How To do your own 600 mile service
Great post. Love the details and pics.
(05-02-2013, 12:10 PM)The ferret_imp Wrote: Congrats you have just completed your own 600 mile service. Be sure and record date, mileage and save your receipts for warranty purposes. Not only have you saved up to $100 at your local dealership and maybe a couple days without your bike if the shop is busy, but you know your service was done right, and you've become more familiar with your bike.
If anyone notices any errors, please bring it up so we can correct it asap. Thanks.
Hope this helps some of the newbies.
(05-02-2013, 12:09 PM)oldyaler_imp Wrote: Well done ferret. Whenever I do any work like that I have to add a step. Before I start I go ahead and spill a little oil on my shirt and hands Because IT 'S GONNA HAPPEN ANYWAY.Big Grin
Yep...
I hate oil, hate it. Like you said, it gets on me, my tools, my garage floor, my work bench, everything that gets near it, but its a necessary evil.
It's nice to be able to do basic service work on your motorcycle though, and to be able to do it on your time schedule, and not at the mercy of the dealer which may be 100 miles away.
Trust me on this, I am not mechanically inclined, but this kind of stuff is really easy. You can do it.
Not only that, but it takes less time than two round-trips to my dealer.
Valves at 8K mi. I take it they are typical Honda, and usually only need checking.
Tom
Heres another tip for you all. The crush washer for the drain plug Honda part # 94109-14000 costs $1.00 at my local motorcycle dealership ... but my 08 Honda Civic uses the exact same crush washer Honda part # 94109-14000 and they only charge 30 cents for it. While out riding stop at the car dealer and get a couple extras and keep them in your tool box just in case.
Thx Ferret, a question about checking the oil level:
With the bike on the center stand, after I run the engine for 20 seconds or so and then shut it off the oil level looks about right.
Then after it sits on the stand for another hour or so the level looks higher, slightly overfull. When is the proper time to check the level?
Every manual I've ever seen says to run it for 3 to 5 mins, then shut it off for 3 to 5 mins, then check it.
Ill run em for 2 to 3, shut it off, and go inside for maybe 10 mins, wash my hands, get a sip of water, then check it. im not sure it really matters that much. You want oil circulated into the engine, and then you want it drained into the oil pan. Giving it a couple minutes for each should be plenty. Remember it doesnt have to be exactly on the upper level line, just " between" the lines.
How much oil did you put in it? Spec is 4 qts 3.2 oz with filter, but mine was over the upper limit line at 4 qts.
I put in an even 4 quarts.
Yep mine was a little full too at 4 qts. Not enough to be concerned over but next time its 3 qts 28 oz,then run it and let it sit, then sneak up on the full line with subsequent adding.
Ferret, did you drain yours on the sidestand at all? I find that, depending on the drain bolt location, if I drain it on the sidestand, then stand it up for a while, then back on the sidestand, and then repeat once more, a surprising additional amount of oil will flow out. In looking at your pictures the CB's drain bolt does look to be in an ideal location for draining, so the centerstand only is probably all you need on this bike. However, the back and forth as I describe above does seem to 'find' some additional oil trapped in passages and galleries etc.
Scoob..you are right, on some bikes, my FZ 1 for example the drain bolt is on the side. On it I drain on the side stand. Fr some reason on Hondas that I have seen, they are set up for draining on the centerstand. Yea wiggling them back and forth may get you some more oil, but I doubt its an ounce. If you drained the oil then set a clean pan underneath overnight, Id bet youd get more. Oil seems to never quit draining thru a hole lol.
(05-07-2013, 07:29 AM)The ferret_imp Wrote: Scoob..you are right, on some bikes, my FZ 1 for example the drain bolt is on the side. On it I drain on the side stand. Fr some reason on Hondas that I have seen, they are set up for draining on the centerstand. Yea wiggling them back and forth may get you some more oil, but I doubt its an ounce. If you drained the oil then set a clean pan underneath overnight, Id bet youd get more. Oil seems to never quit draining thru a hole lol.
I hear you, Ferret. I'm just a little anal about these things, but I know you're never going to get all the old oil out. Like you I find something else to do while I give it extra time to drain. One thing I'm sure of, us DIY'ers let it drain a lot longer than the dealers do!
  Service manual Billie_imp 32 2,949 11-27-2025, 06:35 AM
Last Post: TheLegend
  2018 CB1100EX just collected from service Motorsport3_imp 5 557 05-10-2023, 11:25 PM
Last Post: Motorsport3_imp
  Preparing to do a fork service, any advice? skidmarkart_imp 12 1,236 04-23-2023, 01:35 AM
  Service and Repair Manual alexzanutto_imp 5 648 02-26-2022, 10:02 PM
Last Post: alexzanutto_imp
  Factory Service Manual Download ??? markT_imp 24 1,883 10-14-2021, 09:30 AM
Last Post: furious_blue_imp
  Service indicator - unleashed j3gq_imp 6 613 07-27-2021, 03:12 AM
  Free Honda SERVICE Manuals dan88_imp 9 896 03-30-2021, 08:18 PM
Last Post: Enzofour_imp
  DLX is back from service LongRanger_imp 18 1,270 01-14-2021, 08:00 AM
  First Service larryblag_imp 46 3,030 09-18-2020, 09:11 PM
Last Post: spechg
  Honda Common Service Manual pekingduck 35 2,560 04-26-2020, 03:12 AM
