hellfire vs plexistar 2 windshields
Likes Received: 877 in 480 posts
Likes Given: 1,011
RE: hellfire vs plexistar 2 windshields
Chuckk, just remove the rear bolt holding the tank so you can lift it a little. That’s enough to run a cable.
10-18-2019, 07:57 AM
peterbaron Offline
Likes Given: 996
(10-18-2019, 02:15 AM)Chuckk_imp Wrote:
(10-12-2019, 11:39 AM)Chuckk_imp Wrote: I brushed on 3 or 4 coats of urethane.. my goal was to seal the wood mainly.. the table is made to take abuse and I do just that at times.. I have filled many of those oil pans with nuts and bolts etc.. I don't fill them up too much, allowing me to finger through them looking for that special item.. I use a larger oil drain pan to service my bike.. I have a shed that I keep "stuff" in ..
.[Image: cd322d81da578c10c3e98eef83564847.jpg]
.[Image: 5054a46b2b2f9faf2089117b3f72d117.jpg]
G.O. will have fun picking through my stuff haha ..
getting back on the subject, I did another fuel consumption test today .. as usual, it was a dirty job.. haha .. it seems to be very close to my first m.p.g. test that I did with the plexistar 2
.[Image: 784fe31f71c203cb12228c92294d5a86.jpg]
just to add... I have checked my mileage 3 or 4 more times and the 55 m.p.g. seems to be holding.. that's good news.. today I will start to run a lightning cable from under my seat, up to my handle bars.. this will allow me to keep my iPhone at the ready for doing short videos.. I will try to fish the cable through, under the tank.. I have had the tank off once and that fuel connector was a pain !! ..
..[Image: a5bbe615f09f4c14c1ac4bde1dcb40be.jpg]
Chuckk, I hope you fuse and gauge these circuits properly???, and I know, you have a lot...so do not burn/overload it
Some helpful links:
http://knowhow.napaonline.com/know-how-n...ing-guide/
http://www.offroaders.com/technical/12-v...e-to-amps/
http://www.emrg.ca/dc_wiring.htm
Thumbs UpSmile
10-18-2019, 08:10 AM
Chuckk_imp Offline
Threads: 19
(10-18-2019, 07:57 AM)Cormanus_imp Wrote: Chuckk, just remove the rear bolt holding the tank so you can lift it a little. That’s enough to run a cable.
that was my plan, to lift the tank just a bit.. maybe using a coat hanger to feed it through.. I'll be digging into it tomorrow.. it seems, to keep your friends of dying from boredom, I have to keep the videos about 1 to 2 mins. long.. then I can send them through messages and have audio and video.. I love my Mac .. I can view things full screen.. I haven't tried it yet, but I could also use google maps if I have reception.. the iPhone is in a perfect spot to view them.. thanks cormanus for your input...
chuckk ..
Some helpful links:
Thumbs UpSmile
Some helpful links:
Thumbs UpSmile I attached directly to the battery knowing there was a handy in-line fuse for the heated gear.. I think it is a 7 amp.. the other gizmos have a very small draw. the clock, beeper, and thermometer I picked up the power from in the headlight .. I just have to remember to turn off my heated gear when I stop for a while.. they could drain the battery some.. I have compensated for the extra power consumption by going to the LED rear directionals.. I don't know how that really balances out, but I believe mr. Honda gave me a little extra charging capability..
10-18-2019, 08:33 AM
peterbaron Offline
Likes Given: 996
OK, just in case, Popgun has 50 mile, wireless booster cable set TongueSmile
[Image: 7e37a2da95ed0a4f70e96706cee0b78f.jpg]
^^ if you disconnect gas tank breather hose (R-lower side of tank), you can get extra space/lift tank higher....to route your wires
10-18-2019, 09:02 AM
Chuckk_imp Offline
Threads: 19
[quote='peterbaron' pid='251528' dateline='1571439761']
[Image: 451045c7d6402d5bb22923c6b7c89e3a.jpg]
I think Nicola Tesla has the patent rights on the 50 mile wireless booster cable.. and yes Peter, I will try to gain as much room as I can, without messing with the fuel line..
10-18-2019, 09:37 AM
peterbaron Offline
Likes Given: 996
#26
Chuckk, breather hose = no mess, not fuel line
10-18-2019, 09:46 AM
rboe Offline
Phoenix, AZ
Threads: 64
Likes Received: 6 in 2 posts
Likes Given: 7
#27
Paper towels are, optically speaking, very abrasive. Upgrade to micro fibre cloths (Costco sells large bulk pack, Harbor Freight has them too) and I think you'll find them superior to Bounty (except in the picking up spills department).
10-18-2019, 10:03 AM
Chuckk_imp Offline
Threads: 19
#28
yes Peter.. I know what you mean.. I have had the tank off before, and the fuel line was the troublesome one.. I took several pics with the tank off, so I could view what was under that thing.. I think if I would take the tank off again, I would make myself a tool with 2 little wedges that I would be able to slip into that clip, releasing the 2 latching arms.. boy, thats probably clear as mud.. when I finally got the connector apart, I could see what made it tick .. all except that white clip.. I knew it was there to act as a safety, but for the life of me I couldn't get it back in place.. so I improvised.. I doubled up on a plastic wire tie and slid it in where it would have to be removed before the 2 clips could be released ..
.[Image: d90d7dff5b84aa5471449f1b8e0a83e8.jpg]
.[Image: 76c74527654f444e0adceea8bd54d3ee.jpg]
(10-18-2019, 10:03 AM)Rboe_imp Wrote: Paper towels are, optically speaking, very abrasive. Upgrade to micro fibre cloths (Costco sells large bulk pack, Harbor Freight has them too) and I think you'll find them superior to Bounty (except in the picking up spills department).
old dogs.. new tricks ... boy, I don't know ..
[Image: 78c8854bdc5d169a341832bd325b2c92.jpg]
10-18-2019, 10:07 AM
#29
Chuck: Don't tell Nortoon this, however, the average annual lows for Ventura, CA is a tropical 8C (~46.5F) and I reckon that is at night. How often do you use the heated gear?
10-18-2019, 12:38 PM
Chuckk_imp Offline
Threads: 19
#30
to answer your question G.O. I would guess around 20 times a season.. the question that you aren't asking is, what are the average temps in the mountains where I ride in the winter months at 3000 to 5000 feet.. thats where my handy-dandy thermometer comes in.. there is a difference in temps of about 20 to 30 degrees when I go on my rides.. sometimes even in the summer.. at the place we call the 5000 foot overlook, winter temps are usually 40* to 46* .. there are times when I wear my heated gear, but never turn it on.. the system I have made makes it almost effortless to plug and play my heated gear.. when I first bought my Gerbing heated gear, I didn't use it much.. it was such a pain to wire it up.. you know, running a "Y" harness up your back and down your sleeves to connect your gloves to your vest, then plug the vest into the side cover of the bike.. so I spent quite a bit of time, making parts and controller boxes.. it was time well spent.. now I reap the rewards..
10-18-2019, 02:09 PM
  Windshields: Two Reviews and an Inquiry JRD 9 660 01-31-2026, 02:50 PM
  MRA windshields jedd_imp 4 552 06-24-2018, 09:22 AM
  Plexistar 2 with MRA X-creen Sport ScottWally_imp 5 481 08-15-2016, 10:10 AM
Last Post: Gumby 1100_imp
  Givi windshields Dvassino_imp 0 227 11-26-2015, 06:41 AM
Last Post: Dvassino_imp
  Anyone using the Hellfire Windshield? pbhati_imp 6 616 10-27-2015, 12:23 AM
Last Post: pbhati_imp
