Rattling noise at idle.
#31
(04-03-2015, 08:33 AM)Flynrider_imp Wrote:
(04-02-2015, 02:02 PM)Ghis_imp Wrote: Any issues with clutch slippage on full synthetic. Two dealers are telling me that they only put the 10W30 full synthetic in their motocross bike, but not the road bikes. They both encouraged me to use semi-synthetic oil. Of course you have to go to a different brand than Honda for that. Might just go back to regular Honda 10W30 and see if it gets back to normal as it was before the 600 miles service when the dealer put in the 10W40...
This mixes two different issues. The clutch slippage issues happen if you use oil that has excessive friction modifiers (typically found in car oils). This can happen with both mineral and synthetic oils. What you want is an oil that complies with the JASO-MA specification. That ensures that the oil does not contain friction modifiers that will affect a motorcycle wet clutch. You can find both synthetic and mineral oils that meet the JASO-MA spec and either will be fine for your wet clutch.
You're right. One issue is that Ghis doesn't have to go to a brand of oil other than HONDA to get what he wants and the other issue is whenever someone says "the dealer told me.........."
No luck. I drained the 10W40, and put some 10W30. I let it run for a while, then drained that again. That should have flushed out whatever oil remained in the oil cooler. Replaced the oil filter, and filled it back up with 10W30. Started the bike, and sure enough after running for 2 to 3 minutes the rattling came back. I also notice that as the bike warms up it seems as the noise is going away, but it actually moves up so lightly just above idle, giving the impression that it's gone. Reving the motor a little to 100 to 200 rpm above idle will reveal that the rattling is still there, but it does go away past that. Frustrating for a new bike I only had for a few weeks. Off to the dealer it goes first thing in the morning.
Normally, I would be telling you to check your carbs to make sure they are in sync. The rattle is caused by an out of sync carb, which in turn makes the clutch basket make all kinds of noise. But this is a CB1100 we are talking about. I would not worry about it, as I suspect it has something to do with the syncro's in the clutch basket. Does the rattling go away with the clutch lever pulled in? If so, it's in the clutch basket and I would not worry.
Also, sorry to debunk some of the oil theorists but changing over to synthetic oil or changing oil weights will not change this effect whatsoever.
Thanks xNEOx. I will try that.
Maybe it's the higher elevation. Idea
Hope the dealer can help you out tomorrow.
(04-03-2015, 03:16 PM)EmptySea_imp Wrote: Maybe it's the higher elevation. Idea
I would also advise if you are running synthetic oil, to go with a high flow oil filter as synthetics flow better.
Help Ferret, but a long time back was there not a post about some bolt that one loosened and it tensioned something? Cam chain maybe?
(04-03-2015, 02:47 PM)Ghis_imp Wrote: No luck. I drained the 10W40, and put some 10W30. I let it run for a while, then drained that again. That should have flushed out whatever oil remained in the oil cooler. Replaced the oil filter, and filled it back up with 10W30. Started the bike, and sure enough after running for 2 to 3 minutes the rattling came back. I also notice that as the bike warms up it seems as the noise is going away, but it actually moves up so lightly just above idle, giving the impression that it's gone. Reving the motor a little to 100 to 200 rpm above idle will reveal that the rattling is still there, but it does go away past that. Frustrating for a new bike I only had for a few weeks. Off to the dealer it goes first thing in the morning.
Ghis,
Sorry you did not get the same results as several of us, did you take bike out for a 15-20 mile ride?? You need to get the oil flowing through the tranny and fully warmed up otherwise you'll still hear the noise. I would give it a good run and a video of what your hearing would be helpful.
My bike is now in the shop. Now, all I can do is wait.
Ghis,
The UK member on the UK CB board that had the noise pretty bad had his cam chain tensioner chaned out, I think. At the time, both the dealer and Honda were pretty sketchy about the whole thing.
I can search around for the thread if you want.
  Brits To Tackle Loud Exhaust Pipes With Noise Cameras clearviewx 46 2,137 06-10-2019, 05:01 PM
Last Post: Bazbro_imp
  that pinging noise when you turn off the motor.... jedd_imp 24 1,010 04-06-2018, 05:17 AM
Last Post: VLJ_imp
  Start up idle / procedure? el duque_imp 5 265 03-29-2018, 08:39 AM
Last Post: el duque_imp
  Where's the noise? the Ferret 21 892 04-01-2017, 01:18 AM
Last Post: Rocky_imp
  Rattle noise on instrument panel cbdtran_imp 12 692 03-02-2014, 08:29 AM
Last Post: pechorin75_imp
  Engine Idle _imp 10 473 12-05-2013, 11:37 PM
