Foot Peg Feelers
#31
(01-31-2016, 09:28 AM)Rboe_imp Wrote: I was turning left from a stop (got the green arrow so I launched), mid turn I wanted to upshift to 2nd. Smile If you squirt out of this turn it's easy to hit the next light on the green without speeding.
Now coming home, doing the right hand turn, there is a separate turn lane so I can pick the gear and power through without shifting; and I've learned to pick up my RH boot to avoid having it caught.
I ride with Sidi boots (they don't look that bad yet!) and they are not all that cheap either. In any event, looks like I do need to adjust my riding a tad.
Probably teaching you to suck eggs here, but I went through this routine:
"Change gear or trail brake (if required), foot back, toe on peg, tip in."
Now it is habit.
Cheers.
^ This. Ride with your toes, not your arches, on the pegs.
Nope. Arches. With the toes on the pegs takes too long to hit the brake or shift.
If you've raced or attended track days, you will learn to put the balls of your feet on the pegs through the corners. Leaving your feet in one position on the pegs will not work. My feet change position many times during a ride. Cornering should be a deliberate but smooth transition...no jerky...lol.
A very interesting read.
https://paulritterblog.wordpress.com/wd-...-of-style/
I grew up with the old style the " Hailwood" style if you will. Mostly centered, knees and toes splayed using my toes as feelers, doing my trail braking and down shifting pre corner, wide apex (especially on blind corners), carefully and smoothly looking thru the corner, laying it over on my chosen line, rolling off the throttle just slightly, coasting through and smoothly rolling the throttle back on accelerating out the other side. Maximum smooth, minimum effort is my goal. I'm not racing, I'm riding at a pace that pleases me. There are riders that are faster than me, there are riders that are slower than me. Let them chosse whichever style works for them, and in the few years I have left I'll keep doing what has worked well enough for me for a long, long time.
[url=http://smg.photobucket.com/user/theferret111/media/Dragon%202015_zps36kvbnzx.jpg.html][Image: 2a64e4848f5d2c7e0ef84f78418412a1.jpg]
In spite of my toe dragging, I have yet to touch down a peg feeler, even with the new lowered pegs. Not many areas in Arizona where the road is good enough to do so and where my pucker factor will allow it. Angel
Each to his own I guess. Also some corners are different to others. If the throttle remains static as the corner is entered then the bike must slow down. Why? Same RPM but the effective diameter of the tyre decreases, therefore a few mph or kph are lost. Not a problem if you don't mind. When I tip in, assuming I'm happy with the entry point and entry speed, I increase throttle slightly to maintain the weight balance between front and rear and keep speed static. That is, to stop the front weighting up. Once I'm comfortable I may then increase throttle, but that is optional and only increases the "spirited" factor, nothing else. As Ferret rightly says, if you develop a style and it suites you, then there is no need to change unless you want to explore something else. Others who have a good level of expertise (like Ferret) are always worth listening to. In the early nineties I got my hands on a first model Fireblade (CBR 900RR), the first bike with any real performance I had ridden. It was a fair handful for me and, in retrospect, I reckon I was lucky to survive the first week on the road. I happened to run across a police motorcyclist who followed me around some roads (socially, not on business) and after a long talk changed my riding style completely and for the better. In the same manner an article on trail braking, that this forum pointed me to, gave me some food for thought. At 71 years young I still love to learn.
As far as touching down in corners goes I prefer feelers to boots for the reasons I mentioned in a previous post. I should have mentioned for Rboe's understanding that when you start to stand the bike up again to exit a corner then, sure, put your boot back to arch on the peg to facilitate gear changes, as normally it will be an up shift requiring the boot under the shifter. If leaned well over, to where a touchdown is likely, then an up shift (or down shift for that matter) is probably not a very good idea as, if you don't get it exactly right with no weight shift between front and rear, there is a likelihood of some interesting oscillations developing. If my boot, or peg, is dragging then I don't think a gear change is appropriate for my skill level. As far as the right boot is concerned, if braking is required much the same principal applies; if you are leaned over to the point where something is dragging, then be careful. Better to have entered at the right speed. If running wide is the problem then don't brake, fix your sight on the right line and lean the bike to achieve that line. Rolling off abruptly is also not a great idea at this stage as it weights the front up which may induce the aforementioned interesting oscillations. When the pegs are on the ground there is still plenty (well a little more anyway) left as the pedal pivots up and the line will tighten up. If hard braking in a big lean is required then I guess its not going to be a good day and the difference between toe or arch on the peg is probably insignificant. Smile
Cheers.
(02-02-2016, 04:53 AM)The ferret_imp Wrote: I grew up with the old style the " Hailwood" style if you will. Mostly centered, knees and toes splayed using my toes as feelers, doing my trail braking and down shifting pre corner, wide apex (especially on blind corners), carefully and smoothly looking thru the corner, laying it over on my chosen line, rolling off the throttle just slightly, coasting through and smoothly rolling the throttle back on accelerating out the other side. Maximum smooth, minimum effort is my goal. I'm not racing, I'm riding at a pace that pleases me. There are riders that are faster than me, there are riders that are slower than me. Let them chosse whichever style works for them, and in the few years I have left I'll keep doing what has worked well enough for me for a long, long time.
One of the best looking riding pictures of the cb1100 Thumbs Up
There are far to few riding/rolling pictures of our bikes imo Dodgy
WEll, I took mine off...I hadn't realized I didn't have to cut them off with a Dremel or something, and was pleasantly surprised that it took just a moment with a wrench..
  Rider Foot pegs Matt F._imp 11 710 05-14-2016, 07:36 AM
Last Post: Huladog_imp
  foot peg location Cresty_imp 4 907 07-26-2015, 08:10 AM
Last Post: Cresty_imp
  Finally sat on a CB1100--foot controls? Nark_imp 29 2,160 11-11-2013, 09:35 PM
  Foot Wear Flashman_imp 28 1,786 07-01-2013, 01:15 PM
Last Post: rboe
