battery /charging system issues
(04-14-2014, 09:30 AM)Pterodactyl_imp Wrote: My bike is not being used at the moment but, even so, the weekly kick in the guts brings it straight to life. I did have a problem not so long ago where I used the kill switch to shut down and left the ignition on for a few minutes. Result was a badly discharged battery. Fortunately I had parked on a slope so I did a bump start. Since then no problems and I have got out of the habit of using the kill switch.
I am interested in the actual charge rate as measured by you guys. I have the feeling that with any added electronics the system would only just cope.
Interesting. I always leave my bike in gear when i shut it down and lock the steering. So I've been using the kick stand as a kill switch. So it sounds like I've been doing the same thing to my battery that you've done. It started right up every time since yesterday morning so sound like i just left it with a low charge Friday night when i left the light on while i took my bag off the seat and used the kill features to much.
(04-14-2014, 11:59 PM)The Spaceman_imp Wrote:
(04-14-2014, 09:27 AM)dlhmatt_imp Wrote: Yeah Florida doesn't get cold enough for me not to ride everyday.
But soon it will get hot enough and wet enough...at least down here in the sub-tropical part of the state.
Everyday, rain or shine. Just hit 7000 on the clock and i haven't even been on a proper trip yet. About 1000 a month. Minus the month off for recovery time after my accident.
Not even a hint of battery/charging system problems here, but like you, I have no off-season here.
(04-15-2014, 05:41 PM)Rolls_imp Wrote: Not even a hint of battery/charging system problems here, but like you, I have no off-season here.
Same here. Just turned over 10,000 miles and no issues with anything.
I think there is a warning not to use the kill switch to turn off the engine in the manual. I know my Triumph manual had warnings about this practice stating it could lead to battery discharge.
Interesting, I use the kill switch all the time but as soon as I hit the kill switch I turn the key of as well. I am not having any kind of battery issues what so ever. Could it be that I turn the key off with say a half minute, 30 seconds, if not immediately? Could the issue be that the key isn't being turned off in a reasonable amount of time thus causing this drain?
On a lighter side, maybe it is because I have grape seed oil in my battery instead of electrolyte? Wink Tongue
Sent from my XT1055 using Tapatalk
(04-15-2014, 10:36 PM)redbirds_imp Wrote: I think there is a warning not to use the kill switch to turn off the engine in the manual. I know my Triumph manual had warnings about this practice stating it could lead to battery discharge.
What's a manual? You mean the multi layered beer coaster that came with my bike?
  ABS , speedometer and battery Walter 10 791 05-02-2026, 01:29 AM
Last Post: Walter
  Yuasa Battery Life dave 28 2,519 04-01-2026, 04:44 AM
  Rattle on right side exhaust / battery CB1100i_imp 4 677 04-18-2025, 02:48 AM
Last Post: CB1100i_imp
  Battery jumper the Ferret 14 1,083 10-28-2024, 10:58 PM
  CB1100 SA-E 2017 Battery Davidjill_imp 1 277 08-01-2024, 02:33 AM
  wonder battery The Gecko_imp 58 4,545 02-19-2024, 11:20 PM
  Could old/low battery trigger misfire and engine light? Motorsport3_imp 13 1,227 12-17-2023, 08:41 AM
Last Post: Jgarciajr40_imp
  Replacement Battery dave 54 3,967 02-04-2023, 12:41 PM
  Winter Battery Maintenance Wagonpeddler_imp 27 2,162 10-18-2022, 01:55 AM
  dead battery louied_imp 62 4,242 10-16-2022, 03:48 AM
