Slip on exhaust
spartanheed_imp Offline
Threads: 8
RE: Slip on exhaust
(02-21-2019, 05:02 PM)DBM_imp Wrote:
(02-15-2019, 08:53 AM)jimgl3_imp Wrote: pull the end cap off. drill about 8 1/4" holes. replace end cap. nice deep rumble.
Yup. I drilled several 5/8" holes in the end plate, cut off the snooter pipe, painted the inside end plate with flat black heat paint, and used black high heat RTV sealant when l put the end cap back on. Results are better throttle responce with a nice deep rumble but not too loud. Price was right.
Any pictures please?
And what was the purpose of painting the inside of the end cap?
02-21-2019, 05:11 PM
DBM_imp Offline
Threads: 16
RE: Slip on exhaust
And what was the purpose of painting the inside of the end cap? Sorry no pics. When you cut off the snooter pipe, you can see inside the muffler and the drilled end plate. I painted the end plate to hide the bare metal from the drilled holes.
02-23-2019, 08:50 AM
Honda_Fan_imp Offline
Threads: 4
RE: Slip on exhaust
(02-20-2019, 10:51 AM)Ferrealls_imp Wrote: I have a two bros M2 that I love. It's a little shorter than the delkevic.
What fender kit is that? Never mind just saw breakdown in your signature on
02-23-2019, 09:52 AM
Threads: 8
RE: Slip on exhaust
Drill holes where? Through the end cap or through the metal plate inside the end cap, a few inches down the pipe?
Ignore that, I've found another thread which explains
02-24-2019, 07:26 AM
Threads: 8
RE: Slip on exhaust
Done today.
Not the cleanest job but definitely sounds better. Used a dremel cutting disc and a drill with a 1/2 bit
[url=http://smg.photobucket.com/user/spartanheed/media/IMG_20190226_174503_zps0jcairfj.jpg.html][Image: 1f9110f6ffbce30e830b4af0fa4a2163.jpg]
[url=http://smg.photobucket.com/user/spartanheed/media/IMG_20190226_181021_zpshfxyn4cn.jpg.html][Image: 6b8ea45bc872d9dbd386b8f3666e131f.jpg]
02-26-2019, 04:16 AM
Threads: 4
RE: Slip on exhaust
#26
I believe obligatory sound clip is required
02-26-2019, 05:56 AM
Frulk_imp Offline
Threads: 108
RE: Slip on exhaust
#27
Off topic but Peter asked about my seat earlier in this thread and just now caught that. It’s a K and H from Samurider. Bought off Member Lola on this forum. Vinyl. Can be custom ordered for height/weight/cover/seating surface etc. although I’m prob heavier than previous owner the seat is all day comfortable as it is.
02-26-2019, 06:16 AM
thebrawnyman_imp Offline
Threads: 2
RE: Slip on exhaust
#28
(02-26-2019, 04:16 AM)spartanheed_imp Wrote: Done today.
Will this slight difference have adverse effects to horsepower? Or cause the fuel map to run lean? Interesting to know how it felt riding after, if you noticed any "pickup" differences.
02-26-2019, 06:26 AM
Threads: 8
RE: Slip on exhaust
#29
No idea. There was a thread on here years ago with lots of people doing the same and no one complained
02-26-2019, 07:03 AM
Bheezy27403_imp Offline
Threads: 39
RE: Slip on exhaust
#30
Any gains or loses from this will be minimal.If you could tell a difference I would give you $20. The ecu will adapt to the small change.
02-26-2019, 07:04 AM
  need help installing slip on exhaust nw suburb, IL jm0327_imp 18 1,670 10-25-2024, 12:12 PM
Last Post: iamheero_imp
  Exhaust system/slip-on johnny_elpino_imp 26 2,155 05-26-2023, 01:06 AM
Last Post: kzoorue_imp
  Arrow Slip-On Thoughts le_penseur_imp 84 5,753 05-15-2023, 05:20 AM
Last Post: mrded_imp
  delkevik slip on mufflers outback_imp 4 559 10-14-2021, 12:44 AM
Last Post: outback_imp
  Delkevic Muffler slip-on wgscheib_imp 2 376 06-08-2021, 01:48 AM
  Arrow slip on mufflers DougsZ28_imp 15 1,275 05-13-2021, 04:09 AM
   Over racing slip on spartanheed_imp 7 788 07-05-2020, 08:33 AM
Last Post: Cobalt23_imp
  Busso Slip-On and DLX Seat Cobalt23_imp 15 1,020 07-02-2020, 07:51 AM
  Arrow slip on, amazing! Kawiboy_imp 72 4,616 05-27-2018, 07:48 PM
Last Post: VAslim16_imp
  Yoshimura RS 3 Signature slip on exhaust Derby Joe_imp 3 370 05-15-2018, 02:45 AM
