12-01-2015, 11:29 AM
I have a feeling google translate might be getting involved here.
Why I'm switching BACK to Honda oil
12-01-2015, 11:51 AM
Indeed, but I believe he is trying to say the other two didn't work very well in a traffic jam situation, maybe?
Sent from my VS990 using Tapatalk
12-01-2015, 12:13 PM
Taiwan's urban areas with traffic congestion
REDLINE 10W30 not good SHELL ADVANCE ULTRA 4T 10W40 not good AMSOIL MCT 10W30 very good stalls smooth engine light Fast heat dissipation Indeed, but I believe he is trying to say the other two didn't work very well in a traffic jam situation, maybe? Sent from my VS990 using Tapatalk YES
12-01-2015, 12:41 PM
(12-01-2015, 12:13 PM)jp4141432_imp Wrote: Taiwan's urban areas with traffic congestionThank you for the information! Sent from my VS990 using Tapatalk
12-04-2015, 11:47 AM
Just did my oil; picked the same Honda syn-blend 10W40 oil I used before. 10W40 because of the low miles I put on per year puts me in the middle of summer and the high heats. No complaints so far - but then again only some serious testing with many more miles of abuse.
Personal experience: I really like and have had great service from sun-blend oils. And changing oil often on a regular basis. Some bikes are very hard on their oils and should be changed a lot more often than folks think (my XR650L before the oil cooler was added destroys oils -all oils - at around 500 miles). My biggest concern; my new truck has a built in app that indicates oil life vs. just changing it when you think service or miles indicate to. Do I trust it? I'll probably chicken out and change before the app thinks I should.
12-05-2015, 08:39 AM
If its any consolation Rboe our Honda cars have that feature. We take them in when the light says to and my wife's Accord had racked up 220,000 trouble free miles. My Civic before it 200,000 trouble free miles before I sold it to a friend who is still driving it 3 years later, the Civic before that 197,000 trouble free miles before I sold it. My current Honda truck only has 38,000 miles on it but will get treated similarly.
12-05-2015, 08:50 AM
I also have that slight weep but only after I switched over to the Honda 10W30 synthetic oil. Usually won't show up until I've ridden 60-70 miles, then it's noticeable. I've checked all bolts to make sure they are tight. I'd like to go back to the Honda recommended 4stroke motor oil to see if that will alleviate the problem. Anyone know if switching back will have an adverse affect on my bike?
12-11-2015, 12:45 PM
(03-16-2015, 02:21 AM)CIP57_imp Wrote: [url=http://s1034.photobucket.com/user/cipolla57/media/photo_zpsxtvv0wsy.jpg.html] Just curious, have you checked the torque values on your fasteners on and around the heads? Jerry
12-11-2015, 10:56 PM
Jerry -
I did not check them because I don't have a torque wrench to get in there. But I did put a wrench on them & they appear to be good & tight. I just find it odd it didn't do this until I switched over to the full synthetic oil & my problem looks like your pictures along with others I've seen. But, on the other hand, sometimes after riding 30-40 miles around town, it won't do it at all. Yesterday, I rode about 100 miles, at times up to 75 mph & had a little weep about mid-point - wiped it off & it didn't come back. So I think I am gonna switch back w/in the next couple of weeks & see how it does.
12-12-2015, 12:12 AM
I don't usually comment on oil threads but from my experience using the recommended oil and changing at the recommended interval have always worked fine for my situation. I used conventional oil in a Toyota Corolla that I had for over 20 years. It began to use a little oil at about 180,000 miles. I'd say a quart or so between changes every 7,500 miles. I tried the high mileage oil that most companies sell, and it was like the engine repaired itself, it hardly used half a quart between changes. I've never had a engine lose compression on me except a 5HP Honda engine that was on my pressure washer, my fault though, I neglected it for a few years. I bought a 6.5 HP replacement engine for 99 dollars from Harbor Freight, it bolted right up, I ran it for 3 hours with no load to break it in, changed the break in oil and it runs like a champ. I believe it's a Chinese built Honda clone.
« Next Oldest | Next Newest »
| Switching to synthetic oil... | Bike #12_imp | 39 | 2,740 |
07-11-2014, 02:02 PM Last Post: OldF7Guy_imp |
| Switching switches? | the Ferret | 73 | 5,969 |
05-30-2014, 07:18 AM Last Post: The Spaceman_imp |
