The Finished Chip Beck Spec CB1100-PHOTOS
ChipBeck_imp Offline
Threads: 29
RE: The Finished Chip Beck Spec CB1100-PHOTOS
(11-23-2015, 01:24 AM)Ole_imp Wrote: Looks fantastic Chip. Only thing I would add is tape off and black out the Honda on the cases.
[Image: 5a62b4fe8b92dcc8fb77e06125a36dd5.jpg]
[Image: e864d541a35119d20f2b0ee9cb517608.jpg]
[Image: a90f1d496c85ee58e50b3e9920b010d6.jpg]
Ole,
I thought the same thing but didn't know what kind, if any, type of paint would stick to those hot engine cases long term. I even thought about buying the black lettered cases from the '14 delux. What type of paint did you use? How is it holding up? And did you post a "how to"? Thanks.
Chip
11-23-2015, 05:19 AM
Ole Offline
Wisconsin
Threads: 18
Likes Received: 5 in 3 posts
Likes Given: 1
Hi Chip. I did not do a "how to". I just taped the letters off with a good painters tape then cut them out with an exacto knife. I did not use special paint I used some John Deere semi gloss rattle can black. It stuck very good and the engine and clutch heat has not affected it yet.
11-23-2015, 09:22 AM
Pterodactyl_imp Offline
Threads: 75
Ole,
Chip
Ole,
Chip
Mask as required. Rattle can paint is easy to apply. Fine sand the target to get rid of waxes etc and rough up the surface. Etch prime, it's important, then use a high heat enamel. For filling the lettering it doesn't have to be the VHT and can cure "in situ". Clear cote if you think it needs it. Probably doesn't.
This is the type of paint I would use for that job.
[Image: ea8c7ee14a9d72e6894feee967777322.jpeg]
When I paint the engine covers (stone chips) I use this stuff, below. But it really should be cured in an oven. Heat lamp and 7 days would probably also cure it.
[Image: 7be6f49fb31110ba09c82835ce055c6d.jpeg]
11-23-2015, 10:28 AM
redbirds_imp Offline
Threads: 186
I think you did a splendid job Chip. Very well done!
11-23-2015, 10:51 AM
Threads: 29
(11-23-2015, 04:46 AM)lash_imp Wrote: Would Corbin do that seat mod for anyone else or is it exclusive? I really need something like that for the same reasons..
Lash,
Nothing I post is proprietary and anyone can duplicate it. Multiple members here have ordered Chip Beck Spec seats. The changes to their standard offering are... 1. Delete all backrest provisions. 2. Delete the leather flap at the back of the seat. 3. Delete all tuck & roll stitching. 4. No welts. 5. Plain black leather with black sides.
Corbin will tell you that they will not warranty seats without tuck & roll stitching. My seat is almost 2 years old and it's perfect. I've had 5 Corbin seats over the years and none of them have had tuck & roll stitching. The stock seat and K&H seats don't have it either. Cheers.
Chip
11-23-2015, 10:48 PM
jimigalahad_imp Offline
Threads: 10
#26
Looks fantastic. Clean lines. I particularly like the fairing/handlebar setup especially since it sounds like it provides more than just looks.
11-24-2015, 12:13 AM
furious_blue_imp Offline
Threads: 11
#27
Beautiful Bike !
An island of sanity and taste in a sea of bobbers and Craigslist 'cafes'...
11-24-2015, 04:41 AM
Riko_imp Offline
Threads: 47
#28
thing of beauty! and still kept the stock look
11-24-2015, 06:27 AM
EGAlvarez_imp Offline
Threads: 34
#29
Could we get some more intel regarding the rear tail light? Vendor? Cost?
11-24-2015, 07:07 AM
lash_imp Offline
Threads: 8
#30
Thanks Chip for the info. I am going to order a seat over the winter and hope they know what I am talking about when I ask for the Chip Beck Spec...
Is your seat wider than stock and do you sit farther back? I am 6'2 so I need the leg room.
11-24-2015, 07:35 AM
  finished "forward controls" today Griz53_imp 12 908 10-02-2022, 10:44 PM
  Winter Mods finished, time to ride! Phadreus_imp 3 472 05-02-2022, 10:08 PM
Last Post: Phadreus_imp
  Tech Spec Tank Pads 2017EX_imp 3 367 08-06-2020, 06:10 AM
  Chip Beck Spec Low Handlebar/Mirrors Mod. ChipBeck_imp 112 8,016 09-18-2019, 12:00 PM
  Chip Beck Corbin Seat owners iamlegend21087_imp 6 514 08-29-2018, 07:12 AM
Last Post: bflint
  Pair valve delete...i need photos -_- JohnHighlander_imp 2 282 05-30-2018, 05:21 AM
Last Post: Ferrealls_imp
  It's Finished! (mostly) Banned_imp 7 646 05-25-2018, 10:44 PM
  Top triple clamp torque spec run-tmc_imp 5 465 06-01-2017, 09:15 PM
  Ryujin Fender Eliminator kit Video & Photos lola_imp 27 1,653 02-05-2016, 05:56 AM
  ASWR Spec Chic Design Sport Trunk Seat Chapomis_imp 22 1,512 12-16-2015, 10:14 AM
Last Post: Riko_imp
