Crank Case Cover removal?
furious_blue_imp Offline
Threads: 11
RE: Crank Case Cover removal?
(02-01-2020, 01:29 PM)motoWest_imp Wrote: I know this thread is old, but I thought I would chime in with my experience. To make a long story short, I was unable to remove my cover. I drained the oil, removed all the bolts, got a rag and mallet and . . . . the dang thing wouldn't come off! I'm not sure if someone had removed it before me and applied a super gasket of some sort, but I was in my garage for two hours tapping and pulling and cursing.
In the end, I had to refill the bike with oil, apply some JB Weld to the hole in the stator cover (side-swiped in traffic, that's another story) and take it to the shop with my tail between my legs.
On the plus side, because I provided all the parts, the shop bill was only $90. In hindsight, I would've saved myself a lot of grief had I taken it there to begin with.
FWIW, in 2009 I wanted to remove a cover on my Blackbird so that I could replace a broken stator. Same story, tapping, banging but resisting the urge to lever it off with a chisel. I never was able to remove it and it was as it was installed from the factory since I bought that bike new. Professional mechanics must use some kind of slide hammer device to remove it ? maybe ?
02-22-2020, 12:17 PM
Whad 'bout sum sort of ultra-sonic device to tease it loose?
Anyway, sumthin' higher frequency than a bedside drawer device.
02-22-2020, 01:15 PM
Threads: 11
(02-22-2020, 01:15 PM)GoldOxide_imp Wrote: Whad 'bout sum sort of ultra-sonic device to tease it loose?
After all the tears and not being able to to get that cover off, I really wonder how the pros do it !
02-22-2020, 01:27 PM
Likes Given: 1,015
They probably look around to make sure no one is looking and give it a mighty belt with a rubber mallet. Big Grin
02-22-2020, 06:50 PM
jimgl3_imp Offline
Threads: 27
thinnest feeler gauge you've got. work it in easy then work your way around
also might try bumping the motor. if those gears seen in post 9 have tension on them, that could prevent it from slipping off I think.
02-22-2020, 11:31 PM
Threads: 11
#26
(02-22-2020, 11:31 PM)jimgl3_imp Wrote: thinnest feeler gauge you've got. work it in easy then work your way around
hmm... I've been thinking of giving the CB engine cases a good polish some day, I'll have to keep this mind when it's time to take the covers off !
When trying to remove my old Blackbird stator cover I gave it MANY mighty whacks with a rubber mallet, didn't budge it a bit. It was/is amazingly stuck on there.
02-23-2020, 02:44 AM
Houtman_imp Offline
Threads: 115
#27
Rubber mallets will not do it, you need a jack hammer.
02-23-2020, 06:40 AM
Likes Given: 1,015
#28
Why didn’t I think of that?
02-23-2020, 10:36 AM
PowerDubs_imp Offline
Threads: 125
#29
Stopped using rubber mallet for anything a long long time ago.
Dead blow hammers work wonders. Cheap too.
02-23-2020, 10:52 AM
Olyrider Offline
PNW
Threads: 23
#30
I used a 4 1/2 inch Harbor Freight double-handle suction cup. It cost $3.49.
02-24-2020, 10:32 AM
  SW-Motech Top Case (All CB1100 Models) rdprdp01 2 529 08-20-2025, 06:25 AM
  Anyone recommend s a top case for the 13' OEM rear Carrier? iamlegend21087_imp 14 1,182 06-21-2023, 08:51 PM
Last Post: Tbhart89_imp
  Accessory Removal Wagonpeddler_imp 13 1,029 03-22-2022, 05:22 AM
Last Post: Wagonpeddler_imp
  Honda top case install Jonnyteabag_imp 11 930 12-31-2021, 09:22 AM
Last Post: Jonnyteabag_imp
  Givi SR1118 Top Case Rack active1951_imp 4 507 06-28-2021, 07:08 AM
Last Post: Tom_imp
  Apache 4800 top box. (HF/Pelican case) mvk24_imp 12 1,024 04-16-2021, 04:01 AM
  Givi Side Case Racks...Do they exist? cbolling_imp 21 1,274 08-28-2020, 08:34 PM
  Case paint - need a suggestion to match stock skidmarkart_imp 15 862 03-16-2020, 08:20 PM
Last Post: FLYTYM_imp
  Stripping black finish off of 2017 engine case and cylinders Greaseball_imp 9 812 09-12-2019, 09:59 AM
  iPhone anti-glare case (or alternative ideas) emptysea 9 837 08-05-2019, 08:10 AM
