Ear Plug recommendation
JF Coastal_imp Offline
Threads: 23
RE: Ear Plug recommendation
I'm so confused ?? Why ear plugs? Maybe I'm missing something, or just like the sound of wind and the bike.
06-05-2015, 12:27 AM
the Ferret Online
Likes Received: 618 in 276 posts
Likes Given: 789
According to what I've read, no helmet is quiet enough to stop permanent hearing damage from wind noise over 70 mph. I have never worn ear plugs in 50 years. Also shot guns as a kid, and listened to rock music in my 20's. My ears ring 24/7. Mostly I can ignore it but if I stop to listen it is annoyingly loud. You really hear it when you lay down to go to sleep.
If you can avoid that , that's good. Ear plugs will help avoid that. Too late for me really as the damage is irreparable, but maybe some can benefit from the suggestion to protect their ears.
06-05-2015, 12:53 AM
redbirds_imp Offline
Threads: 186
Same here Mickey. Protect your hearing now before it's too late.
06-05-2015, 01:02 AM
Threads: 23
So it's preventative . Thanks for the explanation !!
06-05-2015, 01:22 AM
flynrider Offline
Phoenix, AZ
Threads: 28
Likes Received: 6 in 2 posts
(06-05-2015, 01:22 AM)JF Coastal_imp Wrote: So it's preventative . Thanks for the explanation !!
Yep. It's most important if you spend a lot of time at highway speeds. Noise level can reach over 100 dB at 65 mph. Continued exposure to levels above 85 dB can cause hearing loss.
Way back when I first started flying virtually no one used noise reducing headsets in training aircraft (noise levels in the 110 dB range). Just about every long time flight instructor I know has some level of hearing loss. Nowadays most every trainer is equipped with headsets and intercom systems.
06-05-2015, 02:41 PM
SanPete_imp Offline
Threads: 7
#26
After a long day ride yesterday my ears are ringing to the point I can't sleep. Mind you I was wearing foam ear plugs. I guess it is too late for me, damage done.
06-05-2015, 07:54 PM
Threads: 23
#27
Thanks for this info Flynrider. Much appreciated.
06-08-2015, 08:56 PM
Motogeezer1949_imp Offline
Threads: 66
#28
I use plugs made for swimmers, called Water Block, also marketed as Aqua Block.
06-08-2015, 09:15 PM
  booster plug outback_imp 4 484 10-07-2022, 01:20 AM
Last Post: Denbow_imp
  Any aftermarket Turn signals plug and play? gretle_2.0 5 676 05-30-2022, 07:05 AM
Last Post: bioman_imp
  Rear shock recommendation please Jim_imp 12 999 09-25-2020, 11:25 PM
  Gold Plug Magnetic Oil Drain Bolt 2017EX_imp 15 1,214 03-05-2020, 03:57 AM
Last Post: Teamwalker_imp
  Auxillary USB Power Plug install for IPhone Frulk_imp 22 1,289 05-12-2019, 06:00 PM
Last Post: Bazbro_imp
  Accessory recommendation for a long ride chandler_imp 22 1,511 06-27-2017, 11:15 PM
Last Post: Rollie Bruner_imp
  Face shield tinting recommendation CB4ME_imp 9 706 03-01-2017, 06:24 AM
  Seeking recommendation for maker of highly customized license plate frame jerrycon_imp 4 416 04-05-2015, 03:12 PM
Last Post: gossman_imp
  PIAA Factory Headlight Recommendation rocket_imp 5 516 03-30-2015, 12:10 AM
Last Post: FJR919_imp
  Plug&Play Back Rest? Stealth128_imp 0 160 08-04-2014, 11:27 AM
Last Post: Stealth128_imp
