Whitehouse K17 mods...
Houtman_imp Offline
Threads: 115
RE: Whitehouse K17 mods...
(03-19-2022, 03:38 AM)GoldOxide_imp Wrote: Smart Bazbro. Don't underestimate the rust. Thumbs Up
RUST in England ???
03-19-2022, 07:47 AM
Bazbro_imp Offline
Threads: 16
RUST in England ???
RUST in England ???
Big Grin Big Grin Big Grin.
And that's just the RIDERS !! Celebrate
03-19-2022, 08:56 AM
tommymck Offline
Florida/Maryland
Threads: 34
Likes Given: 9
You're a big tease Bazbro. When are we going to see the money shot???!!! That front end looks fantastic
03-19-2022, 08:59 AM
Bazbro_imp Offline
Threads: 16
(03-19-2022, 08:59 AM)tommymck_imp Wrote: You're a big tease Bazbro. When are we going to see the money shot???!!! That front end looks fantastic
The tank needs assembling first! The tank cap comes as a separate item and the fuel pump has to be removed from the old tank and fitted to the new one. Then ... fitted to the 'bike!
So, soon, Tommy... soon! Wink
[Image: 073119def6e6ed43b3de20dec21b3e59.jpg]
03-19-2022, 09:33 AM
peterbaron Offline
Likes Given: 1,013
(03-19-2022, 03:45 AM)Bazbro_imp Wrote: Fitting Wyvern 4-into-4 exhausts/silencers, Part 2...
You'll remember that I had to pause fitting the middle two silencers because my jack was in the way.  I had to wait until I could refit the front wheel/mudguard (fender) and lower the front wheel to the ground, before I could remove the jack and finish the exhausts.
So.... here we go on Part 2.
Before fitting the 'H'-section joining the middle two exhausts, I needed to safely route the O2 Sensor's cables.  The right-hand one is OK, but the left-hand cable runs dangerously close to, and could be snagged by, the rear drive chain.
I cable-tied the two cables together as far as possible,  then secured them to the main stand spring  hook on the frame, now unused ('3' in the pic).  Other cable-ties were added, especially where the cable needed to be guided near the centre line of the 'bike ('2' in the pic) and then as it went into the cavity occupied by the chain ('1' in the pic).
Cable-tied Gaffer tape was added where the cable passed any sharp edges.
[Image: e47c3b37a414e83af52b34c1cc7c6a5a.jpg]
[Image: 039d55ea3ec2e8d0ea97092eb5e626a4.jpg]
With foresight, this could have been done better maybe, with shrinkwrap tube or stout rubber tubing.  This is satisfactorily, though.
While under the 'bike, and before the exhausts were fitted, I put tape on the swing arm bearing, to prevent stone damage and subsequent corrosion - a great idea by Max on this Forum.  Thanks Max!
[Image: 833262420ea8e91e607e840262719be5.jpg]
The kit comes with a small 'adapter plate' that, when adjusted properly, keeps the sidestand from hitting the exhaust.  Neat!
[Image: df2af315c6d13e0e314b3ab541690757.jpg]
The 'H'-section middle exhaust joiner was tightened (socket bolts and 10mm nuts) and the inner silencers fitted and bolted up.
[Image: a180dcd1515846d40635c90bb6a2f940.jpg]
Leftside done...
[Image: bff1dea26c2b553ff0cab26d8ad675fc.jpg]
The right side...
[Image: 71e394f5a71cd302cfe8c6989c7168be.jpg]
And both sides!
[Image: c7be55748041ee4bd713a4c92c2fa21d.jpg]
That's enough for today.  Tidying up tomorrow; finishing off small bits I've left, checking tightness of all fasteners I may have touche and so on.  And then... starting on the tank (fitting fuel pump and filler cap, etc).
Thanks for the kind comments, guys - they're all appreciated. Thumbs Up
Yup, GO... I envy the guys that live in a climate where the dreaded "rust" isn't an issue! Wink
^^These two^^ pics I like the most Thumbs UpThumbs Up
03-19-2022, 09:44 AM
[Image: fc2d6f08f36cbcbe41408d385d2435c7.jpg]
I kinda like this intermediate shot.
