Can't get speedometer working after accident
(04-25-2014, 12:11 PM)Firstfour_imp Wrote:
(04-25-2014, 04:13 AM)lccb1100a_imp Wrote:
(04-25-2014, 04:04 AM)HikerToo_imp Wrote: What happen by BTW?
Back in January we had an unusually warm day, and I took it out. Going around a turn I lost traction because I hit the throttle too hard. I tried to get it back up, but I couldn't and I wound up going down and slamming into the curb head first. Luckily the curb was at a 45 degree angle and not 90 degrees or it would have been much worse for the bike and for me. I was just bruised, but the whole front of the bike was smashed in. I waited about 2 months before I even called to get it repaired, and now it's been about 5 weeks and it's still not done. It's rideable, but no speedo, and it won't go over 6000 RPM, so that's no fun.
The mechanic said the needle does sweep when powered up. Meter is brand new and sensor is working fine. Signal is getting into the antilock brake box. Ugh!
(04-25-2014, 02:05 AM)TINK_imp Wrote: The speedo uses the rear wheel sensor, your shop guy will need to troubleshoot the meter and the rear wheel sensor connections.
Q: When you turn on the key does the speedo needle sweep? If not start looking for bad connections at the meter.
Back in January we had an unusually warm day, and I took it out. Going around a turn I lost traction because I hit the throttle too hard. .
Another refutation of the "underpowered" nature of the CB1100.
Another refutation of the "underpowered" nature of the CB1100. No @~*^e. This bike is just fine as delivered and by the way it is NOT a beginner's bike. It is just now starting to get my attention and after just spending an entire day wringing out my GSX-R on the racetrack, the fact the CB1100 is still very interesting is saying something.
As sorry for the OP's terrible predicament as I am, I have a few problems believing the circumstances of the accident.
To have the bike power slide away from you as you describe sounds unlikely from my experience, as the power isn't insane and the torque is fairly flat.
What I suspect happened was you made the bike unstable for whatever reason, and then tried to correct, causing a loss of control.
Stable bike + stable rider = good juju
Stable bike + unstable rider = potential crash
Unstable bike + unstable rider = no worky speedo.
If I'm wrong, just ignore me.
Back to the post please let me know what you find wrong with your speedo. I like to know these things, makes for a great forum Smile
Michael
Does it rev well in neutral, when it might be unaware of a faulty speedo?
  ABS , speedometer and battery Walter 10 815 05-02-2026, 01:29 AM
Last Post: Walter
  O2 sensor eliminator not working on CB1100rs 2017 tory_imp 33 3,023 03-06-2026, 04:31 AM
  Basic Speedometer Troubleshooting George050994_imp 5 514 07-03-2023, 03:30 PM
Last Post: George050994_imp
  Clutch Not Working Henrik_imp 7 660 04-24-2023, 06:43 PM
Last Post: Henrik_imp
  After market turn signal on CB 1100rs 2018 not working Saltani_imp 6 563 12-08-2022, 09:24 PM
Last Post: leung_imp
  New Speedometer Not Working wanobiben_imp 15 1,193 04-13-2022, 01:38 AM
  CB1100 Meter replaced - Speedo, ODO, not working, ABS light ON HELP! danieljrmurray_imp 14 1,304 03-31-2022, 04:03 AM
  Indicators not working AlexCB_imp 8 648 02-28-2021, 03:22 AM
  Speedometer and Odometer aren't working caleb_dud_imp 13 1,052 01-07-2021, 02:59 AM
Last Post: Gover_imp
  One horn not working peterbaron 2 292 06-11-2020, 11:04 AM
Last Post: LakeWylieJoe_imp
