AM
  ID these fork boots/ fork gaiters Riko_imp 9 882 12-18-2017, 09:43 AM
Last Post: LongRanger_imp
  Fork Boots (Front Gaiters) venturer434_imp 16 1,432 11-04-2016, 09:19 PM
  Fork Boots trd_wish888_imp 4 343 12-22-2014, 09:52 PM