There is some sort of soul there - hard to see, but it can be felt. Savor this moment.
03-19-2022, 01:02 PM
Threads: 349
Likes Given: 1,032
Nice work, Bazbro.
03-19-2022, 02:19 PM
Vic_imp Offline
Threads: 2
(03-19-2022, 01:32 AM)Bazbro_imp Wrote: The final fit of the modified CB750 front mudguard...
The excess of the brackets were cut off, buffed and shaped.  I decided to paint the brackets because of this scarring of the chrome.  But... silver or black paint??
The first coat of red oxide primer, ensuring that it gets into all the nooks and crannies where the brackets attach to the mudguard and where rust would otherwise form...
[Image: 1397a3dcfebd77cec5625066b9096328.jpg]
[Image: c7e3209be9bec1b98968ab71fb7933ac.jpg]
I decided,  while I was about it, to paint all the seams round the edge, underneath the m/guard, to properly rust proof it.  By not bothering to mask all of the underside, overspray will get all over the underneath of the m/guard, but I'm not worried about appearance - it's those cracks and seams where rust starts, that I need to cover and protect with paint.
[Image: 600ddb54e2465173f2aec095c9c84b28.jpg]
Don't forget the cable guide that was cut off the strut... that needs the red oxide rust preventer, followed by a topcoat too.
[Image: f110f41acedab64c6a2cfe0cbab4683d.jpg]
Silver it is!  I have some 'Truck Bed Liner' spray, but that's a bit over-the-top, I think.  So a couple of passes of spray silver it is, maybe followed by a couple of coats of clear matte lacquer to make the brackets look nice.
[Image: 0a86b72f9208a49abcd15e64c2bd7ab5.jpg]
The finished job...
[Image: add17b7fd06ab88ab739fcd3811d1387.jpg]
wow! nice work Bazbro!
03-20-2022, 12:19 AM
Bazbro_imp Offline
Threads: 16
TIME TO FIT "THE TANK"...
[Image: ddde34249c942c501623f7cdb2fe84ca.jpg]
Big Grin Big Grin Big Grin Celebrate
Thanks guys.
Great pic, Vic! I shall keep that.
Have you noticed how Honda cleverly curved the CB 750 silencers INWARDS at the ends, preventing the "sticking out" appearance of the Wyverns? The CB750 looks much better from the rear than the Wyverns. But I'm not complaining! Smile
03-20-2022, 01:32 AM
Lord Popgun Offline
El Supremo RLET Force
Virginia
Likes Given: 143
Also, apparently the CB750 did not have a throttle. It had a “gas handle” Big Grin
03-20-2022, 02:47 AM
  Gauge Mods Seancampbell777_imp 11 1,204 10-16-2024, 04:14 AM
  Short mods list and experience with each for those considering. Motomike7_imp 6 638 04-07-2023, 11:34 PM
Last Post: 1973cb750
  2 small mods until the weather changes inditx_imp 10 1,070 01-02-2023, 10:31 AM
Last Post: inditx_imp
  Mods to OEM seats? 2014ltdltz 7 824 07-05-2022, 05:56 AM
  Best suspension mods? gretle_2.0 6 621 05-10-2022, 06:25 AM
  Winter Mods finished, time to ride! Phadreus_imp 3 547 05-02-2022, 10:08 PM
Last Post: Phadreus_imp
  Mods Mods Mods Latinrudeboi13_imp 12 1,058 08-23-2021, 01:11 PM
Last Post: Rox_imp
  Mr.P's CB mods, mark II misterprofessionality 18 1,553 05-21-2020, 06:45 PM
  New Mods 89gaz89_imp 1 334 05-15-2020, 08:08 AM
  Newly Purchased 2013 With some Mods HigginsNYC_imp 26 2,153 03-14-2020, 12:02 AM
Last Post: Cobalt23_imp
