Tubeless tires
Houtman_imp Offline
Threads: 115
RE: Tubeless tires
(08-03-2017, 08:02 PM)Flynrider_imp Wrote: It may be my imagination or failing memory, but I recall reading that tube rims and tubeless rims have different bead properties (i.e. differently angled beads). And that tubeless rims had extra bumps in the bead area to keep a tubeless tire's bead from moving inward.
I am under that impression too , perhaps tubeless tires ok on a tubed rim but not the other way around ?
08-03-2017, 08:49 PM
Likes Given: 1,016
RE: Tubeless tires
I don't know about motorcycles, but I'm sure I've seen punctures in tubeless tyres on cars fixed simply by putting in a tube.
08-03-2017, 10:36 PM
Threads: 698
Likes Given: 792
RE: Tubeless tires
At the shop I go to the head mechanic is running a tube in the rear tire on his Goldwing, and suggested a tube to me when I punctured a new PR4 GT with 2600 miles on it on my ST. I opted for a new tire since I have 83 degree valve stems.
08-03-2017, 11:37 PM
CA200_imp Offline
Threads: 42
RE: Tubeless tires
Putting a tube in tubeless rim takes away some safety , it is just like riding a bike with tubes in a spoke rim.
08-04-2017, 12:03 AM
Likes Given: 1,016
RE: Tubeless tires
CA200, you know about this stuff. Can you put a tube in a tubeless tyre on a rim designed for a tubed tyre?
08-04-2017, 07:08 AM
Houtman_imp Offline
Threads: 115
RE: Tubeless tires
#26
(08-04-2017, 07:08 AM)Cormanus_imp Wrote: CA200, you know about this stuff. Can you put a tube in a tubeless tyre on a rim designed for a tubed tyre?
I would like to know this too !
08-04-2017, 08:07 AM
Tev62 Offline
Threads: 33
Likes Given: 95
RE: Tubeless tires
#27
Did anyone get a definitive on whether the rim on the 2017 EX model will safely support a tubless tyre fitted with the inner tube? I just looked up the cost of the Honda official OEM tyre. Front €729/€60 and Rear €841/€58 tyre and inner tube respectively. WHAAAAAAAAAAAAATTTTTTT! The actual wheels are cheaper.
12-16-2020, 06:13 AM
Houtman_imp Offline
Threads: 115
RE: Tubeless tires
#28
I put the OEM Dunlop's on my 2017 , including inners . Not cheap but still a lot cheaper than in Ireland ! Could you get them somewhere else or perhaps look into the OUTEX conversions.
12-16-2020, 06:33 AM
RE: Tubeless tires
#29
(12-16-2020, 06:13 AM)Tev62_imp Wrote: Did anyone get a definitive on whether the rim on the 2017 EX model will safely support a tubless tyre fitted with the inner tube? I just looked up the cost of the Honda official OEM tyre. Front €729/€60 and Rear €841/€58 tyre and inner tube respectively. WHAAAAAAAAAAAAATTTTTTT! The actual wheels are cheaper.
Consider checking the Japanese CB1100 forum site.
Outex is Japanese. The CB1100 is, well, ... popular over there too. Might get lucky.
12-16-2020, 12:46 PM
Likes Given: 1,016
RE: Tubeless tires
#30
Several members of the forum have done the outer conversion.
12-16-2020, 01:08 PM
  Tires ~ Converting tube to tubeless type. 17-CB-002 30 2,323 05-14-2026, 05:50 AM
Last Post: Kikemon
  120-80/18 tubeless endure tire...anyone? Ferrealls_imp 2 399 06-25-2015, 02:20 AM
Last Post: lemontree_imp
