RLET’s… How do you get them on?
RE: RLET’s… How do you get them on?
(05-14-2021, 04:41 AM)Olof_imp Wrote: I use just water as lubricant, and rubber gloves to get a good grip on the RLET. I've mounted four sets that way, seldom needs more than half a minute. Let sit overnight to dry out.
You should post a "How To Handle RLET" video here. Smile
Shame all other RLET rituals. Big Grin
Begin a new generation of "RLET Whisperers". Thumbs Up
05-14-2021, 10:27 AM
peterbaron Offline
Likes Received: 573 in 311 posts
Likes Given: 954
Oh my...Lord Popgun accept all new rituals/rules must Smile
05-14-2021, 10:38 AM
Lord Popgun Offline
El Supremo RLET Force
Virginia
Likes Given: 136
Hummm, weak with the force some Padawans are.
05-14-2021, 11:06 AM
Yeah, can't disagree with PG's assessment:
RLET Whisperer vs. The Force
05-14-2021, 11:40 AM
Endeavour_imp Offline
Threads: 5
1. Half an hour in warm water
2. Long nosed pliers to stretch the hole outwards before trying to fit
3. A squirt of silicon wd40, let the excess run out
4. Stretch carefully and slip in the lever ball end
BananaBananaBananaBananaBananaBanana
05-15-2021, 07:00 AM
mvk24_imp Offline
Threads: 18
Likes Received: 2 in 1 posts
#26
I still don't know where to buy RLETS lol
05-19-2021, 01:31 AM
KiowaEagle_imp Offline
Threads: 36
#27
Partzilla has them. Part #95010-16001, there is one per package so make sure you order 2.
05-19-2021, 02:34 AM
mvk24_imp Offline
Threads: 18
#28
(05-19-2021, 02:34 AM)KiowaEagle_imp Wrote: Partzilla has them. Part #95010-16001, there is one per package so make sure you order 2.
Thank you
05-19-2021, 02:47 AM
Whoops Offline
Utah, USA
Threads: 30
Likes Received: 112 in 48 posts
Likes Given: 64
#29
Great success!!
So I basically used and highly recommend the zip tie method for installing RLET's. Took about 5 minutes total.
I followed the method used in this video, exactly. Right down to making sure the music from the video was playing while I installed them (this step may be critical, not sure though as I didn't test without).
Additionally I put on the kettle and heated some water to about 175°f/80°c to put the RLET's in just to warm them up and make them a bit more slippery and pliable.
Then I used 4 zip ties and just pulled the RLET on by pulling on the two side of ties. I also used this method to put Grip Puppies on my bars after trying unsuccessfully to install them using water and soapy water.
05-24-2021, 11:10 AM
#30
That is an original approach to Arlette insertion.
05-24-2021, 12:12 PM
  Please Alert the RLET Fashionistas rdprdp01 6 473 09-12-2024, 11:45 PM
   Rlet's simple fitting Mixagon_imp 13 911 05-24-2021, 12:07 PM
  RLET Heaven.. Frankie_imp 29 1,950 09-16-2020, 04:41 AM
Last Post: Frankie_imp
