How To do your own 600 mile service
#31
(05-02-2013, 11:15 AM)The ferret_imp Wrote: While you're at it check fluid levels in clutch, brake and rear brake fluid reservoirs ( rear brake res is under seat right side)
[url=http://smg.photobucket.com/user/theferret111/media/2013_05020030_zps5bc70125.jpg.html][Image: e985b59fbc96950d74c667202ae13b16.jpg]
[url=http://smg.photobucket.com/user/theferret111/media/2013_05020031_zps0f2a3ae2.jpg.html][Image: bfd7f2d5e093ca69c6ef663a43bb2de7.jpg]
Btw your fuse box is right next to the rear brake res. Its good to know where it is before you have any electrical issues
[url=http://smg.photobucket.com/user/theferret111/media/2013_05020032_zps7199aa4b.jpg.html][Image: 14156460d382a789ffba77ca69e54041.jpg]
Our oil should be drained by now so let get to putting our bike back together. Take your drain plug, and new crush washer if necessary and start bolt into drain. After 2 or 3 treads stop and clean oil off surrounding area with a rag.
[url=http://smg.photobucket.com/user/theferret111/media/2013_05020025_zps301573e6.jpg.html][Image: bab1d8ed06ebc31008442a85eedcf96c.jpg]
Once clean run the bolt home by hand. Then tighten with ratchet and 17 mm socket. I snug mine up, but spec is 20 ft lbs I believe.
Next grab your new oil filter. Rub some fresh oil around the rubber o- ring and pour an ounce or two into the filter and roll it around.
[url=http://smg.photobucket.com/user/theferret111/media/2013_05020023_zpsa8d6934b.jpg.html][Image: be17a629c24f80ff84346d2e72242eba.jpg]
When ready to install, take your rag and make sure area around filter is clean.
[url=http://smg.photobucket.com/user/theferret111/media/2013_05020022_zps6b9647f4.jpg.html][Image: 2eb2539d93c4a6a4c7c1fc07cc1ad0e8.jpg]
Install filter by hand and tighten down until it makes contact. Finish tightening by hand turning an additional 1/2 to 3/4 turn or until snug. Torque pec on it is Ft lbs if uou are so inclined.
[url=http://smg.photobucket.com/user/theferret111/media/2013_05020024_zpsbf8503c9.jpg.html][Image: 168f9e0f3bc97bca74fa59b6116b1f13.jpg]
Now move to the right side of the bike. This bike has a pretty small fill so grab a funnel if you don't want oil everywhere.
[url=http://smg.photobucket.com/user/theferret111/media/2013_05020029_zps5b056da1.jpg.html][Image: e1b2273ca86d6b27f7941bfb16708ee5.jpg]
The CB calls for 4.1 qts with filter, 4.0 qts without of Honda 10 W30. I put an asterisk next to that figure. I poured 4 qts into mine ans it was slightly overfilled. Not so high it will cause an issue, but next time I'm putting in 3 qts 28 oz and checking it before adding any more.
[url=http://smg.photobucket.com/user/theferret111/media/2013_05020037_zpsf6b74396.jpg.html][Image: f242c4f2335d0bb3136cbc6ca8fef012.jpg]
Replace your oil fill plug.
Now start the bike, immediately the red oil light will come on
[url=http://smg.photobucket.com/user/theferret111/media/2013_05020050_zps7d74364d.jpg.html][Image: b0f9f4315f23578e3e67defdecd81a9b.jpg]
But it should go out in a second or two
[url=http://smg.photobucket.com/user/theferret111/media/2013_05020051_zps957c285c.jpg.html][Image: 4d761932b2a716f7574409d76a6a86ad.jpg]
While the bike is warming up, check headlight, high and low beams, turn signals left and right, front and back, tail light, and brake light with hand and foot.
After running for 2 minutes. Turn the bike off and let it sit for 5 mins or so. Then check oil level in sight glass. It should be between the high and low mark. Anywhere in between is okay, but we all know you are going to try and make it dead even with the top mark, aren't you?
I admit it; I just can't help it.
Would you happen to have the OD & ID of this washer? I have a few washers from previous Honda bikes still laying around.
(05-06-2013, 02:15 AM)The ferret_imp Wrote: Heres another tip for you all. The crush washer for the drain plug Honda part # 94109-14000 costs $1.00 at my local motorcycle dealership ... but my 08 Honda Civic uses the exact same crush washer Honda part # 94109-14000 and they only charge 30 cents for it. While out riding stop at the car dealer and get a couple extras and keep them in your tool box just in case.
ID would be 14 mm or at least its for a 14 mm bolt. I could measure one in Thousandths I suppose if you need that with my caliper.
Duh, I knew that based on your mention in the preparation for oil drain plug removal. Thanks for the info.
(05-09-2013, 09:31 AM)The ferret_imp Wrote: ID would be 14 mm or at least its for a 14 mm bolt. I could measure one in Thousandths I suppose if you need that with my caliper.
Ferret,
Thanks for the detailed write up you saved me at least $100.00. The shops in my area wanted between $140.00-$225.00. Once I heard those prices I decided I would take an hour of my time an do it myself.
You are welcome jwayne. They ask crazy money for an easy hours worth of work isn't it? Glad it was able to help someone.
Thanks Ferret for posting. Much appreciated. We finally have great riding weather after a pretty cold/snowy early spring, and the miles are piling up now. Should get to it in a couple of days.
Also, about the crush washers, my local dealer, Mason City Honda, has them for only 28 cents. I checked from the place I buy my Honda OEM auto parts from and they wanted 35 cents. Mason City Honda (motorcycles) only wanted 28 cents. And any OEM part is 20% off. Give them a look see.
Hello there folks, I have been getting some info via the web on engine breakins, some sites recommend changing your oil at earlier intervals (200/500 miles) and using regular Dino oil so asto flush out the micro shrapnel from the new engine. Any thoughts on this?
Great site by the way!
Excellent write up, thank you so much for your contribution! I don't want to start an oil discussion thread, but what brand/weight is everyone running?
  Service manual Billie_imp 32 2,984 11-27-2025, 06:35 AM
Last Post: TheLegend
  2018 CB1100EX just collected from service Motorsport3_imp 5 560 05-10-2023, 11:25 PM
Last Post: Motorsport3_imp
  Preparing to do a fork service, any advice? skidmarkart_imp 12 1,254 04-23-2023, 01:35 AM
  Service and Repair Manual alexzanutto_imp 5 652 02-26-2022, 10:02 PM
Last Post: alexzanutto_imp
  Factory Service Manual Download ??? markT_imp 24 1,890 10-14-2021, 09:30 AM
Last Post: furious_blue_imp
  Service indicator - unleashed j3gq_imp 6 628 07-27-2021, 03:12 AM
  Free Honda SERVICE Manuals dan88_imp 9 909 03-30-2021, 08:18 PM
Last Post: Enzofour_imp
  DLX is back from service LongRanger_imp 18 1,279 01-14-2021, 08:00 AM
  First Service larryblag_imp 46 3,045 09-18-2020, 09:11 PM
Last Post: spechg
  Honda Common Service Manual pekingduck 35 2,611 04-26-2020, 03:12 AM
